New Engine Time!, First drive on 4/23/23! |
VaccaRabite |
Mar 17 2023, 09:03 AM
En Garde! Group: Admin Posts: 13,615 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
About 18ish months ago I bought into a new engine program Eric and PMB were starting up. If you have seen me in person I've probably talked your ear off about it. Sorry about that, I've been pretty excited.
Mine is No2 off their line, and its crated up in Utah waiting for the shipper to pick it up. So its really real time here in Dallastown, and I've started getting my 2056 ready to come out. The new engine! (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1679065407.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1679065409.2.jpg) I *think* (and could be wrong) that Eric also used my motor as the promotional model for Facebook and his Web storefront - though that could have been Risdal's engine which was right behind mine. Eric and Larry did a lot of testing on the #1 engine in Jim's car, got a lot of driving data at Red Rocks last fall, and then had to wait on components to come in that resulted from that real world testing. My engine was crated last week. I asked Eric to include some other things (including his new brake lines and new pads), paid the final invoice for parts and shipping and the engine will hopefully be in my garage next week! @Stratplayer @Eric_Shea |
Craigers17 |
Mar 17 2023, 09:28 AM
Senior Member Group: Members Posts: 807 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
(IMG:style_emoticons/default/smilie_pokal.gif) That's a thing of beauty! Any dyno #'s available?
VaccaRabite |
Mar 17 2023, 09:29 AM
Last night I started working on unhooking all the stuff that connects the engine to the car.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1679067022.1.jpg) 914 went up on the quickjacks. I have a lift in the other bay, but as you can see my Westy is taking that spot right now for its re-wiring job. The quickjacks will work fine for this. I took off the 1.8 airbox, and all the MS2 EFI stuff that had been attached to the engine bay of the car. The airbox and it supports came out and got shelved, but the EFI parts just got layed on top of the engine and will drop out with the engine. My current engine uses stock fuel runners. Do they need to come out before I drop the engine? I don't recall if I put those on once the engine was in the car or not. Under the car I only had time to pull the heat exchangers off. Some of you may remember my exhaust issues last year that ended up with me breaking an exhaust stud about 1mm into the head. Ahh, good times. After I fixed that, there was still an exhaust leak. I figured I had cracked the exchanger just inside the heater jacket (where they are super prone to cracks anyway. Well, I was partially right. I HAD cracked the exchanger, just not where I thought. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1679066960.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1679066960.3.jpg) That was the same ear as the broken stud. I don't remember it looking like that when I put the heat exchanger back on last spring, but it had to have started there and probably opened up when I torqued the heat exchangers back onto to the car. Amusingly once the car warmed up that big crack would close up and the leak would become inaudible. I had damn near torn the entire ear off! But the cracked primary was small enough that it would close up when it got hot. I have a new (used good) set of SSIs to go on, but these might be work getting fixed. That's as far as I got last night before I got called in to help make pirogues and then grill up dinner for the family. If things go to plan I'll either have the engine out tonight or will be damn close to having that done. Goal is to have the car driving again by April 1. Zach |
Cairo94507 |
Michael Group: Members Posts: 10,125 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Wow! Very exciting news. What are the build specs? I know you can't wait to get that baby in and fired-up. Looking forward to seeing install photos and maybe even a video of the first fire-up in the car. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beerchug.gif)
VaccaRabite |
Mar 17 2023, 09:33 AM
Aside from the engine swap, that other tasks to be done include mounting new tires, new SS brakelines from PMB, new porterfiled pads, new brake fluid, and hopefully not needing new rotors and bearings - as that will blow my time budget.
Zach |
930cabman |
Mar 17 2023, 09:42 AM
Advanced Member Group: Members Posts: 3,775 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
(IMG:style_emoticons/default/beer.gif) Looks great, keep us informed of the progress and engine specs
VaccaRabite |
Mar 17 2023, 09:44 AM
Eric does not currently have an engine dyno, but that is the question we are all asking. The estimate is about 160, but we don't have real numbers. Jim's butt dyno rated the No1 engine as "Very Fun" at RRC. QUOTE Wow! Very exciting news. What are the build specs? I know you can't wait to get that baby in and fired-up. Looking forward to seeing install photos and maybe even a video of the first fire-up in the car 2258 CC, full fuel electronic fuel injection and spark. At one point I knew what cam was getting used, but I don't recall now, and I don't want to inadvertently give out Eric's secrets (thought I'm pretty damn positive he does not care). Eric is tagged and I'm sure he will chime in. Zach |
StratPlayer |
Mar 17 2023, 10:22 AM
StratPlayer Group: Members Posts: 3,299 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Eric does not currently have an engine dyno, but that is the question we are all asking. The estimate is about 160, but we don't have real numbers. Jim's butt dyno rated the No1 engine as "Very Fun" at RRC. QUOTE Wow! Very exciting news. What are the build specs? I know you can't wait to get that baby in and fired-up. Looking forward to seeing install photos and maybe even a video of the first fire-up in the car 2258 CC, full fuel electronic fuel injection and spark. At one point I knew what cam was getting used, but I don't recall now, and I don't want to inadvertently give out Eric's secrets (thought I'm pretty damn positive he does not care). Eric is tagged and I'm sure he will chime in. Zach I have the same motor that is almost finished. I should be installed into my car some time next week. Once it's installed it will be dyno. I will post the results of the dyno when I get them. |
914werke |
Mar 17 2023, 10:26 AM
"I got blisters on me fingers" Group: Members Posts: 11,022 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
What is that shroud made out of?
Dion |
Mar 17 2023, 10:30 AM
RN Group: Members Posts: 2,804 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Congratulations Zach. Look forward to seeing this and running around PA!
NARP74 |
Mar 17 2023, 11:39 AM
Senior Member Group: Members Posts: 1,295 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Superhawk996 |
Mar 17 2023, 11:42 AM
914 Guru Group: Members Posts: 6,590 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Mueller |
Mar 17 2023, 11:54 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Wow, work of art...enjoy!
nditiz1 |
Mar 17 2023, 12:04 PM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Looks excellent Zack, waiting in anticipation for the first fire up. Did Eric post up the numbers from the #1 test engine? Curious what it was pumping out.
jim_hoyland |
Mar 17 2023, 12:35 PM
Get that VIN ? Group: Members Posts: 9,556 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Looks great ! The PMB upgrade is a giant step up for the ‘4s (IMG:style_emoticons/default/smile.gif)
rhodyguy |
Mar 17 2023, 01:33 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I think the stock tin is still used.
NARP74 |
Mar 17 2023, 02:12 PM
echocanyons |
Mar 17 2023, 02:49 PM
Advanced Member Group: Benefactors Posts: 2,096 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
This engine is pretty incredible, my son has the first one and seat of the pants feels at least 150hp. The EFI and feel of this engine is hands down the finest air cooled 4 cylinder option that exists for the 914.
The thought and build that went into this whole project by PMB is representative of the next level work that they do for 914s. Attached thumbnail(s) |
Craigers17 |
Mar 17 2023, 03:36 PM
burton73 |
Mar 17 2023, 04:35 PM
burton73 Group: Members Posts: 3,691 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Very excited for you guys to get these engines in your cars, it takes time but it will be well worth it.
Best Bob B (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 22nd December 2024 - 07:12 AM |
