BODY ROLL, What to do |
wjpierce |
May 15 2023, 07:56 AM
Newbie Group: Members Posts: 15 Joined: 2-December 07 From: Lompoc, ca Member No.: 8,407 |
Hello 914World.
I recently purchased a '74 914 racer and had it on track at Buttonwillow raceway last weekend. There were issues in that the car was last raced in 2014 but these were overcome. Here is the major problem with the car. Body roll. Transitioning from a right to left turn requires neutralizing the car mid cormer and then allowing it to set. If that isn't done, the car wants to break loose when it sets into the next turn. I don't have a rear sway bar on the car and that is the first order of business but it seems impossible to me that a sway bar could overcome this much roll by itself. I was thinking of trying coilover shocks to help with this. This might also allow us to corner weight the car. What are your thoughts on this. Any other strategies that have worked for others with 914 racers? I appreciate your input. Bill Pierce |
stownsen914 |
May 15 2023, 10:43 AM
Senior Member Group: Members Posts: 930 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
From what you describe, it sounds like something is loose somewhere. Or you have a deteriorating bushing somewhere in your suspension - could be rubber or poly, I've seen both wear out / break apart. Many times the "taking a set" and wanting to break loose is the result of having to take up slack from looseness. It's called snap oversteer when this happens. It can be scary to drive a car that has this issue. A few things to look at - you can jack the car to get each corner off the ground and give the wheel or suspension a good shake as a first test.
Worn bushings on swaybar droplinks (or something loose) Side to side slack in front swaybar (make sure the droplinks are pressed up against the bushings, or even better have a clamp on the car just inboard of where the bushings mount to the body) Worn bushings in front suspension (or something loose) Worn bushings in rear suspension (or something loose) Another possibility is the car is set up too stiff in the rear, springs and/or swaybar, or alignment is way off, causing the car to oversteer. It's different than what I describe above, but can feel similar - the rear will feel "loose." Tell us about your suspension setup, including torsion bar and swaybar sizes, shocks, and rear spring rates. Those things tell much of the story. Also alignment specs. |
Matt Romanowski |
May 15 2023, 11:39 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
We need all the details on your setup. What size torsion bars, what shocks, what spring in the rear, rear springs, ride height, alingment, etc.
I think Scott might be on a good path with something being worn/loose. Dynamic rear toe (worn bushings) makes for a very lively car. |
slivel |
May 15 2023, 12:26 PM
Old car....... older driver Group: Members Posts: 514 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
We need all the details on your setup. What size torsion bars, what shocks, what spring in the rear, rear springs, ride height, alingment, etc. I think Scott might be on a good path with something being worn/loose. Dynamic rear toe (worn bushings) makes for a very lively car. x100 on the dynamic rear tow comment. I like a car to be sprung correctly and fine tune the handling with sway bar and tire pressure adjustment. |
brant |
May 15 2023, 01:25 PM
914 Wizard Group: Members Posts: 11,793 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
What diameter is the current front anti sway bar?
That would be my first suspension change if nothing is broken or worn out in the bushings and the bar is stock. What weight are your rear coil over springs currently? Also a first address type of issue if they are street springs currently Front coil overs are not necessary for corner balance. Rear adjustable coil overs are. (But the stock is already a coil over… not adjustable) So I wasn’t clear which end of the car you were referencing |
wjpierce |
May 15 2023, 11:23 PM
Thanks everybody. I've obviously got a lot of homework and examination of the car to do. It is currently at a race shop elsewhere so I will gather all of the data and report back. I appreciate the feedback. The car has not been on track since 2014 and several other rubber (and metal) parts showed their age and wear. I'll get back when I can answer your questions. Thanks again. Bill
infraredcalvin |
May 15 2023, 11:25 PM
Distracted Member Group: Members Posts: 1,570 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
In addition to current setup (and pics of course). What’s your level of experience? If it’s the same car in your avatar, I think I remember this car from older posts.
yeahmag |
May 16 2023, 02:38 PM
Advanced Member Group: Members Posts: 2,442 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
All the requests for more info are definitely on target. One thing I would keep in mind is that car feel is almost as important as any other parameter. Don't be afraid to play with out of the box spring rates and the like to see what feels good to you. My setup for autocross is radically different than most others and the car is a proven winner.
sixaddict |
May 19 2023, 09:36 AM
Senior Member Group: Members Posts: 862 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
I have never used a rear bar…..and don’t believe one is needed. A 100 years ago, I had a torsion bar fail…….I could always feel it ahead of the terminal oversteer (autocrossing bc it was a guaranteed spin).
Changed them out and it was fixed….. |
brant |
May 19 2023, 09:47 AM
I run an aftermarket (larger diameter) rear bar with adjustable drop links
Really like it although I don’t run it very tight The problem becomes the need for a limited slip I Like street cars with stock bars also But driver style probably plays a role in rear bar applications |
wjpierce |
Jun 10 2023, 09:43 PM
I have the information many have requested.
The car has: Turbo tie rods 23 mm front torsion bars Bilstein shocks/ struts with 225 lb. rear springs 19mm front sway bar Purchased, but not installed 16mm Weltmeister sway bar Toyo R888r tires I have heard the concern about the need for a limited slip diff with the addition of the rear sway bar but hopefully I won't unload a corner sufficiently to lose traction Any other advice? Thanks, everybody. Bill Pierce |
brilliantrot |
Jun 11 2023, 04:57 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
The 914 Aaron (yeahmag) has and I autocross seems to be pretty happy with the same setup except we have gone to 550lb-in rear springs to keep out of the bump stops on the rear shocks. We have since upgraded to some fancy Penske shocks that might allow us to drop down to a 450lb-in spring and add some compression valving to help keep it off the bump stops but running low, on Hoosier with data showing we have sustained 1.3G with peaks to 1.7G, and low friction bearing’s trailing arm pivots, we need a LOT of rear spring.
wjpierce |
Jun 12 2023, 08:22 AM
Thank you. I was thinking that heavier springs would help as well. Our next outing is Willow Springs and I'm going to try the sway bar but I think I'll also buy some springs if the car still rolls like it does. I am coming from a formula car and perhaps my expectations are unrealistic. Severe direction changes require treating the change as if there are two turns. One to settle the car and another to negotiate the turn. Simply changing direction rapidly will certainly cause the car to spin unless I sort of make it neutral as I change direction. I am explaining this badly, but perhaps you know what I mean. I am certain that setting the car is really allowing it to settle on the stops.
Thanks again, for your feedback. |
stownsen914 |
Jun 12 2023, 03:34 PM
What you are describing is the car "taking a set" i.e. loading the suspension in preparation for navigating a turn. Ideally the car should exhibit the same attitude as the transition happens. Sounds like yours isn't. Lots of reasons it could happen, including the looseness / snap oversteer I mentioned in the earlier post.
Can't remember if I mentioned, but is there a possibility your rear shocks are hitting the bump stops? If so and it's the stock rubber type, that can ruin handling in a hurry. As for stiffening the rear springs, if you are looking to dial out oversteer tendencies, going to stiffer rear springs is almost certainly the wrong answer. Going stiffer in the rear (springs or swaybar) will promote oversteer, not reduce it. |
brilliantrot |
Jun 12 2023, 04:44 PM
Can't remember if I mentioned, but is there a possibility your rear shocks are hitting the bump stops? If so and it's the stock rubber type, that can ruin handling in a hurry. As for stiffening the rear springs, if you are looking to dial out oversteer tendencies, going to stiffer rear springs is almost certainly the wrong answer. Going stiffer in the rear (springs or swaybar) will promote oversteer, not reduce it. I think he is hitting the bump stops, we fought the same issue for a long time with 225lb-in rear springs. Car was nice and balanced until you really got aggressive with it on turn in and the rear would instantly go to snap oversteer after a slow weight transfer as we were hitting the bump stops. The rear roll center on lowered cars seems to be so low there is almost a digressive affect to the spring rate. In any case, the car has only gotten easier to drive and better behaved after doubling the rear spring rate. You can hold it in a controlled power slide drift if you want which I was never able to do in my 914. |
campbellcj |
Jun 13 2023, 10:23 AM
I can't Re Member Group: Members Posts: 4,587 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I went from 200's or 225's to 350's along with revalved Bilsteins and the car behaves way better. Has 22mm hollow t-bars and F+R swaybars.
yeahmag |
Jun 13 2023, 12:13 PM
What Evan said... It seems counter productive, but it needs to stay off the bump stops. Running a small o-ring or ziptie on the shock can give you valuable information. Even with 300lb springs were were burying the tell tail. Quick transitions are effortless now. Car still will take a nice set in a long turn and most importantly for Evan, will drift all day long ;-)
brilliantrot |
Jun 13 2023, 09:44 PM
Brett W |
Jun 18 2023, 10:24 AM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Here is the major problem with the car. Body roll. Transitioning from a right to left turn requires neutralizing the car mid cormer and then allowing it to set. Need to address the shock valving. All of what you are describing occurs in the phase of cornering most affected by the dampers. I have to bet the dampers either are street dampers or are valved for comfort more than racing. Get those dampers out and have them valved by someone who understands race dampers. |
Lo-Fi Version | Time is now: 21st November 2024 - 07:55 PM |
