4 Pages V  1 2 3 > »
> Front Sidemarker Flasher Module
Spoke
post Dec 3 2023, 06:10 PM
Jerry
There has been some interest in a module that would flash the front sidemarker with the turnsignal. The rear running/brake/turnsignal board I did for the 356 using the front turnsignal bucket from a 914 uses the same function to flash the running or brake light when the turnsignal comes on.
The flashing circuit was lifted from the 356 board and placed on this board with some modification. The board will be about 1.6in x 1in and will be enclosed in a small plastic box. The module will replace the wires which go from the front trunk into the rubber wire channel to the sidemarker and turnsignal.
Basically the wires to the turnsignal and sidemarker will be pulled out of the rubber channel and connected to the module. The module will have wires that will be fished into the rubber channel and connected to the sidemarker and turnsignal just like the OEM wiring. The OEM wiring will remain intact keeping with my goal of no cutting/screwing/gluing plug-and-play installation.
@Cairo94507
Long_ago
post Dec 3 2023, 06:18 PM
Yes please.
HB
FlacaProductions
post Dec 3 2023, 06:40 PM
Interested.
914werke
post Dec 3 2023, 06:59 PM
(IMG:style_emoticons/default/cheer.gif)
burton73
post Dec 3 2023, 07:20 PM
Senior member, and old dude
Great idea to be safe.
Bob B
56kabrio
post Dec 3 2023, 09:26 PM
QUOTE(Spoke @ Dec 3 2023, 04:10 PM) *
@Cairo94507
I am interested!
Thanks
Mack
second wind
post Dec 3 2023, 11:58 PM
This would be a very nice safety modification....please make it happen...!!!! Thank you very much!!!
gg
Cairo94507
post Dec 4 2023, 08:30 AM
Michael
Of course I want a set. (IMG:style_emoticons/default/smile.gif). Thank you Jerry for solving this problem. I am sure you have saved countless 914's from getting hit. (IMG:style_emoticons/default/beerchug.gif)
sb914
post Dec 4 2023, 10:10 AM
Surf Guru
Great job once again!
914werke
post Dec 4 2023, 10:51 AM
to clarify will this new board cause the sidemarkers to flash/blink simultaneous with the turn signal indication or alternate (off/on, on/off) like new LED circuits?
Spoke
post Dec 4 2023, 11:04 AM
Jerry
QUOTE(914werke @ Dec 4 2023, 11:51 AM) *
The sidemarkers will be powered by the turnsignal power so will be in sync with the turnsignals.
Root_Werks
post Dec 4 2023, 04:38 PM
Village Idiot
What a neat idea! Almost wish I still had side markers
DRPHIL914
post Dec 5 2023, 12:27 PM
Dr. Phil
QUOTE(Spoke @ Dec 3 2023, 07:10 PM) *
@Cairo94507
ok, i'm in, just wondering where the box with the board will be located?
Phil
Chris H.
post Dec 5 2023, 12:39 PM
I'll take a set.
Spoke
post Dec 5 2023, 04:10 PM
Jerry
QUOTE(DRPHIL914 @ Dec 5 2023, 01:27 PM) *
@Cairo94507
Phil
It should tuck in right behind the headlights. The box size should be about 1.75x1.0x0.5 inches.
My 914 will be the test bed for installation.
Spoke
post Dec 5 2023, 04:21 PM
Jerry
BTW looks like I f'ed up the schematic on the first boards. I'll be able to make them work with a couple of mods. 2nd version of the board is almost done.
Without the mods hitting the turnsignals may flash all the running lights on that side of the car. And turning the running lights would light all the turnsignals constant. Oops.
majkos1
post Dec 6 2023, 08:22 AM
majkos1
post Dec 6 2023, 08:23 AM
anderssj
post Dec 6 2023, 06:14 PM
Dog is my copilot...
Yes please.
StratPlayer
post Dec 6 2023, 08:26 PM
StratPlayer
In, indeed
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 24th November 2026 - 02:12 PM
