SOLD Fresh NEW 1.9L Long Block & Misc Motor Parts |
euro911 |
Nov 4 2023, 04:17 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Here's the motor info:
It was originally a 1.7L F.I. that Richard (Type-4-Unleashed) and I rebuilt into a 1.9L (1911cc) a few years ago. All machining work was performed at EMW. It's currently a long block and will need the F.I. components (or carbs), tins and misc tid-bits put back on it. Total fresh rebuild with new 66mm crank, new rods, new bearings, new camshaft, Keith Black 96mm pistons & barrels, new stainless steel valves with new guides, new chromoly push rods, new cam followers, and new 911 swivel-foot adjusters. The entire rotating assembly was balanced, including the crank pulley/pulley and resurfaced flywheel. The fan housing with the flaps and a 50 Amp alternator are included, as well as the tins (that I can find). Also, the following F.I components are included: clean plenum with cold-start injector & throttle body, oil bath air cleaner, painted intake runners with new hoses, 4 rebuilt 1.7L fuel injectors, fuel rails, 5 rebuilt 2.0L injectors, new injector seals, fuel regulator, good MPS, good AAR, dizzy with trigger points & new sparkie wires, etc.). A box full of other misc new items is included too. I found the front tins, the under barrel tins, and I believe the rear tin, but still looking for the rest of the tin pieces (that IIRC, I blasted & painted several years ago). I'd like to get $4,000. for all of it. |
ndfrigi |
Nov 4 2023, 07:49 PM
Advanced Member Group: Members Posts: 2,953 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Sir Mark, did the 1st member have to pass on this engine?
euro911 |
Nov 4 2023, 09:06 PM
Not yet. I posted the pix for him to look at (IMG:style_emoticons/default/popcorn[1].gif)
Abe has contacted me, he's #2 ... so has Ted (913B), he's #3 (IMG:style_emoticons/default/shades.gif) I found a bunch of motor stuff, including the rear engine tin and a couple of other tin pieces, but not the top tins. Must still be in AZ. Gonna have a neighbor there take a 'look-see' UPDATE: The first responder stepped aside and Abe has been catapulted to spot #1 (IMG:style_emoticons/default/first.gif) ... and Ted to the #2 (IMG:style_emoticons/default/stromberg.gif) spot (IMG:style_emoticons/default/laugh.gif) |
euro911 |
Nov 5 2023, 01:57 PM
SOLD ...Thank You, Abe (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 26th September 2024 - 09:38 PM |
