WTB Used functional 914 rotisserie, Near Tampa to Orlando area |
69146 |
Apr 26 2024, 02:16 PM
I'm new here ... Group: Members Posts: 0 Joined: 18-August 23 From: Oldsmar Member No.: 27,532 Region Association: None |
Doing a full restoration build of a 4 to6 gt. At the media blasting stage. Will also rent if you don’t want to sell. Thanks!!
JeffBowlsby |
Apr 26 2024, 06:07 PM
914 Wiring Harnesses Group: Members Posts: 8,492 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Doing a full restoration build of a 4 to6 gt. At the media blasting stage. Will also rent if you don’t want to sell. Thanks!! Considered making your own? Even without welding skills, simple wood frames give good access. A couple examples, there are more. Attached thumbnail(s) Attached image(s) |
Apr 26 2024, 06:12 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Did not put it on a rotisserie until you completely fix the longs. Door bars aren’t enough to secure a compromised car.
69146 |
Apr 26 2024, 07:57 PM
Doing a full restoration build of a 4 to6 gt. At the media blasting stage. Will also rent if you don’t want to sell. Thanks!! Considered making your own? Even without welding skills, simple wood frames give good access. A couple examples, there are more. Thx! Great ideas!! |
Lo-Fi Version | Time is now: 9th May 2024 - 06:41 AM |
