FS: NEW Lemfoerder Turbo Tie Rod Set $199 shipped, Great Update SOLD |
914Sixer |
Mar 4 2023, 11:57 AM
914 Guru Group: Members Posts: 9,049 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Complete kit ready to use. Thought I would need it but only need tie rod ends. $199 shipped
PP: a914nut@email.com Attached image(s) |
technicalninja |
Mar 4 2023, 12:22 PM
Advanced Member Group: Members Posts: 2,287 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I'll take those.
Thanks Rick |
914Sixer |
Mar 4 2023, 12:34 PM
Gone to Rick
technicalninja |
Mar 7 2023, 04:26 PM
Received!
Mark has NICE stuff and ships INSTANTLY! You've been paid Mark. |
second wind |
Mar 7 2023, 11:59 PM
Senior Member Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Quick question....why do different tie rod ends make any difference to the handling of the car? Aren't the specifications and measurements identical? Thank you for the sharing of knowledge....
gg |
technicalninja |
Mar 8 2023, 12:08 AM
These get rid of the funky inner tie rods that the 914 came with.
The original inner ends have a rubber coupler in them, and the "turbo" ends are a ball and socket joint like every other inner tie rod end in existence. The 914 inners are strange. The 930 inners are beefy. No geometry changes at all, just an upgrade. These are nice German Lemfoerder NOS pieces. I believe Lemfoerder was the OEM supplier to Porsche. That's why I bought them. Marks a good guy as well. |
second wind |
Mar 8 2023, 12:20 AM
These get rid of the funky inner tie rods that the 914 came with. The original inner ends have a rubber coupler in them, and the "turbo" ends are a ball and socket joint like every other inner tie rod end in existence. The 914 inners are strange. The 930 inners are beefy. No geometry changes at all, just an upgrade. These are nice German Lemfoerder NOS pieces. I believe Lemfoerder was the OEM supplier to Porsche. That's why I bought them. Marks a good guy as well. Thank you for the info and yes Mark is awesome!! So what difference will the driver experience? Thank you very much!! gg |
914Sixer |
Mar 8 2023, 07:05 AM
You get a steel ball socket vs a rubber joint with metal sleeve. More positive feel.
dax1969 |
Mar 8 2023, 07:24 AM
Member Group: Members Posts: 377 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Wow, checked and the Lemforder turbo tie rod kit is expensive on your side of the pond. Normal price in Europe is 125 usd and I paid with a special deal only 104 usd. They make a difference so good buy greetings Dax |
rhodyguy |
Mar 8 2023, 08:09 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Do those $125 units have castellated nuts that require a cotter key or Nylocs?
Montreal914 |
Mar 8 2023, 09:15 AM
Senior Member Group: Members Posts: 1,751 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
rhodyguy |
Mar 8 2023, 09:37 AM
NOS vs fancy new TTKs with one use cost saving nuts.
technicalninja |
Mar 8 2023, 09:47 AM
the ones Mark sent me have class 4 locking nuts for the outer TREs.
Class 4 nuts do not have nylon in them. They are "supposed" to be single use items but you can get away with using them 3 or 4 times. Especially if you use blue Loctite on the 2nd and up times. I've never had a nut like this come off after tightening and I've re-used class 4s many times. The normal application for class 4s is a high heat application that would melt the nylon insert out. |
dax1969 |
Mar 9 2023, 04:53 AM
Lo-Fi Version | Time is now: 22nd January 2025 - 05:33 AM |
