> 914World Classifieds Rules
> F/S drivers side door pockets in early and late black vinyl $65 each, Diferece is the grain on the vinyl no more soggy pocket!
Mikey914
post Dec 24 2023, 01:40 PM
The rubber man
The early is the wider grain vinyl like my 72 has. It is NOT the wider grain "Elephant " skin.
The later is the standard black late vinyl that most cats have. It does have an imperfection in the top lip was not cut properly, but it will not be noticeable once it's installed.
These are $65 each+ actual shipping.. Will not be able to ship until the 30th.
The late
Mikey914
post Dec 24 2023, 01:44 PM
The rubber man
Early
Montreal914
post Dec 26 2023, 08:19 AM
Hey Mark,
The third picture of the late one is the plastic only, or recovered with the vinyl?
Grain seems different on that picture… (IMG:style_emoticons/default/confused24.gif)
Are the holes pre-drilled in the plastic structure?
Thanks.
Mikey914
post Dec 26 2023, 01:06 PM
The rubber man
1st group 3rd picture shows the base the late vinyl is applied to.
Has an area that was mis-cut. I wanted to point this out as with the vinyl attached you can't see it. The one screw in this area may or may not fully engage. However, the strap and the rest of the screws will hold it nicely.
Mikey914
post Dec 31 2023, 05:06 PM
The rubber man
Bump
- Lo-Fi Version Time is now: 21st November 2024 - 09:30 PM
