Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,491 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
I need to replace the original cloth covered hoses underneath the brake reservoir. Anyone know what specs it needs to be? Is it something local FLAPS will have or needs to be ordered?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
It's hydraulic rated hose. If you don't use that it will dissolve over time.
We stock them cut to length You may need a set for upper and lower. https://914rubber.com/brake-hose-9mm-set-of-2 Attached image(s) ![]() |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:43 PM |
