Blocking one wheel for valve adjustment., On a lift - how do YOU do it? |
FlacaProductions |
Apr 25 2024, 04:38 PM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I get if you're doing valve adjustments by putting just one side of the car up but if you're on a lift (I have an EZCar Lift) it's a bit awkward for me to stop one wheel from turning (with my foot) while spinning the other to get to the next adjustment point.
Anyone use a ratchet strap or similar? Seems a floor jack under the wheel would just get pushed out of the way... Thanks, Brian |
Root_Werks |
Apr 25 2024, 04:41 PM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Not for valve adjustments, but had good luck with a block of wood in front of wheel rotation. The block tries to get sucked under the wheel and stops it.
Assuming the wheel isn't that high off the floor. |
infraredcalvin |
Apr 25 2024, 04:42 PM
Distracted Member Group: Members Posts: 1,511 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I've jammed a jack in there, really just found a valley on the jack to support both sides, there's not much torque when spinning the wheels, unless you have an lsd...
Geezer914 |
Apr 25 2024, 04:43 PM
Geezer914 Group: Members Posts: 1,394 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Nylon strap through the wheel and attached to something stationary.
FlacaProductions |
Apr 25 2024, 04:53 PM
mgphoto |
Apr 25 2024, 07:00 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Pull the pin on the emergency brake cable on one wheel, pull up the handle and you can spin the wheel that is not locked by the brake.
GregAmy |
Apr 25 2024, 07:07 PM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
technicalninja |
Apr 25 2024, 07:45 PM
Senior Member Group: Members Posts: 1,195 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif)
I've been using one of these for decades! Sadly, modern cars often have no access to the starter anymore. But modern cars often have a starter relay in the electrical junction box and with a couple of .250 spades you can get it done. I have turned engines over via "in gear" and push the whole car but I've not turned one via the lock one wheel and turn the other wheel. It should work fine! I have found that if you have a vehicle that you cannot push by hand most of the time you CAN move it by rotating on the tire instead of pushing on the body. I have moved 1-ton duallies around by myself using the "rotate the tires" trick. For turning engines, once you've used a bump starter you never go back... The one Greg linked to is decent and budget friendly. I think I paid the same amount 30+ years ago! |
Spoke |
Apr 25 2024, 07:46 PM
I just used one of my ramps to stop the wheel. A cement block or 2 could be used.
Lifted the car and placed a ramp under one wheel and lowered the car until there was enough pressure on the ramp to keep the wheel from spinning. Still plenty of room to work under the car. |
fiacra |
Apr 25 2024, 08:07 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 315 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Exactly what I've done. Learned that technique from someone who makes their living working on vintage Porsche's. Works great, fast and easy. |
FlacaProductions |
Apr 26 2024, 12:15 AM
I have one and use it but haven't felt it was accurate enough.
I’ll try again! |
ChrisFoley |
Apr 26 2024, 04:13 AM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Iirc, a vice grip C clamp can be used to squeeze the parking brake lever on one caliper.
ClayPerrine |
Apr 26 2024, 11:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,442 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have one and use it but haven't felt it was accurate enough. I’ll try again! Why do you need to be that accurate? You take both valve covers off and use a remote starter button to bump the motor until the front exhaust valve on the left side is open. Then you go adjust the front exhaust valve on the right side. Repeat until you have all the valves adjusted. The cam only has 4 lobes, so if the valve on the left side is open, the valve on the right side is on the base circle. Right where you need it for valve adjustments. |
FlacaProductions |
Apr 26 2024, 11:37 AM
Understood - it just always seemed that it moved in large increments. I'll try it again...
JamesM |
Apr 26 2024, 10:38 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Trans in 5th gear, I just grab one wheel with one hand and spin the other.
brant |
Apr 27 2024, 09:35 AM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Agree with Clay
Remote starter Krusty method And quick Easy. |
rjames |
Apr 27 2024, 01:10 PM
I'm made of metal Group: Members Posts: 3,926 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Trans in 5th gear, I just grab one wheel with one hand and spin the other. (IMG:style_emoticons/default/agree.gif) I dislike bumping the starter when the car is on jack stands. |
FlacaProductions |
Apr 27 2024, 01:27 PM
Finally back to where the 914 is stored and got back into the 123 install today. Found that blocking the wheel is easier than I thought and was kind of surprised how little friction was needed to stop the rotation. A cinder block did the trick.
I HATE the stop-with-one-foot method....thanks for the suggestions. My 914 is at our other place and I only get time with it for short spurts so thinking and scheming and planning takes up the off-tine. |
Lo-Fi Version | Time is now: 9th May 2024 - 07:45 AM |
