914ltd |
Member ![]() ![]() Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
Big improvement in cold start running and driving issues. Brad |
914ltd |
914ltd |
914ltd |
Great device for initial rough running. |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,691 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Can I still place an order ?
Jom |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,908 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
@jim_hoyland - you can order direct here. Same part from Brad.
https://www.ebay.com/itm/276714473501?mkcid...&media=COPY |
jim_hoyland |
Thanks for the link; ordered one via eBay
@jim_hoyland - you can order direct here. Same part from Brad. https://www.ebay.com/itm/276714473501?mkcid...&media=COPY |
914ltd |
DC_neun_vierzehn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 508 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
More available. $30. with post It seems (?) that this might make the CHT sensor easier/faster to replace (if the extension stays in place)? What’s the likelihood that removing the CHT unscrews the extension, too? Interesting potential. Hopefully you won't need to remove the CHT often. It's probably about 50/50 that it would stay in the head unless you use Locktite. A small dab of anti seize on the CHT itself would also help. Keep in mind you are installing a steel threaded part into the much softer aluminum cylinder head. The threads can strip out easily. Brad @914ltd I bought one of these from you a while back, but have not installed yet. I'm looking for guidance on installing the extension for someone who's never installed a CHT nor an extension. 1. Obviously, I don't want to strip the cylinder head. Is there a torque LB you recommend for the extension into the head ... hand tighten only? 2. Same question for the CHT on the extension - what torque should I use? 3. Lastly, should I install the CHT on the extension first, then install the extension into the CH? Thanks in advance. |
914ltd |
More available. $30. with post It seems (?) that this might make the CHT sensor easier/faster to replace (if the extension stays in place)? What’s the likelihood that removing the CHT unscrews the extension, too? Interesting potential. Hopefully you won't need to remove the CHT often. It's probably about 50/50 that it would stay in the head unless you use Locktite. A small dab of anti seize on the CHT itself would also help. Keep in mind you are installing a steel threaded part into the much softer aluminum cylinder head. The threads can strip out easily. Brad @914ltd I bought one of these from you a while back, but have not installed yet. I'm looking for guidance on installing the extension for someone who's never installed a CHT nor an extension. 1. Obviously, I don't want to strip the cylinder head. Is there a torque LB you recommend for the extension into the head ... hand tighten only? 2. Same question for the CHT on the extension - what torque should I use? 3. Lastly, should I install the CHT on the extension first, then install the extension into the CH? Thanks in advance. You would want firm contact with the copper (or aluminum) washers for good heat conduction. There is no published torque but I would think 10 LB would be sufficient. Read the above post for more information. Brad |
914ltd |
Bump |
914ltd |
Bump |
914ltd |
Available |
914ltd |
I first used these while working at a Porsche dealership in the early 70's. I believe we purchased them from a VW dealer. This little device slows down the heat getting to the head temp sensor and after initial warm up, it has no effect on running. $30. with 2 copper seal rings. Post included Does not include the head temp sensor. In stock ready to ship. |
914ltd |
Bump |
914ltd |
914ltd |
Warm weather is coming. How does your 914 drive in the first mile?
914ltd |
L-Jet914 |
Member ![]() ![]() Group: Members Posts: 339 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California ![]() |
More available. $30. with post It seems (?) that this might make the CHT sensor easier/faster to replace (if the extension stays in place)? What’s the likelihood that removing the CHT unscrews the extension, too? Interesting potential. Do you think this would be viable on our 1.8s vs the D-Jet cars? I am probably going to replace my CHT sensor with one that I got from Jeff Bowlsby as the insulation on mine is coming off. I will be purchasing the correct socket to remove a wired sensor. |
914ltd |
More available. $30. with post It seems (?) that this might make the CHT sensor easier/faster to replace (if the extension stays in place)? What’s the likelihood that removing the CHT unscrews the extension, too? Interesting potential. Do you think this would be viable on our 1.8s vs the D-Jet cars? I am probably going to replace my CHT sensor with one that I got from Jeff Bowlsby as the insulation on mine is coming off. I will be purchasing the correct socket to remove a wired sensor. Enriching the mixture when engine is cold would be the same for the Ljet and Djet. It might be helpful to prevent damaging lean backfire common to the 1.8. Brad |
Lo-Fi Version | Time is now: 29th April 2025 - 02:10 AM |
