Oil Leaks, I am tired of them |
sdoolin |
Jul 1 2024, 03:31 PM
Member Group: Members Posts: 383 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Thanks Jake for chiming in. I assembled the cases all the way out to the cylinder heads over the weekend. I used Loctite 565 in those areas of the case through bolts. It was what was recommended the most based on my searches. Wishing I had read your reply before assembly, but I'm not taking it back apart now. Pushrod tubes are in an OE placement with no mods, but I am using "modern" X-Ring O-Rings at both ends of the tubes.
I am hopeful that with very careful assembly, a change to the case half sealer, the updated X-Rings and more attention to detail that I will have less oil leakage. I am not convinced I will have a dry engine or garage floor. |
Lo-Fi Version | Time is now: 17th October 2024 - 09:17 PM |
