1976 fuel injection questions |
914incali |
Apr 2 2024, 11:07 AM
Newbie Group: Members Posts: 4 Joined: 16-February 24 From: bakersfield Member No.: 27,944 Region Association: None |
Picked up a 76 out of texas that had been converted to single carb that just doesn't run very well. I decided to convert back to original FI, essentially everything is gone and I am working on understanding the system. I guess my first question is where does the fuel pump draw power from? there is a single black wire underneath the fuel tank that has no power to it but all the relays have been removed and Im waiting on those from pelican
dr914@autoatlanta.com |
Apr 2 2024, 11:18 AM
914 Guru Group: Members Posts: 8,109 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
power is from the relay board in the engine compartment triggered by the control unit grounding the relay, you can buy a complete injection system on e bay, actually easy to inatall and a very good move to make
Picked up a 76 out of texas that had been converted to single carb that just doesn't run very well. I decided to convert back to original FI, essentially everything is gone and I am working on understanding the system. I guess my first question is where does the fuel pump draw power from? there is a single black wire underneath the fuel tank that has no power to it but all the relays have been removed and Im waiting on those from pelican |
914incali |
Apr 2 2024, 11:34 AM
I have a complete injection system and am waiting on relays to arrive. What has me confused is I do not see a harness under the fuel tank for the pump. BTW thank you for all your videos and information that you provide
Attached thumbnail(s) |
rjames |
Apr 2 2024, 11:54 AM
I'm made of metal Group: Members Posts: 4,157 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Black and red= power, brown=ground to chassis.
914incali |
Apr 2 2024, 12:12 PM
JeffBowlsby |
Apr 2 2024, 01:15 PM
914 Wiring Harnesses Group: Members Posts: 8,777 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Single brown ground cable for the fuel pump is separate from the chassis harness. Look for a male 6mm lug welded to the chassis to attach it.
Could not help but notice your ECU is for a 1973 car. Is your MPS also the 037 for a 73 car? You may have trouble smogging it in CA without the right equipment if that is what is intended. Do you have the other smog parts and have you checked the function of each component? |
914incali |
Apr 2 2024, 01:31 PM
yes its out of a 73 2.0, im not to worried about smog but we will have to see how it goes, at this point just trying to get it up and running with fuel injection. Literally every thing has been removed that should be there for smog and fuel injection
burton73 |
Apr 2 2024, 01:39 PM
burton73 Group: Members Posts: 3,691 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
The problem is you are in California, and you need to get the smog pump set up with the sacrificial rubber pulley set up. Most of those parts on the rubber set up have taken a crap doing what they were supposed to do which is if the pump freezes the rubber breaks. I had to change mine out on my CA 1976 car. Your picture does not show the Pump and recirculating system. Each time you go to get the smog it will be an issue. Just so you know. Welcome to 1976 914 in California
Some of California Love lyrics. California knows how to party California knows how to party in the city, city of LA in the city of good old watts in the city of Compton keep it rocking keep it rolling, Inglewood always up to no good. Keep it rocking, keep it rolling Best Bob B |
fiacra |
Apr 2 2024, 10:02 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 478 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
yes its out of a 73 2.0, im not to worried about smog but we will have to see how it goes, at this point just trying to get it up and running with fuel injection. Literally every thing has been removed that should be there for smog and fuel injection I'm not sure you understand that you need to be REALLY worried about passing the smog test. Look around you and see how many post 1975 and pre-OBDII cars are on the road here in California. You are going to end up putting a ton of money and time into trying to achieve that goal, and still may not pass. You'll need to have the fully original FI system in place, the catalytic convertor, all of the smog equipment, a perfectly tuned well running engine in excellent condition, and you have to find a reliable place that has the ability to test an older car. Those are now getting to be few and far between as the investment in keeping the equipment up and running is too much for most shops. You're still not going to know if the car will pass smog until after you've invested $$$$ and hours into the project. If you can't get it to pass smog you can't get it registered and you can't legally drive it here. I really hate to say it, but you're better off cutting your losses now, putting the minimum into getting the car running and driving and then selling it out of state. After that, find a 1975 or earlier smog exempt car. You probably can figure out how I know all of the above..... |
Karl R |
Apr 3 2024, 07:04 PM
Newbie Group: Members Posts: 37 Joined: 25-July 23 From: honolulu Member No.: 27,486 Region Association: Southern California |
Also that is the wrong FI for your car. Your 1976 car should have a L jet instead of that D jet. Personally I prefer the L jet anyhow since it is quite a bit more mechanically robust in terms of all the connectors and wiring. I think the manifolds will have holes for three studs buy your heads will have four.
JeffBowlsby |
Apr 3 2024, 07:23 PM
Also that is the wrong FI for your car. Your 1976 car should have a L jet instead of that D jet. Personally I prefer the L jet anyhow since it is quite a bit more mechanically robust in terms of all the connectors and wiring. I think the manifolds will have holes for three studs buy your heads will have four. Um, no. 1976 914 2.0L GC code engines are DJet, 3 stud heads. The 912E is LJet maybe that’s what you are thinking about. |
Apr 3 2024, 08:23 PM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
76 is djet.
I happen to have one here if you need pictures. Rich |
Karl R |
Apr 4 2024, 04:39 PM
I guess I'm starting to slip. I thought they stopped the 2.0 in 74 and 75 and 76 were only the 1.8. My 75 was a 1.8, but now what I think about it my wife had a 2.0 75. Did OP state what he has?
Apr 4 2024, 05:31 PM
I guess I'm starting to slip. I thought they stopped the 2.0 in 74 and 75 and 76 were only the 1.8. My 75 was a 1.8, but now what I think about it my wife had a 2.0 75. Did OP state what he has? I think 75-76 was all about getting rid of parts So 1.8, 2.0…djet, ljet. Whatever |
wonkipop |
Apr 4 2024, 06:10 PM
Advanced Member Group: Members Posts: 4,667 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Also that is the wrong FI for your car. Your 1976 car should have a L jet instead of that D jet. Personally I prefer the L jet anyhow since it is quite a bit more mechanically robust in terms of all the connectors and wiring. I think the manifolds will have holes for three studs buy your heads will have four. Um, no. 1976 914 2.0L GC code engines are DJet, 3 stud heads. The 912E is LJet maybe that’s what you are thinking about. yeah jeffs right. no 76 l jet 1.8s. but the 76 D jet california 2.0 is in fact identical to the 75 D jet californian. its not a different set up. we did discover in all the californian air resources board certification material that the 76 models though classified as 76 MY were allowed to conform with 75 MY standards under the provision that all cars were manufactured before jan 01 1976 calendar year. ie they were 1975 manfucture. this is in fact why the 76s are only a half year car. and similarly the 912E is also a half year car in terms of MY. the 912s conform to 76 MY CARB regs and in order to do that those engines ran the L jet not the 914s. the 912E is the second half of 1976 MY car. all were an interim provision until the 924 could arrive in the USA. it doesn't really help a 76 model year 914 owner with passing smog. as noted, its got to be all intact on the car. but in terms of obtaining the emissions equipment the 76 is exactly shared with the 75 but it does have to be the california engine not the 75 49 states engine. (IMG:style_emoticons/default/beerchug.gif) apparently (as reported by one member here) many years ago a deal was made with some 76 owners to be released with conforming to that 75 cut off year due to the technicality of the original CARB certification that accepted that 76 914s were for the purposes of certification 75. but since that time the authorities have cracked down and no longer allow that special case. EDIT you need the works for 76 california smog. cat. EGR. smog pump. even the exhaust system (semi exhaust reactor heat exchangers). the whole muffler set up which has the cat along with the EGR bleed tube. its a fair bit of stuff. and don't forget the emission sticker. someone posted here they want to see the emission sticker in the engine bay. (IMG:style_emoticons/default/screwy.gif) better off with a 75. same car. exactly same car. no smog obligations. |
Ron914 |
Oct 9 2024, 12:42 PM
Newbie Group: Members Posts: 5 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California |
Also that is the wrong FI for your car. Your 1976 car should have a L jet instead of that D jet. Personally I prefer the L jet anyhow since it is quite a bit more mechanically robust in terms of all the connectors and wiring. I think the manifolds will have holes for three studs buy your heads will have four. Um, no. 1976 914 2.0L GC code engines are DJet, 3 stud heads. The 912E is LJet maybe that’s what you are thinking about. yeah jeffs right. no 76 l jet 1.8s. but the 76 D jet california 2.0 is in fact identical to the 75 D jet californian. its not a different set up. we did discover in all the californian air resources board certification material that the 76 models though classified as 76 MY were allowed to conform with 75 MY standards under the provision that all cars were manufactured before jan 01 1976 calendar year. ie they were 1975 manfucture. this is in fact why the 76s are only a half year car. and similarly the 912E is also a half year car in terms of MY. the 912s conform to 76 MY CARB regs and in order to do that those engines ran the L jet not the 914s. the 912E is the second half of 1976 MY car. all were an interim provision until the 924 could arrive in the USA. it doesn't really help a 76 model year 914 owner with passing smog. as noted, its got to be all intact on the car. but in terms of obtaining the emissions equipment the 76 is exactly shared with the 75 but it does have to be the california engine not the 75 49 states engine. (IMG:style_emoticons/default/beerchug.gif) apparently (as reported by one member here) many years ago a deal was made with some 76 owners to be released with conforming to that 75 cut off year due to the technicality of the original CARB certification that accepted that 76 914s were for the purposes of certification 75. but since that time the authorities have cracked down and no longer allow that special case. EDIT you need the works for 76 california smog. cat. EGR. smog pump. even the exhaust system (semi exhaust reactor heat exchangers). the whole muffler set up which has the cat along with the EGR bleed tube. its a fair bit of stuff. and don't forget the emission sticker. someone posted here they want to see the emission sticker in the engine bay. (IMG:style_emoticons/default/screwy.gif) better off with a 75. same car. exactly same car. no smog obligations. Hello, I was reading your post and I am in California and purchased a 1976 914 that is a 49 state car that has a sticker on the drivers door jamb that say Non-Catalyist ,it does have a smog pump that I have just found a good replacement for .I have read many of your smog in California posts and have a question.My car was initially sold in Michigan,then moved to Colorado and finally was sold to someone in California in 1985 and has been registered in California continuously until 2019 when it was then donated to a cars for charity organization .I acquired it in 2022 . I am now in the process of trying to get it registered in California . I have 25K invested so far and it seems like I am fighting a losing battle based on all the posts I read on the subject of registering a 1976 model in California. My engine has been rebuilt and all the 49 state smog equipment is intact and working but no cat. What are your thoughts about my endeavor. Thank you Ron |
wonkipop |
Oct 9 2024, 04:15 PM
Also that is the wrong FI for your car. Your 1976 car should have a L jet instead of that D jet. Personally I prefer the L jet anyhow since it is quite a bit more mechanically robust in terms of all the connectors and wiring. I think the manifolds will have holes for three studs buy your heads will have four. Um, no. 1976 914 2.0L GC code engines are DJet, 3 stud heads. The 912E is LJet maybe that’s what you are thinking about. yeah jeffs right. no 76 l jet 1.8s. but the 76 D jet california 2.0 is in fact identical to the 75 D jet californian. its not a different set up. we did discover in all the californian air resources board certification material that the 76 models though classified as 76 MY were allowed to conform with 75 MY standards under the provision that all cars were manufactured before jan 01 1976 calendar year. ie they were 1975 manfucture. this is in fact why the 76s are only a half year car. and similarly the 912E is also a half year car in terms of MY. the 912s conform to 76 MY CARB regs and in order to do that those engines ran the L jet not the 914s. the 912E is the second half of 1976 MY car. all were an interim provision until the 924 could arrive in the USA. it doesn't really help a 76 model year 914 owner with passing smog. as noted, its got to be all intact on the car. but in terms of obtaining the emissions equipment the 76 is exactly shared with the 75 but it does have to be the california engine not the 75 49 states engine. (IMG:style_emoticons/default/beerchug.gif) apparently (as reported by one member here) many years ago a deal was made with some 76 owners to be released with conforming to that 75 cut off year due to the technicality of the original CARB certification that accepted that 76 914s were for the purposes of certification 75. but since that time the authorities have cracked down and no longer allow that special case. EDIT you need the works for 76 california smog. cat. EGR. smog pump. even the exhaust system (semi exhaust reactor heat exchangers). the whole muffler set up which has the cat along with the EGR bleed tube. its a fair bit of stuff. and don't forget the emission sticker. someone posted here they want to see the emission sticker in the engine bay. (IMG:style_emoticons/default/screwy.gif) better off with a 75. same car. exactly same car. no smog obligations. Hello, I was reading your post and I am in California and purchased a 1976 914 that is a 49 state car that has a sticker on the drivers door jamb that say Non-Catalyist ,it does have a smog pump that I have just found a good replacement for .I have read many of your smog in California posts and have a question.My car was initially sold in Michigan,then moved to Colorado and finally was sold to someone in California in 1985 and has been registered in California continuously until 2019 when it was then donated to a cars for charity organization .I acquired it in 2022 . I am now in the process of trying to get it registered in California . I have 25K invested so far and it seems like I am fighting a losing battle based on all the posts I read on the subject of registering a 1976 model in California. My engine has been rebuilt and all the 49 state smog equipment is intact and working but no cat. What are your thoughts about my endeavor. Thank you Ron Hmmm, don't really know the ins and outs of california regarding registering 49 states cars back in the 80s. maybe you could do it as a resident if you had come in from out of state as the owner of the car in that other state prior.. or maybe by 85 you did not need to take your car in for smog by that point in time. though against that argument i do recall i had to smog my 74 49 states 1.8 when i lived in chicago. that was 1990 so i was still required to smog it. i seem to remember that chicago was one of those cities that maintained stricter smog laws (in terms of testing) than many other non california major cities. my feeling is you would only stand a chance of registering it and passing smog if it had the california certification emissions stickers and conformed to the specs of those stickers and what CARB has on file regarding the equipment and specs. so it would need a catalyst sticker in the door jamb. and the yellow emissions sticker usually on the engine fan casting i think in 75 and 76 would also have to conform to the california spec. the emission stickers do i believe note the engine families as different. i'm more abreast of L jet stuff than D jet. and of course there are no L jet 1.8s for 76 MY. but jeff bowlsby as the 76 D jet stuff on his website. the 49 states car is noted as engine family 17. with emissions equipment noted on sticker as EM/EFI/AIR. that translates as Engine Management, Electronic Fuel Injection/Air Pump. engine management and Electronic Fuel Injection is the catch all for the D jet system less the additional items that went on in 75 on. the california car is noted as engine family 18. with emissions equipment noted on sticker as EM/EFI/AIR/EGR/CAT. so not only did they have an air pump as per 49 states, they also had an exhaust gas recirculation system along with cat. i did read something once from a member here a few years back saying that he was looking for the correct emissions sticker for his car as the authorities were being that pendantic. it even it had to have the emissions sticker along with equipment. my feeling is you are probably up against a bureaucracy that wants to see it all one way and take the cars off the road. i mean i read the news here and you get the sense that california is real zealot territory when it comes to environmental laws. so maybe your chances are not good. esp since all records would indicate the car was a 49 state car to begin with and never in its life conformed to the CARB regulations. |
JeffBowlsby |
Oct 9 2024, 05:15 PM
For smog purposes CA-only model 1975-76 914s also had a 'Fuel Cutoff on Deceleration' system which consisted of a 'Speed Limiter box' (its a computer not a relay), and it plugs into the FI harness. It works in conjunction with a 1975-76 ECU and monitors speed characteristics at the FI trigger points, deciding when to stop fuel. I make that FI harness if needed. SL box image below, it lives just below the battery area in the engine bay had has a dedicated branch on the wiring harness with a 6-pole connector.
Emissions reqs are summarized here: https://bowlsby.net/914/Classic/Emissions.htm Attached image(s) |
wonkipop |
Oct 9 2024, 08:06 PM
@Ron914
here is what CARB would have on file for the 76. its all the bits they are looking for listed with part numbers. can't see that part number of the item mr. b has posted. but i am sure it will be there somewhere somehow. mr. b would know. they are noting some items enrichment sensor and pressure sensor. whether these are the same thing not sure. not really up on the old D jet or the complications of CARB emissions. i do know that all the components are shared from 75 to 76 and do not change. ie a 75 calif = a 76 calif. and a 75 49 states = a 76 49 s. but the big thing is that a 75 calif and 75 49 states are different beasts. |
Ron914 |
Oct 10 2024, 04:58 PM
@Ron914 here is what CARB would have on file for the 76. its all the bits they are looking for listed with part numbers. can't see that part number of the item mr. b has posted. but i am sure it will be there somewhere somehow. mr. b would know. they are noting some items enrichment sensor and pressure sensor. whether these are the same thing not sure. not really up on the old D jet or the complications of CARB emissions. i do know that all the components are shared from 75 to 76 and do not change. ie a 75 calif = a 76 calif. and a 75 49 states = a 76 49 s. but the big thing is that a 75 calif and 75 49 states are different beasts. Thank you bothT for your advice ,this was not the news I was hoping to hear . I somehow assumed since this was a 49 state car that has been continuously registered and smogged for 34 years in California that as long as I had all the original equipment installed and working it would pass a smog check as it has since 1985 . I have spent more than I thought on this car than I thought to get back on the road and I'm starting to think I should just try to sale in another state and look for another one .I am going to just take it in to a star station and see what happens and if its possible to get a wavier as a 49 state car . I wish I could ask the previous owner how he was getting it to pass a smog check for 34 years but that is not possible . |
Lo-Fi Version | Time is now: 22nd December 2024 - 12:02 AM |
