944 Cowl 3rd Brake, Anyone using this fixture? |
rjames |
May 3 2023, 06:48 PM
I'm made of metal Group: Members Posts: 4,126 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
It's a great looking setup and what I was originally going to go with.
However, because that location isn't much higher than the taillights, I opted for locating mine under the targa bar. It's not a lot higher, but with these cars being so low, I thought it might help a bit with visibility. |
Cairo94507 |
May 4 2023, 07:50 AM
Michael Group: Members Posts: 10,051 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I followed Bob's lead and installed an LED 3rd brake light right under the roll-bar hoop. I do not see it when looking out the rear view mirror and it is as high up as you can get it. It really catches your attention when you step on the brakes. (PS -that's a reflection on the trunk lid, not another light. (IMG:style_emoticons/default/smile.gif))
OK, small Public Service Announcement: My personal opinion, as small and low as our cars are, this hi-mount LED 3rd brake light is a modification every 914 owner should move to the top of their list. Additionally, @Spoke (Jerry) makes the absolute best LED conversion kits for all of our lights. Truly plug 'n play and they just work. Wake up your lights so people will see your car before it is too late. Way too many distracted drivers on the roads now. (IMG:style_emoticons/default/beerchug.gif) |
ClayPerrine |
May 4 2023, 11:30 AM
Life's been good to me so far..... Group: Admin Posts: 15,876 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Additionally, @Spoke (Jerry) makes the absolute best LED conversion kits for all of our lights. Truly plug 'n play and they just work. Wake up your lights so people will see your car before it is too late. Way too many distracted drivers on the roads now. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) Don't end up like this: We even had Spokeworks LED taillights in it. I am firmly in the camp that we need a good third brake light solution that mounts up high on the targa band. |
burton73 |
May 4 2023, 11:43 AM
burton73 Group: Members Posts: 3,659 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Additionally, @Spoke (Jerry) makes the absolute best LED conversion kits for all of our lights. Truly plug 'n play and they just work. Wake up your lights so people will see your car before it is too late. Way too many distracted drivers on the roads now. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) Don't end up like this: We even had Spokeworks LED taillights in it. I am firmly in the camp that we need a good third brake light solution that mounts up high on the targa band. I do not this to sound weird but, I have seen young guys in Japanese cars with super strobe flashers in their brake lights. Not sure if they are legal but they put out a great warning for a person that is on there phone or whatever. https://www.youtube.com/watch?v=2spW56EWNNA Bob B |
Cairo94507 |
May 4 2023, 11:52 AM
I have a 3rd brake light flasher module on my 6 and actually turned it off so it does not flash (plan on removing it one of these days entirely) because it flashed 6 times and was extremely annoying to anyone behind me. I would have been fine if it just flashed once and went solid and had a time delay function for sitting in stop and go traffic so it was not constantly flashing. (IMG:style_emoticons/default/beerchug.gif)
Spoke |
Jun 17 2023, 12:46 AM
Jerry Group: Members Posts: 7,076 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
@Steve
Steve, Getting closer to finishing your LEDs. Should have them ready for you in a week or so. Still working on the clips. These LEDs will be 2x as bright as the bulbs. Each bulb that was in the fixture I was sent burns over 8W for a total just less than 35W. Both LED boards burn a total of less than 3W. Attached image(s) |
Steve |
Jun 17 2023, 11:40 AM
914 Guru Group: Members Posts: 5,697 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
@Steve Steve, Getting closer to finishing your LEDs. Should have them ready for you in a week or so. Still working on the clips. These LEDs will be 2x as bright as the bulbs. Each bulb that was in the fixture I was sent burns over 8W for a total just less than 35W. Both LED boards burn a total of less than 3W. Awesome!! Thanks!! |
Steve |
Jun 17 2023, 04:08 PM
I just ordered the round rear spoke lights for my car. They looked really cool on Oscars car at the recent WCR event in Tahoe.
Spoke |
Sep 1 2023, 08:00 PM
@Steve Steve, Getting closer to finishing your LEDs. Should have them ready for you in a week or so. Still working on the clips. These LEDs will be 2x as bright as the bulbs. Each bulb that was in the fixture I was sent burns over 8W for a total just less than 35W. Both LED boards burn a total of less than 3W. @Steve Well it's been a bit more than a week but the 3rd brake lights will ship this weekend. Took a while to figure out how to connect the LEDs to the original bulb sockets. The bulbs have straight pins and doesn't really have a base so I just soldered 25Ga piano wire to push into the bulb sockets. The clips went through several iterations and now fit will with the boards. Here's the boards connected into the bulb sockets. Either socket could be used for connection. I'm not sure if the top hole is 12V or ground. You'll have to figure that on out. |
Spoke |
Sep 1 2023, 08:08 PM
The boards slide into the spacers.
The boards drop right into the fixture. The wires need to be tucked in out of the way. |
Spoke |
Sep 1 2023, 08:10 PM
All lit up.
The 4 bulbs together burn 2.5A at 14V which is 35W. The 2 LED boards together burn 0.195A at 14V which is 2.73W while being twice as bright as the bulbs. This kit will be priced at $40. |
Steve |
Sep 1 2023, 10:44 PM
Looks great!!
Cairo94507 |
Sep 2 2023, 08:42 AM
Another amazing option by Jerry. (IMG:style_emoticons/default/beerchug.gif)
Spoke |
Sep 2 2023, 02:17 PM
As I was preparing to ship the LEDs back to the original 944 owner I noticed the plastic lens fixture didn't sit flush.
On inspection I realized this ridge on the exterior piece was interfering with my supports. So I had to trim the edges of the supports to allow for the ridge. All is well now. |
Steve |
Sep 16 2023, 02:09 PM
Lo-Fi Version | Time is now: 28th October 2024 - 05:18 AM |
