Cairo's Six - 3.6 in and running great! |
rick 918-S |
Mar 17 2024, 07:36 AM
Hey nice rack! -Celette Group: Members Posts: 20,705 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What size line do you have running up to the cooler? I have to plan this out for my 6. It had a front cool but was removed before I ended up with it.
tygaboy |
Mar 17 2024, 08:52 AM
914 Guru Group: Members Posts: 5,439 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
What size line do you have running up to the cooler? I have to plan this out for my 6. It had a front cool but was removed before I ended up with it. @rick 918-S Michael's car has -12 lines. I assume that's standard for the 3.2/3.6 but I'd defer to those more knowledgable. |
rick 918-S |
Mar 17 2024, 08:58 AM
What size line do you have running up to the cooler? I have to plan this out for my 6. It had a front cool but was removed before I ended up with it. @rick 918-S Michael's car has -12 lines. I assume that's standard for the 3.2/3.6 but I'd defer to those more knowledgable. Thanks. I have been researching hard line stuff but haven't gotten as far as sizing. |
tygaboy |
Mar 17 2024, 03:54 PM
Fan mount/lower shroud V2 looks like it's a winner. I still need to add the fasteners for the upper fan mounts but in all, I'm liking it.
This component is far enough along that I can get started on the main shroud design. Attached thumbnail(s) |
Cairo94507 |
Mar 17 2024, 04:29 PM
Michael Group: Members Posts: 10,044 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Loving it! This is exactly why I knew Chris and the Red Barn were where I wanted to be (IMG:style_emoticons/default/smilie_pokal.gif) . This is going to work very, very, nicely. I am getting excited to be able to go pick her up and move on to the next stage of this project. (IMG:style_emoticons/default/beerchug.gif)
Mar 17 2024, 05:21 PM
Resident German Group: Admin Posts: 41,839 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What size line do you have running up to the cooler? I have to plan this out for my 6. It had a front cool but was removed before I ended up with it. @rick 918-S Michael's car has -12 lines. I assume that's standard for the 3.2/3.6 but I'd defer to those more knowledgable. I'm running -12 on my car, should be plenty. (IMG:style_emoticons/default/bye1.gif) |
Cairo94507 |
Mar 18 2024, 06:00 AM
@SirAndy - Thanks Andy- That makes me feel even more comfortable with this set-up. (IMG:style_emoticons/default/beerchug.gif)
Cairo94507 |
Mar 18 2024, 06:17 AM
Oh, and just to follow up, the 3.2 arrived safe and sound to the new owner. I breathed a sigh of relief when he let me know. (IMG:style_emoticons/default/beerchug.gif)
roundtwo |
Mar 18 2024, 11:56 AM
Member Group: Members Posts: 297 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Fan mount/lower shroud V2 looks like it's a winner. I still need to add the fasteners for the upper fan mounts but in all, I'm liking it. This component is far enough along that I can get started on the main shroud design. WOW very slick. Looks fantastic and FUNCTIONAL!! |
tygaboy |
Mar 19 2024, 02:35 PM
I'm reusing the pre-existing cooler mounting holes but they were so close to that drop-down in the nose of the chassis that even a small-ish washer wasn't a happy fit.
So for Michael, even the washers are custom. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/shades.gif) Attached thumbnail(s) |
Cairo94507 |
Mar 20 2024, 06:07 AM
930cabman |
Mar 20 2024, 01:48 PM
Advanced Member Group: Members Posts: 3,593 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I'm reusing the pre-existing cooler mounting holes but they were so close to that drop-down in the nose of the chassis that even a small-ish washer wasn't a happy fit. So for Michael, even the washers are custom. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/shades.gif) With the /6 conversion I have been working on, it appears the same. So many custom bits. How would anybody estimate the $$ for one of these? labor of love for sure |
tygaboy |
Mar 20 2024, 02:10 PM
Driver's side seatbelt retractor mount:
- area prepped (welding jacket protecting things) - secured with a couple self tapping screws - TIG welded in place Note that unwelded hole gets drilled out for the loacting pin on the back side of the retractor. Attached thumbnail(s) |
roundtwo |
Mar 21 2024, 10:54 AM
Diggin' the whole oil cooler system... (IMG:style_emoticons/default/piratenanner.gif)
For us off the shelf folks might something like this be an option for the oil cooler set up? https://www.pegasusautoracing.com/productde...asp?RecID=26672 |
tygaboy |
Mar 21 2024, 04:18 PM
Really? No one? Really? I need you folks to pay more attention!! (IMG:style_emoticons/default/poke.gif)
Not one of you pointed out that if I didn't want to have those fan mounts poking up above the top of the cooler cover, all I had to do was ROTATE THE !@*%($# FANS!!! I almost pee'd my pants laughing when I realized I'd totally missed this, created more work for myself, etc. Good thing I don't do this as my day job. Attached thumbnail(s) |
tygaboy |
Mar 21 2024, 04:22 PM
I used the redo as an opportunity to make a couple other updates:
- the whole thing is wider and it now competely encloses the cooler - the width eliminates a minor air gap at the outer, lower corners between the cooler and this mount - I oriented the fans so the wires all point in the best direction In all, much better... Attached thumbnail(s) |
Cairo94507 |
Mar 21 2024, 07:14 PM
If I had 1 year to design this, I couldn't. Chris is the best. (IMG:style_emoticons/default/smilie_pokal.gif) I love this cooler/fan. (IMG:style_emoticons/default/beerchug.gif)
tygaboy |
Mar 23 2024, 10:08 AM
I'll be posting this on my channel at some point in the future but figured you folks would enjoy keeping up with progress closer to real-time.
https://www.youtube.com/watch?v=dJHU7KiJnFI |
horizontally-opposed |
Mar 24 2024, 10:21 AM
Advanced Member Group: Members Posts: 3,444 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I used the redo as an opportunity to make a couple other updates: - the whole thing is wider and it now competely encloses the cooler - the width eliminates a minor air gap at the outer, lower corners between the cooler and this mount - I oriented the fans so the wires all point in the best direction In all, much better... Simply beautiful work… |
JmuRiz |
Mar 27 2024, 10:19 AM
914 Guru Group: Members Posts: 5,497 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Good looking work!! Let me know if you plan on selling off the old shroud bits...if the red barn makes a new taller/wider version.
Lo-Fi Version | Time is now: 18th October 2024 - 12:17 AM |
