Cairo's Six - 3.6 in and running great! |
Steve |
Aug 28 2024, 01:49 PM
914 Guru Group: Members Posts: 5,678 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Yes, both senders are wrong for those gauges. The temp sender should be 90164163200 and no clue on the pressure gauge since early stock 911 combo gauge with that temperature gauge is 0-140 PSI, not 80. The stock 3.6 pressure sender is 0-5 Bar, which is 0-72.52 PSI, so your close...
Steve |
Aug 28 2024, 01:58 PM
ClayPerrine |
Aug 28 2024, 02:53 PM
Life's been good to me so far..... Group: Admin Posts: 15,803 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
When is the 915 going in? Haven't heard, is a G50 an option in our teeners? have one in my 930, it's sweet I looked into this when building my 4.0L six. The G-50 is a very robust, well shifting transmission. But unfortunately it won't work on a mid engine car without running it upside down. The bell housing bolt pattern on an air cooled Porsche motor asymmetrical, so you have to redrill the bell housing to run the G-50 transmission upside down. Then you have to redrill the drain plug and the vent in the transmission. You have to setup some sort of shift linkage that will work the factory shift rod. To make it fit in a 914, you have to cut the bottom out of the rear trunk to clear the transmission. And the axle angles are really absurd when running a G-50. That and the fact that a clapped out G-50 will run you 10K. Then you have to rebuild it before it is usable. That's why I chose a G-86-21 from a Boxster S/Cayman S. They shift as good as or better than a G-50,they are already mid engine, the axle angles are good, and they are cable shifted. But there are other drawbacks to them as well. If I ever win the lotto, I will have G-86-21 cases made up with a G-50 bell housing and mounts for the rear of the trans that will fit a 914. |
rick 918-S |
Aug 28 2024, 06:14 PM
Hey nice rack! -Celette Group: Members Posts: 20,667 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
rick 918-S |
Aug 28 2024, 06:17 PM
When is the 915 going in? Haven't heard, is a G50 an option in our teeners? have one in my 930, it's sweet I looked into this when building my 4.0L six. The G-50 is a very robust, well shifting transmission. But unfortunately it won't work on a mid engine car without running it upside down. The bell housing bolt pattern on an air cooled Porsche motor asymmetrical, so you have to redrill the bell housing to run the G-50 transmission upside down. Then you have to redrill the drain plug and the vent in the transmission. You have to setup some sort of shift linkage that will work the factory shift rod. To make it fit in a 914, you have to cut the bottom out of the rear trunk to clear the transmission. And the axle angles are really absurd when running a G-50. That and the fact that a clapped out G-50 will run you 10K. Then you have to rebuild it before it is usable. That's why I chose a G-86-21 from a Boxster S/Cayman S. They shift as good as or better than a G-50,they are already mid engine, the axle angles are good, and they are cable shifted. But there are other drawbacks to them as well. If I ever win the lotto, I will have G-86-21 cases made up with a G-50 bell housing and mounts for the rear of the trans that will fit a 914. Double post |
rick 918-S |
Aug 28 2024, 06:18 PM
When is the 915 going in? Haven't heard, is a G50 an option in our teeners? have one in my 930, it's sweet I looked into this when building my 4.0L six. The G-50 is a very robust, well shifting transmission. But unfortunately it won't work on a mid engine car without running it upside down. The bell housing bolt pattern on an air cooled Porsche motor asymmetrical, so you have to redrill the bell housing to run the G-50 transmission upside down. Then you have to redrill the drain plug and the vent in the transmission. You have to setup some sort of shift linkage that will work the factory shift rod. To make it fit in a 914, you have to cut the bottom out of the rear trunk to clear the transmission. And the axle angles are really absurd when running a G-50. That and the fact that a clapped out G-50 will run you 10K. Then you have to rebuild it before it is usable. That's why I chose a G-86-21 from a Boxster S/Cayman S. They shift as good as or better than a G-50,they are already mid engine, the axle angles are good, and they are cable shifted. But there are other drawbacks to them as well. If I ever win the lotto, I will have G-86-21 cases made up with a G-50 bell housing and mounts for the rear of the trans that will fit a 914. If the 901 wasn't a mag case you could cut the bell housing off and weld one on the G-86 |
ClayPerrine |
Aug 29 2024, 05:50 AM
When is the 915 going in? Haven't heard, is a G50 an option in our teeners? have one in my 930, it's sweet I looked into this when building my 4.0L six. The G-50 is a very robust, well shifting transmission. But unfortunately it won't work on a mid engine car without running it upside down. The bell housing bolt pattern on an air cooled Porsche motor asymmetrical, so you have to redrill the bell housing to run the G-50 transmission upside down. Then you have to redrill the drain plug and the vent in the transmission. You have to setup some sort of shift linkage that will work the factory shift rod. To make it fit in a 914, you have to cut the bottom out of the rear trunk to clear the transmission. And the axle angles are really absurd when running a G-50. That and the fact that a clapped out G-50 will run you 10K. Then you have to rebuild it before it is usable. That's why I chose a G-86-21 from a Boxster S/Cayman S. They shift as good as or better than a G-50,they are already mid engine, the axle angles are good, and they are cable shifted. But there are other drawbacks to them as well. If I ever win the lotto, I will have G-86-21 cases made up with a G-50 bell housing and mounts for the rear of the trans that will fit a 914. If the 901 wasn't a mag case you could cut the bell housing off and weld one on the G-86 The 901 clutch is too small for the engine I have. But I actually thought about that using a 964/993 G-64 AWD transmission partial case, (IMG:https://blobs.autobahnparts.com/media/Default/_Profiles/91318dec/c9d8afc8/1-40.jpg) Cutting the bell housing portion off, cutting the bell housing off of a G-86-21 case, and welding the two together. But it would take a lot of time to get it fitted correctly. And I am not a welder. I don't have the skill level necessary to do that. So the welding would cost a fortune. Sorry about the thread hijack...... (IMG:style_emoticons/default/hijacked.gif) |
Cairo94507 |
Aug 29 2024, 10:04 AM
Michael Group: Members Posts: 10,001 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
@Steve - OK, I ordered that sender from RM European. I am trying to source the fitting from Porsche to allow that to screw into the 3.6. (IMG:style_emoticons/default/beerchug.gif)
Steve |
Aug 29 2024, 10:53 AM
@Steve - OK, I ordered that sender from RM European. I am trying to source the fitting from Porsche to allow that to screw into the 3.6. (IMG:style_emoticons/default/beerchug.gif) @cairo94507 Both senders look the same physically. Let us know if their is a difference. I also have a temp gauge like yours and was debating on putting it in someday. I was just anal on crooked numbers in the 904 pod, versus the stock one doesn't matter since its just a white area and red area. Another future project... |
ClayPerrine |
Aug 29 2024, 04:26 PM
@Steve - OK, I ordered that sender from RM European. I am trying to source the fitting from Porsche to allow that to screw into the 3.6. (IMG:style_emoticons/default/beerchug.gif) @cairo94507 Both senders look the same physically. Let us know if their is a difference. I also have a temp gauge like yours and was debating on putting it in someday. I was just anal on crooked numbers in the 904 pod, versus the stock one doesn't matter since its just a white area and red area. Another future project... The oil pressure sender on a 3.6 has a threaded base that is about 19mm (estimated). The oil pressure sender for that gauge has an 8mm threaded base. You have to have the adapter to put it in a 3.6L engine. |
Cairo94507 |
Aug 29 2024, 08:28 PM
@ClayPerrine - I checked with Porsche and that adapter, (96410770522) is out of stock everywhere. Any other possible sources? (IMG:style_emoticons/default/beerchug.gif)
ClayPerrine |
Aug 29 2024, 10:26 PM
@ClayPerrine - I checked with Porsche and that adapter, (96410770522) is out of stock everywhere. Any other possible sources? (IMG:style_emoticons/default/beerchug.gif) Buy one of the plugs, drill it out and tap it to the correct size for the sender. |
Aug 29 2024, 11:28 PM
Resident German Group: Admin Posts: 41,802 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My pressure is typical 80 pounds when at freeway speeds, say 2700 RPM/75 MPH, and when idling, at 40 pounds. Interestingly, those numbers aren't too far off. Mine sits around 20-30 at idle and 70-100 under load. (IMG:style_emoticons/default/idea.gif) |
Cairo94507 |
Aug 30 2024, 06:01 AM
Thanks Andy. Interesting indeed; maybe my sender is OK and I just need to have PAS change the gauge to one with a higher scale. (IMG:style_emoticons/default/beerchug.gif)
@ClayPerrine - Is it the same size as the oil drain plug? |
Long_ago |
Aug 30 2024, 06:18 AM
Newbie Group: Members Posts: 31 Joined: 12-May 21 From: Tracy, Ca Member No.: 25,541 Region Association: Central California |
Maybe there's something in the VDO catalog??
https://vdo-instruments.com/product-categor...rs-and-sensors/ |
Cairo94507 |
Aug 30 2024, 06:26 AM
@long_ago - Good morning HB. Thanks for the referral. (IMG:style_emoticons/default/beerchug.gif)
Steve |
Aug 30 2024, 08:59 AM
My pressure is typical 80 pounds when at freeway speeds, say 2700 RPM/75 MPH, and when idling, at 40 pounds. Interestingly, those numbers aren't too far off. Mine sits around 20-30 at idle and 70-100 under load. (IMG:style_emoticons/default/idea.gif) The stock 3.6 sender is 0-5 Bar (0-72 PSI). Your gauge is 0-80 PSI. I don't know if its worth the hassle of changing the pressure gauge or sender. I would just change the temp sender to match your temp gauge. Temp accuracy is more important. |
Lo-Fi Version | Time is now: 16th September 2024 - 01:03 PM |
