Super penetrating oil |
blabla914 |
May 3 2023, 05:44 PM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
Help. Two STUCK studs. Used heat, special Collette tool, impact wrench and tapping. 3 days still no luck. Ideas?.. What are the studs in? If they are head studs I've always found it hard to put enough heat on a head stud. I mean the head is designed to dissipate heat right? I've only had luck with acetylene or welding a nut right onto the stud. If you are using a MIG setup for sheet metal with like 0.023 wire you need to really crank it up. Do it along with copious amounts of penetrating oil. Have plenty of ventilation and be prepared for some fires. Plan on a mess. Good Luck Kelly |
brant |
May 3 2023, 05:53 PM
914 Wizard Group: Members Posts: 11,646 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Recently pulled a Jeep 4.0 head that was cooked and nasty
Nothing would budge them Until my neighbor taught me a trick TIG machine No filler or tungsten Hold the torch on the top of the stud until the stud glows red All of the heat is concentrated on the stud They all came out after this. Easily |
sixaddict |
May 3 2023, 07:53 PM
Senior Member Group: Members Posts: 815 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Recently pulled a Jeep 4.0 head that was cooked and nasty Nothing would budge them Until my neighbor taught me a trick TIG machine No filler or tungsten Hold the torch on the top of the stud until the stud glows red All of the heat is concentrated on the stud They all came out after this. Easily |
sixaddict |
May 3 2023, 07:54 PM
10-4
Worth a shot Recently pulled a Jeep 4.0 head that was cooked and nasty Nothing would budge them Until my neighbor taught me a trick TIG machine No filler or tungsten Hold the torch on the top of the stud until the stud glows red All of the heat is concentrated on the stud They all came out after this. Easily |
sixaddict |
May 4 2023, 06:46 AM
Finally got them…very last one broke…. (IMG:style_emoticons/default/headbang.gif)
I’m sure machine shop will be able to get what’s left out. |
DennisV |
May 4 2023, 07:52 AM
Senior Member Group: Members Posts: 501 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
TIG machine No filler or tungsten Hold the torch on the top of the stud until the stud glows red All of the heat is concentrated on the stud They all came out after this. Easily Interesting! learn something new every day... (IMG:style_emoticons/default/welder.gif) |
930cabman |
May 4 2023, 07:58 AM
Advanced Member Group: Members Posts: 3,236 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
TIG machine No filler or tungsten Hold the torch on the top of the stud until the stud glows red All of the heat is concentrated on the stud They all came out after this. Easily Interesting! learn something new every day... (IMG:style_emoticons/default/welder.gif) I have also found heat to be the best at loosening rusted/stuck threaded fasteners. Thanks for the great TIG tip |
Lo-Fi Version | Time is now: 2nd July 2024 - 06:39 PM |
