944 Cowl 3rd Brake, Anyone using this fixture? |
Spoke |
Mar 22 2023, 08:50 PM
Jerry Group: Members Posts: 7,076 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
A 914/944 owner asked if I could add LEDs to the 944 cowl 3rd brake fixture. He said this same fixture is also used on some Corvettes. Anyone use this on their 914?
For such a nice exterior, the bulbs are crappy push-in bulbs with even worse sockets. As always, I'm looking for a way to connect wires to this fixture w/o cutting, gluing, splicing. I could solder steel piano wire to the pigtails and plug in to the existing sockets but Steve doesn't think that will work well. There's 2 grommets to this fixture, one to the sealed lens and one to seal through the cowl. There's almost enough room to get a 5mm LED on a board between the reflector and lens. You can see the edge of the reflector is curved. The LEDs don't fit at the top and bottom so the boards will have a cutout there for relief and for securing the boards. The length is 11 inches so I'll make the board span the entire interior of the lens. I'm thinking 36 LEDs which will be quite bright. |
Steve |
Mar 22 2023, 09:12 PM
914 Guru Group: Members Posts: 5,697 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I'm using this setup as well as others. One of my lights is intermittent.
Root_Werks |
Mar 23 2023, 11:09 AM
Village Idiot Group: Members Posts: 8,452 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Would this be mounted on the targa bar behind the rear window?
andys |
Mar 23 2023, 11:32 AM
Corvette.....Forgot what year, maybe late 80's?
Andys Attached thumbnail(s) |
Spoke |
Mar 23 2023, 07:50 PM
Spoke |
Mar 23 2023, 07:55 PM
Not a 3rd brake light but something I designed last week. Not sure how it would look. Basically just an outline of LEDs. Many new vehicles use the LEDs in a pattern of some sort. Why not the 914?
Trying out the new light. Looks interesting with a round turnsignal and an outline brake. |
Mar 23 2023, 09:00 PM
914-6 GT in waiting Group: Members Posts: 19,572 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’m not a fan of the outline. Looks too modern to me.
Spoke |
Mar 24 2023, 02:56 PM
I'm contimplating using surface mount LEDs for this board but the board is too large to fit into my IR oven. I'll have to print this out to see how it fits in the enclosure.
Getting this arc of the board to follow the curve of the fixture was not trivial. First I had to determine the the amount of arc over the length of the fixture. I measured 85mil arc over the length of 12.5 inches of the lens. Using trig I calculated the radius of the curve of the fixture to be 229 inches. I could have used an arc of 229 inches in Altium for the board outline but the maximum PCB workspace is like 10 x 10 feet. 229 inches is just over 19 feet and I couldn't get the arc to work. So I ended up using small sections of straight lines to make the arc. |
Spoke |
Mar 24 2023, 10:32 PM
Printed the board and placed it in the fixture. I got the curvature right but the board is too tall. It fits between the reflectors and the lens but the lens needs to be pushed out a bit to fit the board+LEDs.
The reflector hugs close to the exterior and you can see the indentation the lens makes to the sealing gasket. Notice too the extruding braces. These might contact the board when assembled. I think I'll have to leave a relief in the board to accommodate these ridges. |
Geezer914 |
Mar 25 2023, 12:52 AM
Geezer914 Group: Members Posts: 1,742 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I purchased one off eBay a few years back for $25. 86-95 Corvette. Tapped into the tail light wires running under the relay board. Used quick connects so I could remove the engine lid if needed. Mine has a one piece gasket that covers the entire bottom of the light except for the 2 mounting holes and 1 for the wires.
Geezer914 |
Mar 25 2023, 05:45 AM
andys |
Mar 25 2023, 09:01 AM
Whatever came with it. Geezer914 seems to know. Andys |
Geezer914 |
Mar 25 2023, 10:32 AM
The bulbs are 891. Super Bright LED bulbs sells a G4 LED bulb for 3.99. 180 lumens vs 145 for the 891 bulb.
Spoke |
Mar 25 2023, 04:15 PM
The bulbs are 891. Super Bright LED bulbs sells a G4 LED bulb for 3.99. 180 lumens vs 145 for the 891 bulb. @Geezer914 Is this the G4 LED you're referring to? G4 Bi-Pin LED Light Bulb - 20W Equivalent - 180 Lumens - 12V - Dimmable If so, did you do the warm, natural, or cool version? I'd like to purchase a few to test them out. If these are not the ones you used, please point out which one you used. Thanks, Spoke |
Spoke |
Mar 31 2023, 10:56 PM
Spoke |
May 3 2023, 11:05 AM
Boards are in.
Designed some clips to hold the boards in the fixture. Seem to fit well. The boards + clips drop right in. The first boards have been populated. So glad I went with 2 small boards instead of one long board. These fit into the IR oven and makes assembly much easier. Waiting on the lenses for the LEDs. The Carclo 10415 lenses are as expensive as the LEDs. The connectors will be interesting. The easiest method would be to solder some piano wire of the correct gauge onto the wires then push them into the existing sockets. Steve who was the catalyst for the project does not want to use the existing bulb sockets because of oxidation/corrosion but I'm not a fan of cutting/splicing or any way damaging the fixture. If someone would like to try these out, please contact me. I'm giving Steve a set and someone else to try. No charge; I just ask that you report back how they fit and work. |
Steve |
May 3 2023, 11:28 AM
Boards are in. Designed some clips to hold the boards in the fixture. Seem to fit well. The boards + clips drop right in. The first boards have been populated. So glad I went with 2 small boards instead of one long board. These fit into the IR oven and makes assembly much easier. Waiting on the lenses for the LEDs. The Carclo 10415 lenses are as expensive as the LEDs. The connectors will be interesting. The easiest method would be to solder some piano wire of the correct gauge onto the wires then push them into the existing sockets. Steve who was the catalyst for the project does not want to use the existing bulb sockets because of oxidation/corrosion but I'm not a fan of cutting/splicing or any way damaging the fixture. If someone would like to try these out, please contact me. I'm giving Steve a set and someone else to try. No charge; I just ask that you report back how they fit and work. Are you referring to me? Otherwise, I would also be glad to try it out. -Steve |
Spoke |
May 3 2023, 12:08 PM
Are you referring to me? Otherwise, I would also be glad to try it out. -Steve @Steve If you're not the Steve I've been working with and sent me the fixture, then yes, I'd be glad to send you a set. Please PM your contact info. It will probably be a week or 2 before I get these out the door. |
burton73 |
May 3 2023, 12:11 PM
burton73 Group: Members Posts: 3,659 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Steve |
May 3 2023, 06:07 PM
Are you referring to me? Otherwise, I would also be glad to try it out. -Steve @Steve If you're not the Steve I've been working with and sent me the fixture, then yes, I'd be glad to send you a set. Please PM your contact info. It will probably be a week or 2 before I get these out the door. PM sent |
Lo-Fi Version | Time is now: 28th October 2024 - 02:58 AM |
