Stripped, Clean metal |
930cabman |
Dec 18 2023, 05:52 AM
Advanced Member Group: Members Posts: 3,843 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
jaredmcginness |
Dec 18 2023, 07:08 AM
... Group: Members Posts: 508 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Thanks was looking for a new brand to try. Just ordered a gallon for a customer project, I will try it out.
930cabman |
Dec 18 2023, 07:53 AM
Geezer914 |
Dec 18 2023, 08:16 AM
Geezer914 Group: Members Posts: 1,821 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Thanks for sharing.
MikeK |
Dec 18 2023, 10:15 AM
Member Group: Members Posts: 132 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Thanks for posting. I'll give it a try.
It's been a struggle to find a good stripper since the MEK ban in CO. I put some painted bolts from a Vanagon in a cup of Kleen Strip for 2 days and it barely softened the paint. This was submerged. |
930cabman |
Dec 18 2023, 10:37 AM
Thanks for posting. I'll give it a try. It's been a struggle to find a good stripper since the MEK ban in CO. I put some painted bolts from a Vanagon in a cup of Kleen Strip for 2 days and it barely softened the paint. This was submerged. As mentioned Back to Nature brand is a safe product, no noxious odor, incidental skin contact is ok. Does need to be over 60 degrees and covered 24 or so hours. Washes off with water, I simply dry the surfaces with paper towels. Much better than going over 1/2 century of XYZ and who knows what else |
technicalninja |
Dec 18 2023, 11:37 AM
Advanced Member Group: Members Posts: 2,267 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Looks like an alternate to "stinky" removers.
Thanks for the tip! Takes longer but looks like it works pretty good with the plastic overlay. Can you tell what the "base" is? Most of the 'friendly" strippers are citrus based. Often smells "fruity". I'm going to try this due to this post. |
Shivers |
Dec 18 2023, 01:16 PM
Senior Member Group: Members Posts: 2,883 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Wow, that works pretty good. Thanks for the tip
930cabman |
Dec 18 2023, 02:21 PM
Looks like an alternate to "stinky" removers. Thanks for the tip! Takes longer but looks like it works pretty good with the plastic overlay. Can you tell what the "base" is? Most of the 'friendly" strippers are citrus based. Often smells "fruity". I'm going to try this due to this post. There is very little odor with Multi Strip. It is not like paint, it needs to be applied heavy, as in about as thick (1/16") as you apply it. I do not know the base, but the folks at Back to Nature have always been user friendly when I request information. make sure you protect the floor as after sitting for 24 or more hours, the paint falls off via gravity. |
930cabman |
Jan 1 2024, 07:17 AM
davep |
Jan 1 2024, 08:03 AM
914 Historian Group: Benefactors Posts: 5,227 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Not exactly why but check out the rusting under the removed paint. there were no signs of degradation on either surface of this rusting. Maybe this was included at the factory at no extra charge Could the rusting have come from the stripping process? Now you have it stripped, what do you use to protect the bare surface; Metal Prep? I have used MP for many years on cleaned surfaces, and it tends to prevent rust for quite a long time under dry conditions. |
brant |
Jan 1 2024, 08:42 AM
914 Wizard Group: Members Posts: 11,832 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The rust occurs during stripping
It wasn’t under the paint |
friethmiller |
Jan 1 2024, 08:45 AM
Senior Member Group: Members Posts: 738 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Not exactly why but check out the rusting under the removed paint. there were no signs of degradation on either surface of this rusting. Maybe this was included at the factory at no extra charge I think rust can start to get under the paint a number of different ways. Check out my passenger side inner fender. This was under the paint. You would have never known by looking at it. BTW, this rust came off easily with my metal etch and a red 3M scuff pad. |
Jett |
Jan 1 2024, 09:56 AM
Senior Member Group: Members Posts: 1,676 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Our garage is at a constant 71 degrees from the floor radiant heat, and very little moisture, yet we found similar rust under the primer of the trunk lid but not the quarter panels. We also found pockets of 1” surface rust under the rear shock tower seam-sealer, very unexpected.
I bought some phosphoric acid to remove the rust, will try this afternoon. Attached thumbnail(s) |
930cabman |
Jan 1 2024, 12:03 PM
The rust occurs during stripping It wasn’t under the paint Not sure if I agree, I did the entire body and the leading portion of the hood is the only area showing this. During removal of the stripper the steel was generally clean as a whistle. I scrubbed with a heavy scotchbrite pad and rinsed with water. I'm gonna put my $5. on the rusting was under the paint |
930cabman |
Jan 1 2024, 12:14 PM
Not exactly why but check out the rusting under the removed paint. there were no signs of degradation on either surface of this rusting. Maybe this was included at the factory at no extra charge Could the rusting have come from the stripping process? Now you have it stripped, what do you use to protect the bare surface; Metal Prep? I have used MP for many years on cleaned surfaces, and it tends to prevent rust for quite a long time under dry conditions. Planning to sand everything down to smooth bare and epoxy prime, go from there |
Jan 1 2024, 12:29 PM
914-6 GT in waiting Group: Members Posts: 19,707 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Was it original paint and primer or a respray.
technicalninja |
Jan 1 2024, 01:32 PM
I've found I get rust overnight it I don't use a phosphoric compound (or something similar).
After it's been hit with "metal ready or Dura-etch" it will go WEEKS in bare metal before the surface rust comes back. Most of the strippers I've used over the years initially strip to clean metal that is starting to rust by the 2nd hour... |
930cabman |
Jan 1 2024, 02:34 PM
Was it original paint and primer or a respray. A combination of both, odd only the front portion of the frunk is effected. It will sand out easily. About 95% of the steel looks great It has been a couple of weeks and no signs of surface rusting. I keep the temp around 60 - 65 degrees. |
930cabman |
Jan 3 2024, 02:48 PM
Lo-Fi Version | Time is now: 18th January 2025 - 12:40 PM |
