18 Pages V « < 12 13 14 15 16 > »
> Contracted 914 fever— is this the car to cure it?, What do you think of this ‘73 914 2.0 on Bat— pass or play?
Gint
post Dec 29 2023, 12:21 PM
Post #261
Mike Ginter
QUOTE(trylon @ Aug 15 2023, 07:25 PM) *
QUOTE(Porschef @ Aug 15 2023, 03:53 PM) *
Very pretty, congratulations! (IMG:style_emoticons/default/beerchug.gif)
Did you happen to have a look at the red ‘76?
Never made it— the seller has set aside a single day for visitation and it has yet to arrive.
You were probably better off with a car that spent a majority of its life out west anyway.
I've been reading through your thread backwards.
Great looking 914!
trylon
post Dec 30 2023, 08:31 AM
Post #262
QUOTE(Gint @ Dec 29 2023, 01:21 PM) *
Great looking 914!
Thanks for all the input Gint!
trylon
post Jan 8 2024, 03:27 PM
Post #263
Still havin’ horn fun!
Put them back on to their wiring and gave the horn button a press— nothing.
So I pulled the horn relay and tested it in the headlight motor— works.
Went to put it back and the horns sounded when I just touched the relay to its input holes! Startled me. Tried again and nothing this time, not even when I press the horn button. Thought I might have blown the relay somehow, tested it with 12v and its clicks as expected.
Intermittent wonkiness possible?
Just had the thought that I should put the headlight motor one into the horn relay spot and see what happens…
Attached ImageAttached Image
trylon
post Jan 29 2024, 02:38 PM
Post #264
What a transformation!
930cabman
post Jan 29 2024, 05:45 PM
Post #265
QUOTE(trylon @ Jan 29 2024, 03:38 PM) *
What a great restoration, I would sure like a set of these on my ride.
Is this a DIY?
TRS63
post Jan 30 2024, 02:27 AM
Post #266
Region Association: Europe
Wow, awesome work on the Fuchs!
Bests
Antoine
trylon
post Jan 30 2024, 08:47 AM
Post #267
Let me hasten to add that I had no more to do with this restoration than doling out the cash.
All credit goes to Ed at https://www.fuchsrestoration.com/
trylon
post Feb 1 2024, 08:25 AM
Post #268
Tale of my road to the 914 up on BAT:
https://bringatrailer.com/2024/02/01/bat-au...ive-revelation/
rhodyguy
post Feb 1 2024, 09:18 AM
Post #269
Is the wire on the horn pad securely fastened?
trylon
post Feb 1 2024, 10:09 AM
Post #270
QUOTE(rhodyguy @ Feb 1 2024, 10:18 AM) *
Going there next… thanks!
trylon
post Feb 8 2024, 11:15 AM
Post #271
Ok, pulled the horn button. Detached, taped ground wire. Worn cup. Non-conductive washers incorrectly placed so that horn would always be grounded. So that and corroded points in each horn were the culprits as now if the ground wire is grounded, the horn sounds.
Ordered a new cup to complete the job. Safety increasing— LED headlights and working horn. Drivers side seat belt next.
Attached Image Attached ImageAttached ImageAttached Image
trylon
post Feb 11 2024, 08:32 AM
Post #272
Hahaha— failed at trying to lube a sticky belt!
NOS on order…
trylon
post Feb 12 2024, 02:07 PM
Post #273
Soon to be back on all fours!
930cabman
post Feb 12 2024, 03:17 PM
Post #274
New sneakers are always a + (IMG:style_emoticons/default/beerchug.gif)
emerygt350
post Feb 12 2024, 04:27 PM
Post #275
Love how those wheels turned out.
wonkipop
post Feb 13 2024, 02:06 AM
Post #276
QUOTE(trylon @ Feb 12 2024, 02:07 PM) *
top shelf. beyond beer. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer.gif)
take the glaze off those and chuck it into a few corners and report back, (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/biggrin.gif)
trylon
post Feb 18 2024, 12:36 PM
Post #277
QUOTE(wonkipop @ Feb 13 2024, 03:06 AM) *
Looking forward to doing just that!
But ‘tis the season for repairing. Having at making it safer for all the Porsche fun I can muster this year.
I will then, with face flushed and heart racing, give with all the delicious driving details— Stay Tuned!
trylon
post Feb 20 2024, 05:13 PM
Post #278
https://cvrpca.com/event/apr-20-lake-waramaug-coffee-run/
Organized a coffee run!
Porschef
post Feb 21 2024, 01:24 PM
Post #279
How you doin'
emerygt350
post Feb 21 2024, 01:32 PM
Post #280
I actually rewound a seatbelt after that. Worked just as well as when I let the magic winds out. Ended up buying new ones before track day last July. Good investment. Not that expensive, and much safer.
- Lo-Fi Version Time is now: 15th November 2024 - 05:16 AM
