she's back home!, in a fresh coat of epoxy primer |
Jeroen |
Aug 25 2005, 07:16 AM
yep... it is 1/2 an inch up
Brad advised me to mount it 1/2" up if I was going to run headers on a low car to make sure I got enough ground clearance... |
DNHunt |
Aug 25 2005, 07:23 AM
Oh man Jeroen, when I saw that post about it being too high my stomach flipflopped. I had visions of trying to grind those welds.
Now, that looks Mavvvelous. Dave |
Jeroen |
Aug 25 2005, 01:09 PM
I figured, worse case scenario, I could put a 1/2" washer under the mounts and use longer bolts to lower it back
I did forget one thing though... I should have grinded a vent hole at the bottom center of the welded piece I fear it's going to be a water trap (I'm not using any engine tin, so there's quite an exposed scoop (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) ) |
Jeroen |
Aug 25 2005, 05:32 PM
well, instead of just sittin' here glaring at my monitor, I got off my ass and put the (old) engine in the car for mock up
went in smooth and fits like a glove just took me 20min (no help) so that explains the smug grin (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/uploads/blog-1125012194.jpg) (IMG:http://www.914world.com/bbs2/uploads/blog-1125012211.jpg) (IMG:http://www.914world.com/bbs2/uploads/blog-1125012221.jpg) |
root |
Aug 25 2005, 06:28 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
Looks awesome! Keep the pics coming...great job! (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Makes me want to start a 6 project next....... but the 'BIG TIV' is first in line!.. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:40 PM |
