Lilchopshop’s Subaru Conversion Project, Making it up as I go |
Lilchopshop |
Mar 9 2024, 07:54 AM
Member Group: Members Posts: 75 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States |
It’s been a while since my last post, but I’ve been chipping away at stuff. Here are some updates.
Shifter is mounted Cleaned up the driver’s footwell and welded all the access holes in the floor pan. Finished the metal work on the rear valence (for now). I’m undecided if I’m going to keep this valence as is or make something else. I’m going to wait to see how I feel about it once the car is on wheels. Did a rough install of the hybrid axles with the new exhaust and all the rear suspension parts to check for installation issues and adequate clearances. I also wanted all these parts in place for when I’m figuring out the shift cable routing. This was a good motivator for me. Next up is brackets for shift cables, and then start working out the pedal box mods for the hydraulic clutch. |
76-914 |
Mar 9 2024, 08:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,646 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
It's good that you're back on it. Should be a nice reliable 914 when you're finished. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 22nd December 2024 - 05:34 AM |
