Mysterious Plug, What's black and red and hides under carpet? |
DennisV |
Jun 2 2023, 06:03 PM
Senior Member Group: Members Posts: 551 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Am I correct in assuming that this has no business in a 1970 914-6? There was nothing attached to the plug which was near the base of the shifter. It looks homemade, with a fuse inline.
I tried finding a color wiring diagram for a 914-6. I kicked up a few names in searches, but none of them replied to me about buying one. |
DennisV |
Jun 2 2023, 07:04 PM
Also, this brown wire white stripe was found near the tunnel. I'm thinking that this is for the handbrake switch and just incorrectly located?
Superhawk996 |
Jun 2 2023, 07:12 PM
914 Guru Group: Members Posts: 6,533 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
FWIW Restoration Deaign used to offer a full size 914/6 wiring diagram - maybe 3’ x 5’ in size. Wall size.
@peteyd |
windforfun |
Jun 2 2023, 07:16 PM
Senior Member Group: Members Posts: 1,985 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Neither one is stock. It's a DAPO thing.
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
peteyd |
Jun 6 2023, 11:01 AM
Senior Member Group: Members Posts: 730 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Neither one is stock. It's a DAPO thing. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Wrong... the brown/white on the tunnel is most likely the fan switch. Cavity 9 on 14 pin connector that plugs into the relay panel in the engine bay the inline fuse is an addition from a previous owner. Please give informed advice. Pete |
windforfun |
Jun 6 2023, 05:47 PM
Neither one is stock. It's a DAPO thing. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) Wrong... the brown/white on the tunnel is most likely the fan switch. Cavity 9 on 14 pin connector that plugs into the relay panel in the engine bay the inline fuse is an addition from a previous owner. Please give informed advice. Pete Only half wrong. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
DennisV |
Jun 7 2023, 07:13 AM
the brown/white on the tunnel is most likely the fan switch. Cavity 9 on 14 pin connector that plugs into the relay panel in the engine bay the inline fuse is an addition from a previous owner. Please give informed advice. Thank you for chiming in Pete. Where is that spade connector meant to attach? I'm not seeing an obvious mate for it. I assume it's opposite end is running to the position you reference in the engine bay. |
sixnotfour |
Jun 7 2023, 03:06 PM
914 Wizard Group: Members Posts: 10,643 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Sportamatic shifter, Brn wht
windforfun |
Jun 7 2023, 03:18 PM
Perhaps this is more informed advice.
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
sixnotfour |
Jun 7 2023, 06:04 PM
Now you are wrong.. Twice..
DennisV |
Jun 8 2023, 08:27 AM
windforfun |
Jun 8 2023, 09:09 AM
Okay, I surrender. That wire is for the bulb in the defrost indicator.
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 28th November 2024 - 12:37 AM |
