Cairo's Six - 3.6 in and running great! |
ClayPerrine |
Jul 28 2024, 09:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,803 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
@rick 918-S I don't think it is low fuel pressure. When we first turned the key to power the systems, I had maybe 2 gallons of gas in the tank. We could hear the fuel pump pumping and it quickly was pouring gas back into the tank via the return line- sounded like a garden hose pouring water. But still, it is a good idea to throw a fuel pressure gauge in line to see... you never know. (IMG:style_emoticons/default/beerchug.gif) @frankieshooz Thanks a bunch, let's hope it comes out as nice and we had planned. Once you get your car back from PMB we have to meet up at one of the gatherings. I would love to see your car. (IMG:style_emoticons/default/beerchug.gif) @ClayPerrine - Those injectors look nice and would not break the bank either. I see they are presently out of stock. I have saved that page and will check to see when they are available. Even if we service mine, new injectors might be nice. (IMG:style_emoticons/default/beerchug.gif) That's not the only place you can get them. Search around for the best price and availability. |
Cairo94507 |
Jul 29 2024, 05:49 PM
Michael Group: Members Posts: 10,001 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I just ordered the vacuum canister for the resonance flap. I did not have one....what the heck? My understanding is that comes into play at higher RPM's. (IMG:style_emoticons/default/confused24.gif)
Steve |
Jul 29 2024, 08:21 PM
914 Guru Group: Members Posts: 5,678 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I just ordered the vacuum canister for the resonance flap. I did not have one....what the heck? My understanding is that comes into play at higher RPM's. (IMG:style_emoticons/default/confused24.gif) I left mine connected, but SMC and Paragon list it as part of the air injection. https://www.paragon-products.com/Vacuum-Res....110.140.03.htm So I am curious if it’s needed. |
ClayPerrine |
Jul 30 2024, 05:42 AM
I just ordered the vacuum canister for the resonance flap. I did not have one....what the heck? My understanding is that comes into play at higher RPM's. (IMG:style_emoticons/default/confused24.gif) There is a check valve and a vacuum canister in the line to the resonance flap. It is needed to keep the resonance flap open at full throttle. The manifold vacuum goes to zero at full throttle, and the resonance flap would close when it is needed the most. The canister provides enough vacuum reserve to keep it open. The check valve keeps it from dumping to the intake plenum that is at zero vacuum. |
Cairo94507 |
Jul 30 2024, 07:11 AM
Ohhhh... now I have to find a check valve. (IMG:style_emoticons/default/beerchug.gif)
Greg was able to take the injectors to the shop to get them serviced. I can't wait to get back out there so we can install them and see if that helped. (IMG:style_emoticons/default/confused24.gif) |
technicalninja |
Jul 30 2024, 08:35 AM
Senior Member Group: Members Posts: 1,821 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Look to the AC world if Porsche is excessive on price.
Most of the dash systems from 20 years back had vacuum controls. The check valves and vacuum canisters are sources of problems. Need MORE volume in the canister? VW water pumpers had what looked like a bunch of frog's eggs clipped to the hood. Those are the best canisters of all... |
technicalninja |
Jul 30 2024, 08:36 AM
I've got a couple of brand new MOPAR valves.
I'd ship one for free if it would help... |
Steve |
Jul 30 2024, 10:37 AM
Ohhhh... now I have to find a check valve. (IMG:style_emoticons/default/beerchug.gif) Greg was able to take the injectors to the shop to get them serviced. I can't wait to get back out there so we can install them and see if that helped. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Curious what valve you are referring to? This one? https://www.pelicanparts.com/More_Info/9556...amp;SVSVSI=0643 |
eric9144 |
Jul 30 2024, 01:57 PM
Advanced Member Group: Members Posts: 2,739 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
(IMG:style_emoticons/default/piratenanner.gif) so close (IMG:style_emoticons/default/driving.gif)
Cairo94507 |
Jul 30 2024, 03:13 PM
OK, the injector shop said the injectors were fine. So the hunt continues for why it is running rich and rough at low RPM. (IMG:style_emoticons/default/beerchug.gif)
roundtwo |
Jul 30 2024, 10:23 PM
Member Group: Members Posts: 291 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Great project and progress Michael. I’ve been watching from the sidelines and learning along from you and the pit crew (IMG:style_emoticons/default/clap56.gif)
ClayPerrine |
Jul 31 2024, 05:11 AM
OK, the injector shop said the injectors were fine. So the hunt continues for why it is running rich and rough at low RPM. (IMG:style_emoticons/default/beerchug.gif) Did you replace the O-rings under the intakes? Vacuum leaks will cause rough running. Also, check to make sure the distributor is installed correctly. The injection is sequential, and if the distributor is installed wrong, it will run rough. |
Cairo94507 |
Jul 31 2024, 06:08 AM
@roundtwo - Thanks- I appreciate that. I look forward to seeing your car again.
@ClayPerrine - We did not replace the O-rings under the intake. We believe the distributor dropped right in the way it came out.... I will talk to Greg about that. Thank you guys. (IMG:style_emoticons/default/beerchug.gif) |
Steve |
Jul 31 2024, 06:30 AM
@roundtwo - Thanks- I appreciate that. I look forward to seeing your car again. @ClayPerrine - We did not replace the O-rings under the intake. We believe the distributor dropped right in the way it came out.... I will talk to Greg about that. Thank you guys. (IMG:style_emoticons/default/beerchug.gif) The pulley should be on TDC (red mark) and both distributors should point to the line. Easy to see with the caps off. Could it also be the ICV? Is it also hunting at idle? |
Cairo94507 |
Jul 31 2024, 06:36 AM
@Steve - Thanks for the info Steve. As we continue to work this issue, we will be checking all that stuff. I appreciate your thoughts on this. (IMG:style_emoticons/default/beerchug.gif)
technicalninja |
Jul 31 2024, 08:24 PM
Mailed check valve today.
Incoming! |
ClayPerrine |
Jul 31 2024, 08:42 PM
I was talking with Betty about this at dinner. And I thought of something else to check.
Make sure both coils are firing. The engine will run on one ignition, but it will do so badly. The pistons are large enough to need both coils to run smooth. Put a timing light on each coil wire and make sure they are both firing. Mine wasn't firing on both cylinders initially. I had a bad igniter. Hope that helps! |
mb911 |
Aug 1 2024, 04:24 AM
914 Guru Group: Members Posts: 7,149 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I was talking with Betty about this at dinner. And I thought of something else to check. Make sure both coils are firing. The engine will run on one ignition, but it will do so badly. The pistons are large enough to need both coils to run smooth. Put a timing light on each coil wire and make sure they are both firing. Mine wasn't firing on both cylinders initially. I had a bad igniter. Hope that helps! (IMG:style_emoticons/default/agree.gif) Had a 964 that had a bad coil and it ran terrible. Unplugged the one coil and it ran better. Bought a new replacement for the bad one and all was good |
Cairo94507 |
Aug 1 2024, 06:08 AM
@ClayPerrine @MB911 = Excellent tip. I am. headed to Greg's this morning with the list of things to check. We shall see. (IMG:style_emoticons/default/beerchug.gif)
930cabman |
Aug 1 2024, 10:29 AM
Advanced Member Group: Members Posts: 3,511 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
@ClayPerrine @MB911 = Excellent tip. I am. headed to Greg's this morning with the list of things to check. We shall see. (IMG:style_emoticons/default/beerchug.gif) Hopefully "the list" is getting smaller (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 16th September 2024 - 12:52 PM |
