Buckeye Sprints, National race at Mid-Ohio this weekend |
groot |
Aug 19 2005, 07:15 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I'm headed to M-O this weekend to race. Anybody else going?
I'm trying out a few things and uncovered a problem or two in the process. For cooling, I'm running 2-3" ducts from the turn signal openings (one on each side)... I know many of you think it's not enough, but I'm willing to try it out before I run a huge duct. I also replaced by EGT senders with some Westach parts. I was checking to see if they worked and oh, my..... they read a lot higher than my other senders did. I'm guessing the old senders were not the right calibration to work with my Westach gage. I still have to do the alignment, I'm removing some camber to save weight.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Brett W |
Aug 22 2005, 09:44 AM
Probably that selective firing issue with the 009. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:06 AM |
