SOLD- '87 3.2 Carrera Motor, 9K miles on rebuild |
Steve |
Nov 20 2023, 08:53 AM
914 Guru Group: Members Posts: 5,728 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
<b>@Cairo94507 </b> GLWTS Michael! Regarding a 3.6l 914/6 build: you might wanna consider including a light weight flywheel in the build. Assuming gearing isn’t too tall, the 3.6l’s abundance of torque in a 914 will make starting from a dead stop a snap. Plus a low inertia flywheel will sharpen engine response as well as improve acceleration. Please keep us updated I'd disagree. Reason being the 914 is too light for the motor. The gas pedal would be sensitive. Same issue with high compression V8s. Think EV with regen. You’re certainly entitled to your opinion. Mine’s based on the ERA 427 Cobra I built with 550 hp / 550 lb-ft that weighed 2600lbs, and a light weight flywheel, clutch & pressure plate. Throttle response was great; not too sensitive or difficult to modulate. When I posed the question here whether a light flywheel would be appropriate for my 2.7L RS powered 914/6, I was told by owners of 914’s with similar drivetrains it’s a good fit. With this much hp, first is worthless and you start off in second. Using second its easy to modulate the hp. I rode in Sir Andy's car with a 3.6, it was very controllable starting out in second. I am also pushing close to 400 hp with my SBC 914. Starting off in second is very controllable. I can lay rubber down the street in second without it fish tailing. The biggest issue with the 3.6 is the light flywheel can cause the engine to die if you let off the gas at a semi high rpm. Steve Wong's chip for the 3.6 has a fix for this in his chip. |
Cairo94507 |
Nov 30 2023, 10:26 AM
Michael Group: Members Posts: 10,095 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I was hoping to have my 3.2 out of the car by now but have had a bad cold for a while and it has kept me from doing almost anything. I am hoping to get this 3.2 out before Christmas. (IMG:style_emoticons/default/beerchug.gif)
Chris914n6 |
Dec 2 2023, 02:10 PM
Jackstands are my life. Group: Members Posts: 3,413 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
<b>@Cairo94507 </b> GLWTS Michael! Regarding a 3.6l 914/6 build: you might wanna consider including a light weight flywheel in the build. Assuming gearing isn’t too tall, the 3.6l’s abundance of torque in a 914 will make starting from a dead stop a snap. Plus a low inertia flywheel will sharpen engine response as well as improve acceleration. Please keep us updated I'd disagree. Reason being the 914 is too light for the motor. The gas pedal would be sensitive. Same issue with high compression V8s. Think EV with regen. You’re certainly entitled to your opinion. Mine’s based on the ERA 427 Cobra I built with 550 hp / 550 lb-ft that weighed 2600lbs, and a light weight flywheel, clutch & pressure plate. Throttle response was great; not too sensitive or difficult to modulate. When I posed the question here whether a light flywheel would be appropriate for my 2.7L RS powered 914/6, I was told by owners of 914’s with similar drivetrains it’s a good fit. Drivers bias. Go for a spin as a passenger... I found it to be a pain in the neck (IMG:style_emoticons/default/aktion035.gif) |
Cairo94507 |
Dec 13 2023, 03:41 PM
Christmas is coming...doesn't your 914 need a nice 3.2 motor? (IMG:style_emoticons/default/beerchug.gif)
Cairo94507 |
Dec 18 2023, 10:28 AM
BTTT
Cairo94507 |
Jan 2 2024, 07:55 AM
Yup- still available. Jesus, I gotta get this 3.2 out of my car soon. (IMG:style_emoticons/default/beerchug.gif)
Cairo94507 |
Jan 22 2024, 05:22 PM
Seriously hoping my 3.2 will be out in 2 weeks.... I got RSV and it knocked me for a loop, then I got better and then... I got RSV again! WTF?? Anyway, seem to be over that mess now and my wife says I can play in the garage starting the 27th.... we shall see. (IMG:style_emoticons/default/beerchug.gif)
Cairo94507 |
Feb 6 2024, 04:44 PM
My 3.2 is sold. Now I guess I really have to get her out of the car. The most excellent news is it is going into another 914! Yay. (IMG:style_emoticons/default/beerchug.gif)
Freezin 914 |
Feb 6 2024, 04:48 PM
Senior Member Group: Members Posts: 925 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
My 3.2 is sold. Now I guess I really have to get her out of the car. The most excellent news is it is going into another 914! Yay. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) Congratulations! Can’t wait to see the next chapter of your beautiful car! |
burton73 |
Feb 6 2024, 05:07 PM
burton73 Group: Members Posts: 3,676 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Way to go buddy, he is getting a very special Eng,
Best Bob B (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) |
Cairo94507 |
Feb 6 2024, 05:17 PM
Thanks guys. It is a great motor and has always run great. I am really glad it is going into another 914. I will photo everything before we disconnect it from my car and label everything so it should be a pretty straight forward install for the new owner. (IMG:style_emoticons/default/beerchug.gif)
Feb 6 2024, 05:58 PM
914-6 GT in waiting Group: Members Posts: 19,597 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Win win for buyer and seller.
Lo-Fi Version | Time is now: 25th November 2024 - 05:18 PM |
