Clutch action and tunnel repair...., Hoping I can fix my clutch pedal issue...who has done the tunnel repair?? |
930cabman |
Nov 16 2023, 06:01 AM
Advanced Member Group: Members Posts: 3,802 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
read the repair procedure in the tech tips 700 appendix We have repaired them successfully for the last 48 years using this method Hello out there....my clutch pedal action changed drastically recently and the usual is an old clutch cable giving out...well so far that is not the case and I even have removed my clutch pedal cluster thinking it was shot but now that it is out I compared it to my brand new pedal cluster on the shelf and they are identical in spring tension and other aspects...so basically my current pedal cluster is as good as new....so what to do next? I have heard of a problem with the braised in tubes in the tunnel for clutch/throttle cables that give out....can anyone please comment on this issue and how to fix? I am somewhat anxious about this repair and don't really know why....please someone tell what they know about this issue....thank you very much!! gg "The last 48 years" thanks doc |
DaveB |
Nov 18 2023, 02:17 PM
Member Group: Members Posts: 169 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
I don't have a suggestion for your next steps on the clutch but...this thread is a good nugget of information. I didn't know about the tunnel tube breaking off. Just ran a scope and see that mine needs to be fixed.
read the repair procedure in the tech tips 700 appendix We have repaired them successfully for the last 48 years using this method So the 914 shift tube started to need repair/replacement in 1975? (IMG:style_emoticons/default/biggrin.gif) DaveB |
Lo-Fi Version | Time is now: 4th January 2025 - 12:11 AM |
