Cairo's Six - 3.6 in and running great! |
mb911 |
Aug 1 2024, 10:35 AM
914 Guru Group: Members Posts: 7,149 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
@ClayPerrine @MB911 = Excellent tip. I am. headed to Greg's this morning with the list of things to check. We shall see. (IMG:style_emoticons/default/beerchug.gif) Basically the bad coil was sending bad juju to the other coil causing misfires |
technicalninja |
Aug 1 2024, 02:42 PM
Senior Member Group: Members Posts: 1,821 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
@ClayPerrine @MB911 = Excellent tip. I am. headed to Greg's this morning with the list of things to check. We shall see. (IMG:style_emoticons/default/beerchug.gif) Basically the bad coil was sending bad juju to the other coil causing misfires We had a weird one once, RX3 ITA car. Rotaries take BIG, BIG power in the secondary ignition to work properly. Strange misfires till we were looking in the engine compartment after dusk. All of the wires had a blue "aura" around them and you could actually SEE the auras affecting each other! Looked like something out of "Starwars." Braided SS sheathed wires with INDIVIDUAL grounds fixed that just fine... |
FL000 |
Aug 1 2024, 06:22 PM
Member Group: Members Posts: 419 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
All of the wires had a blue "aura" around them and you could actually SEE the auras affecting each other! Looked like something out of "Starwars." How many beers in were you when this was observed (IMG:style_emoticons/default/av-943.gif) Just kidding, that could have been a hard problem to find. Good to see all the progress you guys have made. |
Cairo94507 |
Aug 2 2024, 07:52 AM
Michael Group: Members Posts: 10,001 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
We began yesterday by admiring the absolutely beautiful Mickey Mouse ears a good friend of Greg's 3D printed for my car. A special thanks to Steve Silva for hating the PMS ears enough to ask his good friend if he could do this. Just amazing finished product and made out of the good stuff so they will not deform or melt. We started the engine and I was amazed at how much air pressure comes out of those 2 pipes even with the engine running poorly. No wonder the heat exchangers pump out such great heat. Hooked up the hoses and called that done.
Here is a pictures of the as-shipped PMS Mickey Mouse ears on the engine. You can just see the two pipes sticking up, almost straight up. That was not going to work for the way we wanted this build to look. Here is how the beautiful 3D ears look: We discussed the list of things you all have been mentioned to help us trouble-shoot the poor running condition - thank you all. When we got to the cylinder head temperature sensor... the wiring was opposite of what Kevin's 914-6 3.6 was. Greg had taken pictures of Kevin's wiring. Greg swapped the pins and plugged it back in. Greg removed the passenger side intake manifold so we could install the new Vacuum canister and connected the vacuum lines so the resonance flap would operate. I have to say, Porsche did a nice job of locating that canister. I turned the key and it started and lumped along, missing and smelling rich with some smoke. As we stood there looking at the engine, Greg said, "Michael, unplug the MAF." I did and the engine smoothed right out! OMG! So we rejoiced for a minute and ordered a new MAF sensor. 3 hours later we had it in our hands. Quick side note: We checked the price of the MAF through Porsche, $1,190.00 and they could not get it in until Monday. We checked it through RM European and the cost was like $170. What the exact hell is going on with Porsche parts? Greg called a good friend and he ordered it through SSF for us and when we picked it up it was $190 including tax. Nice. We installed the new MAF and it fired right up and ran great. Yay! (IMG:style_emoticons/default/piratenanner.gif) We checked around the car for leaks, etc., put the seats in and took her for a ride. It felt so good to be behind the wheel again. We drove about 7 miles and pulled over and checked for leaks and noted the front oil cooler fans were now on. We still did not have the fan shroud installed because we wanted to make sure everything was tight and no leaks. I could not even hear the fans running from inside the car. The temperature was sitting at 180 and it was about 98 degrees outside. We returned to Greg's with about 15 miles on her and checked the oil and added 1 quart. We now have 13 quarts in the system and it reads right between the marks on the dip stick. We took her for another ride, Greg driving this time and he tested the engine properly. The engine has tons of torque and pulls hard. First gear really not needed. We do not have the back-pad, seatbelts or the floor mats installed yet. Despite that I was amazed at how quiet the engine was. We could hear the resonance flap open at high RPM's. We put another 10 miles on it and went back to Greg's. The engine is running better now than it did when we first drove her. I guess awaking from a 27 year slumber takes a minute. On the next trip to Greg's I will bring the rear valance to see if it will fit the Sport muffler. I will also take the back-pad and see if that will fit with the seat belt modification. We still have to chase down the oil pressure gauge issue; it and the warning light are acting up. When running, the pressure gauge pins to maximum and the warning light glows green. We obviously have pressure so that, fortunately, is not it. We need to install the oil cooler shroud (thanks again Chris @Tygaboy ). It will be nice to get that buttoned up. I am optimistic about the whole cooler set-up. With no shroud to funnel air we did not get over 180 degrees on the 2 rides. Now granted, we were not sitting in stop and go traffic on a 108 degree day, but still. I was relieved to grab the front trunk oil lines and feel they were hot as was the cooler. No leaks and the fan thermostat working properly was terrific. We are closing in on the end of this swap. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/driving.gif) I feel blessed to have so many great friends who have all contributed to this build. Without them, this would have never happened. Cheers to all. Michael |
ndfrigi |
Aug 2 2024, 08:15 AM
Advanced Member Group: Members Posts: 2,951 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
wow! Congratulations Michael and great work Greg!
tygaboy |
Aug 2 2024, 08:31 AM
914 Guru Group: Members Posts: 5,424 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
(IMG:style_emoticons/default/cheer.gif) Gotta be a big relief to get it running - and running well! Huge shout out to Greg for all his work. (IMG:style_emoticons/default/pray.gif)
Can't wait to see you, Bob and the car in person. |
930cabman |
Aug 2 2024, 08:54 AM
Advanced Member Group: Members Posts: 3,511 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
Victories are always good, enjoy this ride in good health |
ClayPerrine |
Aug 2 2024, 09:17 AM
Life's been good to me so far..... Group: Admin Posts: 15,803 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
We still have to chase down the oil pressure gauge issue; it and the warning light are acting up. When running, the pressure gauge pins to maximum and the warning light glows green. We obviously have pressure so that, fortunately, is not it. I had the exact same problem. The wires are swapped between the gauge sender and the light sender. I just changed them at the sender and it fixed both of them. Hope that helps..... And Congrats on getting to the first drive! Clay |
Root_Werks |
Aug 2 2024, 09:48 AM
Village Idiot Group: Members Posts: 8,414 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Aug 2 2024, 09:53 AM
Resident German Group: Admin Posts: 41,802 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
We still have to chase down the oil pressure gauge issue; it and the warning light are acting up. When running, the pressure gauge pins to maximum and the warning light glows green. We obviously have pressure so that, fortunately, is not it. I had the exact same problem. The wires are swapped between the gauge sender and the light sender. I just changed them at the sender and it fixed both of them. Hope that helps..... And Congrats on getting to the first drive! Clay Same here, mine were swapped as well. (IMG:style_emoticons/default/dry.gif) |
Cairo94507 |
Aug 2 2024, 12:48 PM
Fingers crossed! Thanks Clay and Andy. (IMG:style_emoticons/default/smilie_pokal.gif)
Steve |
Aug 2 2024, 02:08 PM
914 Guru Group: Members Posts: 5,678 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
(IMG:style_emoticons/default/beerchug.gif) Congrats!! Glad you got the bugs out!! Lots of good troubleshooting information in case we run into similar issues.
napasteve |
Aug 2 2024, 02:27 PM
914 driving winemaker Group: Members Posts: 508 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
Just outstanding! I'm also looking forward to seeing in person.
Cairo94507 |
Aug 4 2024, 07:19 PM
The car is home now. The oil pressure and warning light were resolved by swapping the 2 wires. Buttoned up the oil cooler/fan shroud and with Greg lying under the car I turned on the fans and they blow air out the floor louvers nicely. Reinstalled the rear valance, wiped the car down and took her for a drive. Everything works beautifully. I am amazed how nice it runs; no smoke, no drips, just great running.
On the way home, weather was over 100 degrees the entire way and she ran at 185 degrees. I was doing between 65 and 80 the entire trip- 107 miles. Effortless acceleration and power. Now I still do not have my back pad installed, I need to order some seatbelt hardware to get the passenger belt installed and then I will see about installing the back pad. Regardless, the engine is quiet. I used to have to drive with AirPods and play music because the 3.2 was a bit rowdy. I will be posting pictures probably tomorrow, but I need to give her a detail and then take some photos. Thanks to Greg T. and his wife Sandi for tolerating my brother and I during this entire process. Greg is a true Master mechanic and it definitely shows on my car. Thanks to my twin brother Bob who supported this decision and helped throughout the process, as did HB, our good friend. It was a great adventure and a terrific learning experience for me. Heck, I might even attempt the oil/filter change on my own in a couple hundred miles. Cheers, Michael (IMG:style_emoticons/default/beerchug.gif) |
Shivers |
Aug 4 2024, 07:46 PM
Senior Member Group: Members Posts: 2,646 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Congratulations! (IMG:style_emoticons/default/smile.gif)
eric9144 |
Aug 5 2024, 02:49 PM
Advanced Member Group: Members Posts: 2,739 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
We do not have the back-pad, seatbelts or the floor mats installed yet. Ah memories of picking up my car...with no seatbelts. The 3.6 is a totally different beast than the 3.2, not bashing the 3.2 by any means but the 3.6 is kind of glorious, especially when you're foot becomes more accustomed to the power curves etc. My only advice at this point is ease into it, you'll be surprised at just how capable and fast, yet oddly civilized that motor can be--and congratulations on the next chapter with your -big- 6 (IMG:style_emoticons/default/cheer.gif) |
Cairo94507 |
Aug 5 2024, 03:17 PM
Thanks Eric; Totally agree re the feel of the 3.6. Here are a couple photos of how the engine bay turned out. Given all of the stuff on these engines, I think we did a pretty good job of making it look as uncluttered as possible.
A big thanks to Greg and Steve's good friend, Cayley for making those absolutely beautiful "Mickey Mouse" ears. Also to Clewett Engineering for their terrific serpentine belt kit- I think that is a must-do upgrade for a 6 in a 914. |
mb911 |
Aug 5 2024, 03:28 PM
I bet that thing will have rubber on the rear of the 1/4”s pretty easy. I can only imagine. My car feels like a beast now that it has the fuel injection operating well I can’t imagine what a 3.6 would be like
rick 918-S |
Aug 5 2024, 09:30 PM
Hey nice rack! -Celette Group: Members Posts: 20,667 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Damn I saw that reflection on the front fender lip and thought it was damaged! (IMG:style_emoticons/default/huh.gif)
You are are going to need alot more rubber (IMG:style_emoticons/default/aktion035.gif) |
Aug 5 2024, 09:42 PM
Not that much more. Sticky 225's all around have worked very well for me on the street. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 16th September 2024 - 01:03 PM |
