Alfa Calipers |
Alfa Calipers |
PatMc |
Sep 30 2023, 07:43 PM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Good update on rear calipers. I found these among my random collection but have no idea what they are from. Could be VW, Audi, 356, 911 or ? They're ATEs with 38mm pistons and are suitable for vented rotors. The spacers in them are as manufactured. These are a good match for alloy S fronts. They mount on our trailing arms and with a fat washer are near perfectly centered. They are left and right with the bleeder at the top and the hard plumbing to the bottom. The take 60mm pads, same as 914 6 rears. I guess no alloy rears for me. Anyone know what they are ? (IMG:style_emoticons/default/confused24.gif) Standard 911 rears from 69-83. The early ones had a machined spacer, later went a cast spacer. |
mb911 |
Oct 1 2023, 06:20 AM
914 Guru Group: Members Posts: 7,385 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Next mystery. I've had these 911(what year ?) 944 (?) ebrake parts for years thinking they might come in handy. Thing is, they seem different from any others that I've seen used in a 914 conversion. The shoes are wider and the retainers are flat spring steel. See photos. The shoes are wider than the contact area of my 911 vented rotors so ~1/8" of the shoe hangs outside the drum, so not compatible. (IMG:style_emoticons/default/sad.gif) The intesting part of these is the stop for the bottom of the shoes is incorporated in the backing plate. Maybe this feature can be added to the more compatible 911 ebrake parts. What years of 911 parts are best for this conversion ? Well mine was a clusterF$&@. I would not suggest to anyone. It works fine but what a PIA. You need 69-73 parts and the best part is you get to modify the bracket out of them. Had to have a machinest machine down the brake shoes. In the end I was super irritated with the process. Parts are very hard to find |
Oct 1 2023, 07:00 AM
914-6 GT in waiting Group: Members Posts: 19,671 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Next mystery. I've had these 911(what year ?) 944 (?) ebrake parts for years thinking they might come in handy. Thing is, they seem different from any others that I've seen used in a 914 conversion. The shoes are wider and the retainers are flat spring steel. See photos. The shoes are wider than the contact area of my 911 vented rotors so ~1/8" of the shoe hangs outside the drum, so not compatible. (IMG:style_emoticons/default/sad.gif) The intesting part of these is the stop for the bottom of the shoes is incorporated in the backing plate. Maybe this feature can be added to the more compatible 911 ebrake parts. What years of 911 parts are best for this conversion ? Well mine was a clusterF$&@. I would not suggest to anyone. It works fine but what a PIA. You need 69-73 parts and the best part is you get to modify the bracket out of them. Had to have a machinest machine down the brake shoes. In the end I was super irritated with the process. Parts are very hard to find I gave you the cores. I wonder if they were the wrong year to work with or 944 brakes or something. When Scott did mine on the Suby car, he didn't have the issues. I don't know what year brakes I gave him. |
rgalla9146 |
Oct 1 2023, 09:38 AM
Advanced Member Group: Members Posts: 4,673 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Next mystery. I've had these 911(what year ?) 944 (?) ebrake parts for years thinking they might come in handy. Thing is, they seem different from any others that I've seen used in a 914 conversion. The shoes are wider and the retainers are flat spring steel. See photos. The shoes are wider than the contact area of my 911 vented rotors so ~1/8" of the shoe hangs outside the drum, so not compatible. (IMG:style_emoticons/default/sad.gif) The intesting part of these is the stop for the bottom of the shoes is incorporated in the backing plate. Maybe this feature can be added to the more compatible 911 ebrake parts. What years of 911 parts are best for this conversion ? Well mine was a clusterF$&@. I would not suggest to anyone. It works fine but what a PIA. You need 69-73 parts and the best part is you get to modify the bracket out of them. Had to have a machinest machine down the brake shoes. In the end I was super irritated with the process. Parts are very hard to find I've got the caliper part pf the project covered. Years ago I parted out an '83 SC. That's where the mystery calipers (and my engine) came from. Early in this thread Mark Epstein suggested 911 rears might be the ticket and to ask Eric Shea... Doh ! I think the 911 ebrake parts are difficult to get because breakers want to sell the trailing arms as a complete assembly. That's my next challenge. |
mate914 |
Oct 1 2023, 12:00 PM
Matt Group: Members Posts: 802 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Am I going to have to take my brakes apart and take pictures? I have the Alfa calipers and the early emergency brakes setup with tangerine racing adapter kit.
@rgalla9146 Matt |
rgalla9146 |
Oct 1 2023, 12:21 PM
Am I going to have to take my brakes apart and take pictures? I have the Alfa calipers and the early emergency brakes setup with tangerine racing adapter kit. @rgalla9146 Matt Hey Matt NO,NO,NO ! I'm making good progress and love the process. Working out issues like this is therapeutic. I like to solve a problem step by step. Rory |
mb911 |
Oct 1 2023, 06:07 PM
Next mystery. I've had these 911(what year ?) 944 (?) ebrake parts for years thinking they might come in handy. Thing is, they seem different from any others that I've seen used in a 914 conversion. The shoes are wider and the retainers are flat spring steel. See photos. The shoes are wider than the contact area of my 911 vented rotors so ~1/8" of the shoe hangs outside the drum, so not compatible. (IMG:style_emoticons/default/sad.gif) The intesting part of these is the stop for the bottom of the shoes is incorporated in the backing plate. Maybe this feature can be added to the more compatible 911 ebrake parts. What years of 911 parts are best for this conversion ? Well mine was a clusterF$&@. I would not suggest to anyone. It works fine but what a PIA. You need 69-73 parts and the best part is you get to modify the bracket out of them. Had to have a machinest machine down the brake shoes. In the end I was super irritated with the process. Parts are very hard to find I gave you the cores. I wonder if they were the wrong year to work with or 944 brakes or something. When Scott did mine on the Suby car, he didn't have the issues. I don't know what year brakes I gave him. Mark Calipers, stubs and hubs were awesome. The rest was a major learning curve with a bunch of trial and fitting then machining, then fitting, then matching. None of that was your fault. The problem is not many of these parts have actual part numbers on them so you going off pictures and descriptions. |
mb911 |
Oct 1 2023, 06:13 PM
Luke M |
Oct 2 2023, 07:54 AM
Senior Member Group: Members Posts: 1,400 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Next mystery. I've had these 911(what year ?) 944 (?) ebrake parts for years thinking they might come in handy. Thing is, they seem different from any others that I've seen used in a 914 conversion. The shoes are wider and the retainers are flat spring steel. See photos. The shoes are wider than the contact area of my 911 vented rotors so ~1/8" of the shoe hangs outside the drum, so not compatible. (IMG:style_emoticons/default/sad.gif) The intesting part of these is the stop for the bottom of the shoes is incorporated in the backing plate. Maybe this feature can be added to the more compatible 911 ebrake parts. What years of 911 parts are best for this conversion ? Well mine was a clusterF$&@. I would not suggest to anyone. It works fine but what a PIA. You need 69-73 parts and the best part is you get to modify the bracket out of them. Had to have a machinest machine down the brake shoes. In the end I was super irritated with the process. Parts are very hard to find I've got the caliper part pf the project covered. Years ago I parted out an '83 SC. That's where the mystery calipers (and my engine) came from. Early in this thread Mark Epstein suggested 911 rears might be the ticket and to ask Eric Shea... Doh ! I think the 911 ebrake parts are difficult to get because breakers want to sell the trailing arms as a complete assembly. That's my next challenge. Hi Rory, So here's the issues that I ran into while doing this mod. You need to make sure you get the correct e-brake shoes for the early (70-73) e-brake backing plates. Yes, there's a few different ones out there. I purchased two new sets and both where wrong. The e-brake shoes are too long so they do not fit under the SC/early 911 vented rotors. I'll have to find the part # which worked and post it here for you. I believe I got the correct set from Stoddard. You can buy just the backing plates used and the new hardware kit from PP or Stoddard. You'll have to grind down the control arm mounting plate bosses a little so the backing plates fits. I also installed a tube through the control arm so I can remove the Boxster caliper pad pin. If you look at Andy's thread he modified the pin to install/remove it. Then you'll need to add a pad plate(it's what I call it) basically a 90 degree angle iron with a hole in the middle of it. It's used to support the e-brake shoes at one end. The Tangerines kit has those pieces included (pic attached of that). Then you'll need to relocate the factory E-brake cable bracket on the control arm. You'll cut it off and move it to a more straight/inline position to attach to the new e-brake setup. I'll post pics/info on here as I find them. You've got my # if you need to give me a call on it. Attached image(s) |
Luke M |
Oct 2 2023, 09:46 AM
Here's the e-brake pad and hardware info. The hardware is sold as a complete set. Take a look at the shoes. Pay real close attention to the angle at the upper end. The new pad will not work and needs to be like the old pad. The new pads are a little large in OD once installed which makes installing the rotor impossible. That was the case at my end. Spoke with a guy at Stoddard and he knew exactly what I was talking about. So this must be an issue with some of the pads being made. This was about 6 months ago so not sure if the issue has been resolved with the manufacturer.
Lo-Fi Version | Time is now: 2nd January 2025 - 10:38 PM |
