Starter Tab Wiring Size?, Open tab on the solenoid... |
FlacaProductions |
Dec 26 2023, 07:10 PM
Senior Member Group: Members Posts: 1,845 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Looking to put a female connector on my remote starter button to replace the current spring clamp. Anyone know the size of the tab on the solenoid? I have an open one there - yellow wire on the other one.
JeffBowlsby |
Dec 26 2023, 10:55 PM
914 Wiring Harnesses Group: Members Posts: 8,780 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Measure the width. Should be 6mm, 1/4in also works.
FlacaProductions |
Dec 27 2023, 11:11 AM
Thank you - away from it and trying to get some little things done.
jcd914 |
Dec 28 2023, 10:29 PM
Check and test the starter terminal you are asking about, many starters have a second terminal that is an output to provide voltage to the coil while starting.
Not used on the 914 but most replacement starters have the terminal. It is an output and won't energize the solenoid. Jim |
FlacaProductions |
Dec 29 2023, 12:07 PM
Hey Jim - thank you for this. I've already confirmed the functionality. Problem is, I'm 2100 miles from it. Just want to change one lead from my remote start switch to fit the tab vs. the spring clamp that has a tendency to slide off.
Lo-Fi Version | Time is now: 26th December 2024 - 09:48 AM |
