Quick brake master installation question - washers? |
burlybryan |
Apr 25 2024, 10:26 AM
Member Group: Members Posts: 102 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
I've got the non-easy install 914Rubber brake master cylinder. From the installation videos I've seen, there should be small metal washers between the MC and the rubber grommets for the supply lines. Do these exist within my original MC to be re-used? The new one (bought a while ago before they offered the easy install version) didn't come with them.
Thanks. |
rjames |
Apr 25 2024, 12:28 PM
I'm made of metal Group: Members Posts: 3,926 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Deleted
Apr 25 2024, 02:06 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The washers that go under the lines will be present in your old mc and are fine to reuse. They are not crush washers like the ones on the side. They absolutely have to be there for your brakes to function properly and not leak.
914werke |
Apr 25 2024, 02:27 PM
"I got blisters on me fingers" Group: Members Posts: 10,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
fiacra |
Apr 25 2024, 03:12 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 315 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
I've got the non-easy install 914Rubber brake master cylinder. From the installation videos I've seen, there should be small metal washers between the MC and the rubber grommets for the supply lines. Do these exist within my original MC to be re-used? The new one (bought a while ago before they offered the easy install version) didn't come with them. Thanks. I'll add my voice to the chorus. You need them, and they are not the crush washers that go on the banjo fitting for the caliper supply lines. They came with my 914Rubber non-easy install MC and were in a small ziploc bag. Easy to lose, especially if you bought the part several years ago. Give 914Rubber a call and I'll bet they'll send you some more. I'm not a big fan of reusing easily replaceable parts, but that advice came from a more experienced member so I'm sure it's ok to reuse the old ones. Have fun getting the grommets in place. I lubed mine with a bit of brake fluid and that really helped. I used a pair of right angle pliers to push them down in place. That was the hardest part of the job... A Motiv pressure brake bleeder and three quarts of brake fluid were needed to get all the air out of the system. Have fun! |
burlybryan |
Apr 26 2024, 08:01 AM
Thanks guys. Appreciate the detailed replies. Wish me luck!
dr914@autoatlanta.com |
Apr 26 2024, 10:15 AM
914 Guru Group: Members Posts: 7,840 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
those are stainless and very important to help seat the two supply lines.
I've got the non-easy install 914Rubber brake master cylinder. From the installation videos I've seen, there should be small metal washers between the MC and the rubber grommets for the supply lines. Do these exist within my original MC to be re-used? The new one (bought a while ago before they offered the easy install version) didn't come with them. Thanks. |
rjames |
Apr 26 2024, 10:58 AM
Appreciate the correction. I deleted my post with the incorrect info.
rjames |
Lo-Fi Version | Time is now: 9th May 2024 - 03:10 AM |
