23 Pages V « < 18 19 20 21 22 > »
> Fred's Backyard LE Restoration
morehills
post Feb 19 2025, 04:59 PM
Post #381
OK, I'm one step from showing up at Fred's house with the three wise men, as this work is certainly immaculate and beyond my conception. But Fred, for the novice back yard mechanic, can you tell us what tools are the essential kit for all this fine work? And what was your prior metal working experience? I want to think I could approach a project like yours in the future. And that's where I will likely leave it -- with the thinking.
930cabman
post Feb 19 2025, 05:54 PM
Post #382
QUOTE(morehills @ Feb 19 2025, 05:59 PM) *
Fred is one of those guys with 30 hours in his day, there can be no other way.
Will you be toting myrrh in your trek to Fred's?
friethmiller
post Feb 19 2025, 06:44 PM
Post #383
Ha! Ha! (IMG:style_emoticons/default/lol-2.gif)
Thanks but I have no "real" tools and certainly no overhead cover! No official training, no training at all actually if you don't count metal shop in high school about 40 years ago. (IMG:style_emoticons/default/biggrin.gif)
You (and any others) are always welcome to stop by to check out the LE. Warning: You might get put to work. (IMG:style_emoticons/default/welder.gif)
friethmiller
post Feb 19 2025, 07:32 PM
Post #384
Paint Removal: (the grind continues) - (2/15 & 2/16/2025):
With the seal track completed, I decided to jump right into removing the remaining old paint from the front trunk. There's a lot of painted surfaces to attack here and some old sealant that needed to be removed. I did a lot of this by hand with a scraper but used a paint removing disc on some of the larger areas. The second picture shows some of the seal track drains that I cut in (red arrows). There are 5 drains on this lower section and are approximately 8 inches apart. I will also install a drain hole above each light bucket to allow any water in the fender seal track to drain down into the bucket
After several hours of scraping, grinding, and sanding I was able to get these areas ready for sandblasting. I don't particularly like to do it but there are times when it's necessary. This trunk is really bad!
Results of a light sand-blasting:
Red arrow shows additional damage that "magically" appeared after blasting in the light bucket. The other photo here shows the damage to the truck reinforcement corners. I'm still debating about replacing both of these. With the supports above, this will not be easy to do. (IMG:style_emoticons/default/idea.gif)
The remaining photos show all the cuts made in the areas that need repair. All of this will be done next weekend (weather dependent). As bad as this front corner looks, it's WAY better than the other side. We'll see. Cheers! (IMG:style_emoticons/default/beer.gif)
bkrantz
post Feb 19 2025, 08:59 PM
Post #385
I know Porsche and Karmann used steel and treatments that were normal for the 914 era, put seeing photos like this still makes me wonder. After all, the body assembly was complex and labor intensive, but so prone to rust in all kinds of places.
friethmiller
post Feb 19 2025, 09:38 PM
Post #386
QUOTE(bkrantz @ Feb 19 2025, 08:59 PM) *
Yeah, I agree. I've come to terms with the rust on this car. It must be fixed/solid. BTW, I started drilling out the spot welds on the driver side fender. Like a "pool shark" you've got to think 2 to 3 moves ahead of what's currently "in-play". With that fender removed, I'll get to do more "goodness" in the cowl area. Should be done with the main body (minus doors/hoods) in a few more weekends.
Artfrombama
post Feb 20 2025, 01:57 AM
Post #387
QUOTE(bkrantz @ Jan 19 2025, 09:02 PM) *
QUOTE(friethmiller @ Jan 19 2025, 07:25 PM) *
Passenger Light Bucket Area Repair - Part 6 (1/18/2025):
Working the bottom edge:
You can see that I worked in small patches to try and match the curve the best I could. I have found it's most important to pay attention to the sides and top of these pieces - making sure everything is as flush as it can be. None of this is going to show too much but I trying to do a little bit better than my previous efforts. Might need an English Wheel or something to create these flowing curves with all the other vertical bends/curves that are necessary (IMG:style_emoticons/default/confused24.gif) The following photos show the process of buttoning up this area.
Yay! (IMG:style_emoticons/default/cheer.gif)
My scrolling finger hates you! (IMG:style_emoticons/default/bootyshake.gif)
Root_Werks
post Feb 20 2025, 10:43 AM
Post #388
Village Idiot
Loving all the pictures! Ruts repair on a 914 can be so time consuming.
friethmiller
post Feb 20 2025, 11:23 AM
Post #389
QUOTE(Artfrombama @ Feb 20 2025, 01:57 AM) *
QUOTE(Root_Werks @ Feb 20 2025, 10:43 AM) *
Yeah, sorry @Artfrombama . I'm try to show my work as it progresses without going overboard. I like to analyze my work: patch/metal gaps, welds, and grinding. I'm my biggest critic, of course (IMG:style_emoticons/default/smash.gif) I've caught a lot of stuff that I had to go back and fix after looking at the posted photos.
Artfrombama
post Feb 20 2025, 05:08 PM
Post #390
QUOTE(friethmiller @ Feb 20 2025, 11:23 AM) *
No, love your photo documentation, I look forward to your posts.
It's just when someone replies and those photos are posted again. But it's all good.
Carry on, I'll let myself out. (IMG:style_emoticons/default/unsure.gif)
fiacra
post Feb 20 2025, 08:27 PM
Post #391
Person.Woman.Man.Camera.TV
QUOTE(friethmiller @ Feb 19 2025, 04:44 PM) *
I took high school home-economics but the rye bread rounds that I tried to make this morning turned out more like rye bread biscotti. I took metal shop as well, but my projects always turned out looking like I tried to shape them by running over them with a car. They haven't gotten any better... I also took wood shop, but the fence I built three days ago looks like I don't know how to read a level (fortunately you can only see that on the neighbor's side (IMG:style_emoticons/default/happy11.gif) ).
I keep revisiting this thread because of just how amazing it is to me that somewhere in Texas is a man restoring an LE in his backyard, working with a car that looks a lot like swiss cheese, and achieving such remarkable results. I can only imagine what you would have gotten done if you had a fully equipped shop to work in. Wish you were nearby and I could see it happen in person. No disrespect to anyone else's rustoration project, but this is by far the most interesting project thread I've read. Thanks for putting this LE back on the road.
friethmiller
post Feb 20 2025, 11:17 PM
Post #392
QUOTE(fiacra @ Feb 20 2025, 08:27 PM) *
Thanks! I still have a long way to go.
I'm sure that rye biscotti would be really good with some coffee! (IMG:style_emoticons/default/smilie_pokal.gif)
friethmiller
post Feb 21 2025, 08:38 AM
Post #393
QUOTE(Artfrombama @ Feb 20 2025, 05:08 PM) *
No, you are right. I don't like that either. I'll call it out next time.
iankarr
post Feb 23 2025, 06:38 PM
Post #394
Phenomenal. Just wow!
friethmiller
post Feb 23 2025, 06:58 PM
Post #395
Patching Holes and Prep'n the Driver Side Corner - Part 1 of 2: (2/23/2025):
Since Saturday was cold and wet, I only had Sunday to get some progress done on the LE. First order of business was the patch in the back trunk floor, followed by several other small rust holes I discovered here and there. After that, I planned on patching the holes in the driver side light bucket.
After cutting, forming, and tacking-in the patch, I figured I'd save my back and rotate the car up on the 90 to have better access. This is when the rotisserie is nice! Anytime I bang my head on it, I hate the damn thing. (IMG:style_emoticons/default/huh.gif) Here's a couple shots front and back on this patch. Going to need to jack this thing up off the front hoop at some point so I can grind/remove paint under that steering support rack (thingy). Probably happen right before I paint the bottom of the car.
Next up, two rust holes in the passenger side corner support bracket (thingy). Here, I decided on drilling out the bad metal and take a chance on being able to patch with just weld. Risky thing to do on a 914 trunk, I know. Got lucky on these and a few other holes I drilled out in the rear corner.
Attached Image. Attached Image
Next, I was able to come in from below on the light bucket and cut out the bad spot with a 3" cutting wheel. The last photo [of the 3] shows the patch in the center and two other holes on either side that where welded close.
After looking around the entire area I found one more hole on the front cross panel. Note the use of the copper backer. I use this for most holes I weld close. I also got a chance to finally grind down the patch I did a few weeks ago at the bottom of the passenger side support bracket.
Coming up next in Part 2 - Cutting and blasting below the light bucket...
Cairo94507
post Feb 23 2025, 07:05 PM
Post #396
Michael
Really nice work. (IMG:style_emoticons/default/smilie_pokal.gif)
friethmiller
post Feb 23 2025, 07:19 PM
Post #397
Patching Holes and Prep'n the Driver Side Corner - Part 2 of 2: (2/23/2025):
After all that patching I decided to switch gears and grind off the rest of the old paint from the bottom of the trunk. And just like everywhere else, rust under the paint (IMG:style_emoticons/default/bootyshake.gif)
Well, it didn't take too long here to figure out that the bottom of the trunk corner needed to come out and get overhauled - just like the other side (IMG:style_emoticons/default/headbang.gif) The arrows point to the cut lines.
Decided to throw on some quick primer on the trunk (for now) and start the process of drilling out spot welds to get this piece out of the car. Of course, there's like 40 spots welds on this corner. Go grief, that took forever to remove. It looks aweful!
I had some time still left in the day so I pulled out the sandblaster and hit the entire area under the light bucket. Arrow points to the hole that magically appear with a very light blasting. I'm probably going to have to replace a lot of this bottom metal - just like the other side.
Final shot of the work area. It's coming around. (IMG:style_emoticons/default/biggrin.gif)
Yours truly out in some beautiful weather, sporting one of his favorite tools. Cheers!
friethmiller
post Feb 23 2025, 07:25 PM
Post #398
QUOTE(iankarr @ Feb 23 2025, 06:38 PM) *
QUOTE(Cairo94507 @ Feb 23 2025, 07:05 PM) *
Thanks guys!
930cabman
post Feb 24 2025, 06:02 AM
Post #399
Fred gets my nomination for restoration of the year
friethmiller
post Feb 24 2025, 09:15 AM
Post #400
QUOTE(930cabman @ Feb 24 2025, 06:02 AM) *
Ha! That's not even a thing! (IMG:style_emoticons/default/confused24.gif) But I certainly appreciate the comment. Thank you, sir!
3 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 19th April 2025 - 05:49 PM
