jmargush |
Member ![]() ![]() Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 ![]() |
I'm in the process of putting 911 brakes up front.
I have 2 sets of calipers and noticed one at has a wider space between the 2 caliper halves than the other set. Are there different thicknesses of rotors or what is the purpose and how do I know which one to use? Just test fit and use prices of elimination I suppose? Attached thumbnail(s) ![]() |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
What rotors are you using? vented or not?
Easiest way is to ask Eric at PMBPerformance. OR Stick pads in there, use clamps to push the pads all the way open...measure between pads. Do both calipers do both rotor types. Rich |
jmargush |
I'll be using vented rotors.
Guess I will mock up the assembly |
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 881 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
No expert here, but I believe, pre 78 are 24mm and post 77 26mm, but not exactly sure. But I am sure the earlier rotors were a bit thinner.
Freezin 914 |
I am pretty sure your set up is a 74’ Bilstein, with A calipers. Then the other set is a wide A. Again, hopefully some more people chime in.
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,331 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Early is 20mm, Carrera is 24mm
Freezin 914 |
Early is 20mm, Carrera is 24mm I knew someone knew the deal!! Ha! (IMG:style_emoticons/default/beerchug.gif) |
Early is 20mm, Carrera is 24mm I knew someone knew the deal!! Ha! (IMG:style_emoticons/default/beerchug.gif) Do those calipers have the same spacing - 3” or 3.5” What front hubs are you using? Eric is the one to ask regarding all the compatibility. |
Freezin 914 |
Early is 20mm, Carrera is 24mm I knew someone knew the deal!! Ha! (IMG:style_emoticons/default/beerchug.gif) Do those calipers have the same spacing - 3” or 3.5” What front hubs are you using? Eric is the one to ask regarding all the compatibility. All 3.5” Maybe Jeff will chime in…..not sure if he has different parts from what I had sold him. |
jmargush |
Early is 20mm, Carrera is 24mm I knew someone knew the deal!! Ha! (IMG:style_emoticons/default/beerchug.gif) Do those calipers have the same spacing - 3” or 3.5” What front hubs are you using? Eric is the one to ask regarding all the compatibility. All 3.5” Maybe Jeff will chime in…..not sure if he has different parts from what I had sold him. Nope still same parts you sold me! Getting closer to putting out all together! |
jmargush |
So 7.2mm spacer = 24mm gap in caliper for rotor
11.2mm spacer= 27.5mm gap in caliper for rotor My rotor thickness measures just over 20mm. There aren't different hat heights on the rotor are there? |
jmargush |
Next question
Should this inner bearing slide on or does it need to be driven on slightly? Attached thumbnail(s) ![]() |
jmargush |
another question
the spacers between the caliper halves, should those stay matched to the calipers or can they switched? If caliper #1 was a wide and caliper #2 is normal is it ok to swap the spacers and make caliper #2 the wide one? |
another question the spacers between the caliper halves, should those stay matched to the calipers or can they switched? If caliper #1 was a wide and caliper #2 is normal is it ok to swap the spacers and make caliper #2 the wide one? Spacers can be switched to at least some extent. For example, I gave Eric a rear M caliper and a 914-6 caliper. He used the spacer and hardware from the M caliper to remake the six caliper into a 914-6GT caliper. But again, I would go to Eric for exact specs. |
jmargush |
One more 911 caliper question.
Are there rights and lefts on the front Wide A calipers?or are they interchangeable? I would assume in order to get the bleeder on the top when mounted. |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:43 PM |
