orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,755 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
I also liked the writeup. They didn't go through a two paragraph generic history of the 914, the writeup we've all read 1000 times.
Paul |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
It is an absolutely beautiful car. I'd love to have it. |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
I thought the M471's came with wider rims? Those Fuchs could be stock to the 914, looks a little goofy.
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,734 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
The car was at the Amelia action but was on display only. Several years ago before these were half-million-dollar cars I thought the M471's came with wider rims? Those Fuchs could be stock to the 914, looks a little goofy. Clearly riding on narrower rims now than in the photo from a few years ago. |
Gustl |
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,540 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria ![]() ![]() |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,449 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
I thought the M471's came with wider rims? Those Fuchs could be stock to the 914, looks a little goofy. M471 cars originally came with 185/70 VR 15 on 6Jx15 Fuchs in combination with wheel spacers missing the spacers? agree with @Root_Werks - is goofy the way it is now. if your going to put the original size wheels and rubber back on you should at least go full pedant or go home? ![]() |
rgalla9146 |
There is (or was) a real M471 here in New Jersey that looked a bit scruffy, much like the silver one pictured. I saw it probably 15 years ago at a PCA event |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,106 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Not to be picky also, but on a half-million car..
I wouldn't expect to see a spot of rust anywhere.. Calipers should be redone to factory finish. chipped/flaked paint on the engine underside air baffles. Was the front suspension significantly different? The panel that protects the steerig rack and master cylinder doesn't look right; it only has 2 bolts. I agree, the rear wheels look 'lost' in the flares. Sadly, as a car that was originally sold specifically for racing, this one will spend the rest of it's life as a garage queen, only trotted out for shows. |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,121 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
Not to be picky also, but on a half-million car.. I wouldn't expect to see a spot of rust anywhere.. Calipers should be redone to factory finish. chipped/flaked paint on the engine underside air baffles. Was the front suspension significantly different? The panel that protects the steerig rack and master cylinder doesn't look right; it only has 2 bolts. I agree, the rear wheels look 'lost' in the flares. Sadly, as a car that was originally sold specifically for racing, this one will spend the rest of it's life as a garage queen, only trotted out for shows. I agree in general but rarity and desirability is everything. This car sold for $230k and i think i spy some rust lol Attached image(s) ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,441 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
QUOTE Sadly, as a car that was originally sold specifically for racing, this one will spend the rest of it's life as a garage queen, only trotted out for shows. Sold as a Body Mod... no other GT features. |
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
I thought the M471's came with wider rims? Those Fuchs could be stock to the 914, looks a little goofy. M471 cars originally came with 185/70 VR 15 on 6Jx15 Fuchs in combination with wheel spacers missing the spacers? agree with @Root_Werks - is goofy the way it is now. if your going to put the original size wheels and rubber back on you should at least go full pedant or go home? It looks like the current owner went with a narrower set of tires. The stock photo in the other link looks like a different tread pattern, with wider tires. Attached image(s) ![]() |
wonkipop |
Not to be picky also, but on a half-million car.. I wouldn't expect to see a spot of rust anywhere.. Calipers should be redone to factory finish. chipped/flaked paint on the engine underside air baffles. Was the front suspension significantly different? The panel that protects the steerig rack and master cylinder doesn't look right; it only has 2 bolts. I agree, the rear wheels look 'lost' in the flares. Sadly, as a car that was originally sold specifically for racing, this one will spend the rest of it's life as a garage queen, only trotted out for shows. I agree in general but rarity and desirability is everything. This car sold for $230k and i think i spy some rust lol that was 230,00 pesos (aus $) not greenbacks. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) approx 150K USD. sure was rusty though. saw that car. aussie rust but. (IMG:style_emoticons/default/beer.gif) some one did their maths on that one and figured out it was worth it. and it probably was. it was all there. rusty or not. there was profit in it. and income. there is a speedster down here. a right hand drive delivered. all original. and i mean original. its not restored apart from mechanical upkeep. beautifully faded. reportedly changed hands last at a mil aud. it never goes up for auction when it switches owners. i've seen it once or twice. some rich chinese dude owns it at present. nice enough guy. brings it out to coffee runs occasionally. no trailer queen. gets driven to its outings. |
Brian Fuerbach |
Member ![]() ![]() Group: Members Posts: 119 Joined: 1-July 19 From: Orange, Ca Member No.: 23,266 Region Association: Southern California ![]() |
Beautiful 914. Were sway bars part of the M471 package? The front sway bar appears not to be through body. Is this correct?
BillJ |
Not to be picky also, but on a half-million car.. I wouldn't expect to see a spot of rust anywhere.. Calipers should be redone to factory finish. chipped/flaked paint on the engine underside air baffles. Was the front suspension significantly different? The panel that protects the steerig rack and master cylinder doesn't look right; it only has 2 bolts. I agree, the rear wheels look 'lost' in the flares. Sadly, as a car that was originally sold specifically for racing, this one will spend the rest of it's life as a garage queen, only trotted out for shows. I agree in general but rarity and desirability is everything. This car sold for $230k and i think i spy some rust lol that was 230,00 pesos (aus $) not greenbacks. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) approx 150K USD. sure was rusty though. saw that car. aussie rust but. (IMG:style_emoticons/default/beer.gif) some one did their maths on that one and figured out it was worth it. and it probably was. it was all there. rusty or not. there was profit in it. and income. there is a speedster down here. a right hand drive delivered. all original. and i mean original. its not restored apart from mechanical upkeep. beautifully faded. reportedly changed hands last at a mil aud. it never goes up for auction when it switches owners. i've seen it once or twice. some rich chinese dude owns it at present. nice enough guy. brings it out to coffee runs occasionally. no trailer queen. gets driven to its outings. Strange. Article said Dollars https://www.motorious.com/articles/news/por...udicrous-price/ |
wonkipop |
Not to be picky also, but on a half-million car.. I wouldn't expect to see a spot of rust anywhere.. Calipers should be redone to factory finish. chipped/flaked paint on the engine underside air baffles. Was the front suspension significantly different? The panel that protects the steerig rack and master cylinder doesn't look right; it only has 2 bolts. I agree, the rear wheels look 'lost' in the flares. Sadly, as a car that was originally sold specifically for racing, this one will spend the rest of it's life as a garage queen, only trotted out for shows. I agree in general but rarity and desirability is everything. This car sold for $230k and i think i spy some rust lol that was 230,00 pesos (aus $) not greenbacks. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) approx 150K USD. sure was rusty though. saw that car. aussie rust but. (IMG:style_emoticons/default/beer.gif) some one did their maths on that one and figured out it was worth it. and it probably was. it was all there. rusty or not. there was profit in it. and income. there is a speedster down here. a right hand drive delivered. all original. and i mean original. its not restored apart from mechanical upkeep. beautifully faded. reportedly changed hands last at a mil aud. it never goes up for auction when it switches owners. i've seen it once or twice. some rich chinese dude owns it at present. nice enough guy. brings it out to coffee runs occasionally. no trailer queen. gets driven to its outings. Strange. Article said Dollars https://www.motorious.com/articles/news/por...udicrous-price/ you think you are the only country in the world with dollars? the government here calls it a dollar. the locals (me and others) refer to it as the peso (IMG:style_emoticons/default/biggrin.gif) . if you deploy your sense of humor you will understand the vernacular. its not even a bill anymore, its a coin. (IMG:style_emoticons/default/biggrin.gif) the paper notes were gorgeous. ![]() the oxidised 356 was sold here in aus at shannons. at an auction i attended. with aussie buyers. the auctioneer called it in a broad australian accent. the car is right hand drive. the article you probably read was an australian article. yes we are another country that has a currency called the..................dollar!!!!!! (IMG:style_emoticons/default/bootyshake.gif) it sold for 150 thou of your greenback dollars. there is a conversion rate you can access on google. if you think about it, given 356 values for certain cars etc thats probably about right. it will return a profit after restoration when its sold again. the $ in the end are the same, here or USA. there is a potential sale price for a finished restored car which dictates how much the chicken shed find wreck is worth. and just to upset your cultural supremacy even more! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) austalia was the first export market for porsches. we even beat you guys to it. check the history. there is a lot of very very very early 356s here. but no 914s. officially. except one special one. .......maybe. (IMG:style_emoticons/default/beer.gif) who knows. its all above my pay grade. ps if you look closely at the oxidised 356 you will notice lots of very special things about it. check the wheels. some other clues. and while aussies might whinge about the rust, its mostly surface oxidisation on that car, not your version of savage salt rust - terminal cancer. its more like a desert scorched car in your neck of the woods. (IMG:style_emoticons/default/beerchug.gif) but i'm going to agree with original poster. any one calling half a mil of gen-yu-whine greenbacks on a 914/6 - well you don't want to see any rust. esp bubbles under the paint. esp around the door handle area. |
BillJ |
Ok ok ok lol
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,389 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
The car was at the Amelia action but was on display only. http://www.914world.com/bbs2/index.php?showtopic=364166 https://rmsothebys.com/en/auctions/mo21/mon...46-m471/1131361 ( if you dont know that red car pictured by Steve above in the same picture was also Steve's M471 car and it also is back up for sale i believe in Europe) Phil SMG's M471 is not Red - it's Tangerine i knew than andwas going to correct that after i typed it but left it to see who would be first to correnct me, you win (IMG:style_emoticons/default/laugh.gif) It was too easy for me as SMG's car has been at my house, in my garage, I R&R the engine, etc. I also bought the seats that came with the car to Steve ( he replaced with Factory seats) ![]() ![]() ![]() |
BillJ |
Really love those seats with pepita. Sooooooo nice. If i ever convert back to street car that is what will go in.
Root_Werks |
Agree with others, don't like being picky on such a beautiful 914, but for $500k+, you'd think the trim around the radio would be tucked in correctly. The screws on the gauge bezel would be painted and not look like they were removed with an incorrect Phillip's driver etc.
I see it so much, $50k paint job, lots of parts replaced, looks like a new car until you get closer. This 914 would never pass the 356 guys sniff test. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
I saw my car at Amelia and was sad at how down hill it had gone since I owned it, people trying to do things they should not have, rough treatment, and everything everyone else has mentioned.
I actually used to run that car at road atlanta, so installed factory 16 front and 15 rear sway bars and seven and 8 fuchs with the correct 21mm wheel spacers even though it came with sixes. So as one comment back then, it was a "resto mod" for example I LIKED the black headlight surrounds!!!! Somethng happened to the right seat cushion and a poor job done in restitching, they tried to do someting to the paint and it had some kind of a reaction in some areas. |
Lo-Fi Version | Time is now: 29th June 2024 - 05:47 PM |
