930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,891 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Repairing a hell hole and neighboring area I have opened up the longitudinal to discover quite a bit of rusting/debris. I would say when scraped and vacuumed out it's about a cup full. How crazy do we need to go with this?
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,136 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
vacuum and blow and make sure that a pick will not penetrate the structure, meaning you have good solid metal. We are currently doing one in our shop and have at least 200 pictures of the work, we do this all of the time, but nothing like fresh work
Repairing a hell hole and neighboring area I have opened up the longitudinal to discover quite a bit of rusting/debris. I would say when scraped and vacuumed out it's about a cup full. How crazy do we need to go with this? ![]() |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,774 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
That portion of metal (1 cup) is a portion of structural metal that is gone from the car. Chances are where that came from is not really healthy (since it already was loosing metal/rust). (IMG:style_emoticons/default/sad.gif)
Post #111 show what I discovered between the layers after seeing something suspicious from the inside... I believe you commented on it. http://www.914world.com/bbs2/index.php?s=&...t&p=3072935 I hate to see what I am seeing and your situation might be different, but at this point I see no other option than digging more and replace all bad metal for good solid one. (IMG:style_emoticons/default/headbang.gif) I hope yours is better. (IMG:style_emoticons/default/beerchug.gif) |
930cabman |
Agreed, the cup full of debris was once structural. I do not feel it's too bad and may clean the open up another inspection hole for additional information.
Lo-Fi Version | Time is now: 13th February 2025 - 02:29 AM |
