Cairo's Six - 3.6 in and running great! |
4CamGT |
Feb 27 2024, 08:46 AM
Newbie Group: Members Posts: 19 Joined: 18-October 11 From: Newport Beach, California Member No.: 13,688 Region Association: None |
QUOTE The rear was slightly flared from when it was new. So far I don’t know how to post more than one photo at a time! The Webers on mine work flawlessly. Fires up hot or cold immediatly almost like FI. It was dyno’d at 235hp. Freeman, so nice to see you posting on this site! Could you elaborate further about the rear flares being done when it was new? Does that mean you finally did confirm they were done at the factory? For those that don’t know, this was my beloved car for 25 years! Here’s another pic of these unique rear flares. Michael, sorry for the hijack on your thread. Steve, nice to see you here as well! Back in 2019 I visited the Porsche Museum with my ex-colleague, Porsche designer Grant Larson. We didn’t find any documentation on the rear flares. We did however get access to the Piech 914-8. We made a template over the rear flare. It matched very close to mine. So, it’s still a mystery (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
4CamGT |
Feb 27 2024, 08:51 AM
For comparison…
roundtwo |
Feb 27 2024, 09:00 AM
Member Group: Members Posts: 297 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Way to go Michael. A brave endeavor !!!
Saw your spotless car over at Chris's ...beautiful as ever...I can see why Chris is a little hesitant about mixing your car with even the hint of welding. No doubt I'll be spying on the progress of the seat belts and want to see the details of the fan install...a project I might need to copy and paste on my car. (IMG:style_emoticons/default/hide.gif) |
4CamGT |
Feb 27 2024, 09:12 AM
It happened it was the year the Porsche Museum was celebrating 50 years of the 914!
gereed75 |
Feb 27 2024, 09:55 AM
Senior Member Group: Members Posts: 1,294 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Michael
What belt retractor and receiver are you using in the seatbelt upgrade I did this back n the eighties on a car I no longer own and now can not remember the details. I seem to recall I used late 914 or VW belts/ retractors Would like to do this on my car now. Love to drive it but those old belts do not inspire confidence! |
eric9144 |
Feb 27 2024, 12:06 PM
Advanced Member Group: Members Posts: 2,740 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
My car has the PMS front Setrab cooler along with dual fans (on a manual switch under the dash). In -most- normal driving situations here in SoCal, just the cooler without the fans works pretty well, when temps pop up a bit (driving hard or sitting in traffic) I will flip the fans on for additional cooling, have considered just putting them on a thermo switch so they kick on or off at temps but doing it manually isn't really a big deal... But then again I also have that massive Petersen style oil tank with 12-14qts in it --This is a pic without the fan shroud in place (IMG:style_emoticons/default/chowtime.gif)
4CamGT |
Feb 27 2024, 05:47 PM
My car has the PMS front Setrab cooler along with dual fans (on a manual switch under the dash). In -most- normal driving situations here in SoCal, just the cooler without the fans works pretty well, when temps pop up a bit (driving hard or sitting in traffic) I will flip the fans on for additional cooling, have considered just putting them on a thermo switch so they kick on or off at temps but doing it manually isn't really a big deal... But then again I also have that massive Petersen style oil tank with 12-14qts in it --This is a pic without the fan shroud in place (IMG:style_emoticons/default/chowtime.gif) This is an interesting layout. Do the fans get in the way of ventilating the heat out when the fans are off vs having the fans mounted to the cooler? How big is the inlet hole on the bulkhead? |
Cairo94507 |
Feb 28 2024, 12:53 PM
Michael Group: Members Posts: 10,044 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
For anyone interested, the oil cooler and fans in Eric's car appear to be the same cooler and fans I just listed for sale in the classifieds. http://www.914world.com/bbs2/index.php?showtopic=369378
eric9144 |
Feb 28 2024, 01:41 PM
This is an interesting layout. Do the fans get in the way of ventilating the heat out when the fans are off vs having the fans mounted to the cooler? How big is the inlet hole on the bulkhead? The fans don't seem to be in the way as most times I'm not even running them and it takes a bit to come up to temp... inlet pics: |
930cabman |
Feb 28 2024, 03:35 PM
Advanced Member Group: Members Posts: 3,593 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
@4camGT
get access to the Piech 914-8. We made a template over the rear flare. It matched very close to mine. So, it’s still a mystery How did you pull this one off? Either way, very cool |
4CamGT |
Feb 29 2024, 08:53 AM
@4camGT get access to the Piech 914-8. We made a template over the rear flare. It matched very close to mine. So, it’s still a mystery How did you pull this one off? Either way, very cool It was through my ex-Porsche colleague, Grant Larson. I was a Porsche designer in Weissach 1983 to 1990. Great years to be at Porsche! Attached thumbnail(s) |
tygaboy |
Mar 5 2024, 11:53 AM
914 Guru Group: Members Posts: 5,439 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Michael opted for a dual-pass Setrab cooler and three fans. Setrab doesn't offer a fan mount set up for that particular cooler so it's CAD/plasma table to the rescue.
Here's the start of the fan mount. The green lines indicate the edges of the cooler core, the outer shape is the cooler body. This just gets me started on the fan positions. Now I need to work out how I want to mount this to the cooler. I think it'll be sections that'll fold over and serve as the attachment points. Attached thumbnail(s) |
Cairo94507 |
Mar 5 2024, 02:49 PM
Parts have arrived- Yay! I know Chris wants to get this off his plate- and out of his shop. I am looking forward to going to pick her up and get busy with the 3.6 implant. Thanks for everything Chris; I am proud to have you working on this oil cooler set-up as well as the seatbelts. (IMG:style_emoticons/default/beerchug.gif)
tygaboy |
Mar 16 2024, 01:19 PM
I'm working up a one-piece cooler/fan mount with built in front lower shroud. Typical At The Red Barn approach: Do as good a job as possible on the first attempt but be prepared for a do-over, once I see it in real life.
This design needs a couple mount holes moved and that lower shroud area widened. Off to fab V2... Attached thumbnail(s) |
technicalninja |
Mar 16 2024, 02:59 PM
Senior Member Group: Members Posts: 1,927 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Looks NICE!
I prefer the fans on the cooler versus fans attached to the floor over the lovers. |
Mar 16 2024, 03:36 PM
Resident German Group: Admin Posts: 41,839 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Not picking nits here but maybe add a few more holes to that backing plate so some air can go trough without having to hit the fans?
I see no benefit to only having those 3 holes for the fans. I'm guessing you are not trying to "funnel" air through the fans. (IMG:style_emoticons/default/popcorn[1].gif) |
tygaboy |
Mar 16 2024, 06:39 PM
RE: comments about how the fan mount, clearance to the cooler, vents in the mount, etc:
Every pic I can find, and specifically the ones on the Setrab site, show the fans dead against the cooler with no other openings. Note that I spaced Michael's fans back .5". I'm certainly not saying y'all don't have valid comments. I'm no expert so I'm thinking we'll go with what I've done, test it and if mods are needed, we'll go after them at that point. I really do appreciate the input! Attached thumbnail(s) |
flyer86d |
Mar 17 2024, 04:34 AM
Member Group: Members Posts: 443 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
@4camGT get access to the Piech 914-8. We made a template over the rear flare. It matched very close to mine. So, it’s still a mystery How did you pull this one off? Either way, very cool It was through my ex-Porsche colleague, Grant Larson. I was a Porsche designer in Weissach 1983 to 1990. Great years to be at Porsche! I like the flares and the green metallic. You don’t see many in that color. Charlie |
Cairo94507 |
Mar 17 2024, 06:15 AM
Outstanding work Chris; I know this is going to work great. (IMG:style_emoticons/default/beerchug.gif)
mb911 |
Mar 17 2024, 06:58 AM
914 Guru Group: Members Posts: 7,196 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am sure it will work great. I am thinking it may not even need the fans but having never been to CA I really don’t have a good grasp on temps year round
Lo-Fi Version | Time is now: 18th October 2024 - 12:16 AM |
