Fresh 2.7, doesn't want to wake up |
930cabman |
May 30 2024, 04:55 AM
Advanced Member Group: Members Posts: 3,511 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
She lives (IMG:style_emoticons/default/piratenanner.gif) Spark timing was retarded by probably one tooth. There are many details to be worked out, carbs, fuel pump, generator light, .... but I can tell by the sound, she is going to rock (IMG:style_emoticons/default/piratenanner.gif) It feels good, right? Congrats!!!! Let the six 914 run with the wild Porsche.... Matt (IMG:style_emoticons/default/flag.gif) Good is much understated, how about SUPER, after mucho $$, several years, many brain cells, ...... Now I just need to sort a couple things and might be rolling down the road this weekend. The taste of victory is very good, and the sound of a six (IMG:style_emoticons/default/happy11.gif) |
Root_Werks |
May 30 2024, 09:29 AM
Village Idiot Group: Members Posts: 8,414 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Very glad this had a happy ending! Or rather a beginning of a six!
(IMG:style_emoticons/default/driving.gif) |
930cabman |
May 30 2024, 03:14 PM
Thank you to all contributors, she is running decent, now onto the Webers and then I will be done, but are we ever done (IMG:style_emoticons/default/lol-2.gif)
flyer86d |
May 30 2024, 03:32 PM
Member Group: Members Posts: 440 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
As I found out on my 2.7, set up the Webers on initial settings. I found them on line, set the fuel pressure at 3 psi and then adjust till it runs as you like it. We have all gotten used to fuel injected motors which magically start and run. But set up close to right, Webers work great. It just takes some futzing and a lot of patience.
Charlie |
930cabman |
May 31 2024, 08:08 AM
As I found out on my 2.7, set up the Webers on initial settings. I found them on line, set the fuel pressure at 3 psi and then adjust till it runs as you like it. We have all gotten used to fuel injected motors which magically start and run. But set up close to right, Webers work great. It just takes some futzing and a lot of patience. Charlie I have been running Webers on several different sporting cars for many years, with success. Yes, they can be touchy, but I like the simplicity of them. When a modernish FI system is working correctly, there is probably nothing better. I am getting different air flow numbers from my snail when comparing from venturi to venturi. Is this a sign the air adjusters need attention? I have always had these closed, but have never had a venturi to venturi difference in air flow. This is my first go with 3V carbs. |
930cabman |
Jul 7 2024, 08:37 AM
She lives (IMG:style_emoticons/default/piratenanner.gif) Spark timing was retarded by probably one tooth. There are many details to be worked out, carbs, fuel pump, generator light, .... but I can tell by the sound, she is going to rock (IMG:style_emoticons/default/piratenanner.gif) It feels good, right? Congrats!!!! Let the six 914 run with the wild Porsche.... Matt (IMG:style_emoticons/default/flag.gif) Yes, she lives and I have logged in maybe an hour of run time including a short ride. I have a hard piped oil pressure gauge and it reads ok. Changing the oil and filter yesterday, I found the oil filter dry. 0 oil. I pulled the console and everything lines up. What could I be missing, other than a few brain cells |
mate914 |
Jul 7 2024, 09:00 AM
Matt Group: Members Posts: 782 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
She lives (IMG:style_emoticons/default/piratenanner.gif) Spark timing was retarded by probably one tooth. There are many details to be worked out, carbs, fuel pump, generator light, .... but I can tell by the sound, she is going to rock (IMG:style_emoticons/default/piratenanner.gif) It feels good, right? Congrats!!!! Let the six 914 run with the wild Porsche.... Matt (IMG:style_emoticons/default/flag.gif) Yes, she lives and I have logged in maybe an hour of run time including a short ride. I have a hard piped oil pressure gauge and it reads ok. Changing the oil and filter yesterday, I found the oil filter dry. 0 oil. I pulled the console and everything lines up. What could I be missing, other than a few brain cells 0 oil is odd. Maybe the oil filter has to be the one for the same console? You need to find a 911 guru, witch I am not. Matt |
IronHillRestorations |
Jul 7 2024, 09:08 AM
I. I. R. C. Group: Members Posts: 6,758 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
@930cabman check your oil lines. Sounds like you have an obstruction in the oil lines. I have had a stainless braid hose that internally broke down and collapsed, closing it.
sixnotfour |
Jul 7 2024, 09:13 AM
914 Wizard Group: Members Posts: 10,512 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the bypass for the oil filter is in the console ,, stuck open ??,,odd..,,
sixnotfour |
Jul 7 2024, 09:23 AM
top right,
Attached thumbnail(s) |
mb911 |
Jul 7 2024, 09:46 AM
914 Guru Group: Members Posts: 7,149 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
What console do you have? I have seen reports on the bird board recently that the filters being made go full bypass very easily
930cabman |
Jul 7 2024, 11:57 AM
What console do you have? I have seen reports on the bird board recently that the filters being made go full bypass very easily IIRC, the console is from PMS and the Mahle filter is from China. I will check the console and filter. Was driving me more crazy than usual Thanks all |
930cabman |
Jul 7 2024, 11:58 AM
@930cabman check your oil lines. Sounds like you have an obstruction in the oil lines. I have had a stainless braid hose that internally broke down and collapsed, closing it. Everything is new from PMS |
mate914 |
Jul 7 2024, 12:22 PM
@930cabman check your oil lines. Sounds like you have an obstruction in the oil lines. I have had a stainless braid hose that internally broke down and collapsed, closing it. Everything is new from PMS The oil console is new? Made where? Matt |
930cabman |
Jul 7 2024, 02:35 PM
What appears to be some sort of pressure valve inside the new Mahle oil filter has apparently malfunctioned. The oil filter console is straight through, so no possibility of an issue there. I had another Mahle oil filter on the shelf and looking into the center opening it looked different. I plugged it all together and now the oil is flowing through the filter (warm to the touch) and my hard wired oil pressure gauge is reading differently.
Victory and she barks nicely. thanks all |
mb911 |
Jul 7 2024, 02:47 PM
What appears to be some sort of pressure valve inside the new Mahle oil filter has apparently malfunctioned. The oil filter console is straight through, so no possibility of an issue there. I had another Mahle oil filter on the shelf and looking into the center opening it looked different. I plugged it all together and now the oil is flowing through the filter (warm to the touch) and my hard wired oil pressure gauge is reading differently. Victory and she barks nicely. thanks all Mann filters are the only option now a days. I have some Mahle left but once they are gone it’s all gonna be Mann |
930cabman |
Jul 7 2024, 03:20 PM
Been wrenching for 50+ years, never seen an oil filter close down. I have a couple Mahle filters left on the shelf, will probably go with NAPA Gold maybe sooner than later
Is the purpose to protect from over pressurizing? |
sixnotfour |
Jul 7 2024, 03:51 PM
is this an oc 54..not the early filter.
930cabman |
Jul 7 2024, 03:56 PM
is this an oc 54..not the early filter. If memory serves, yes OC 54. Kinda sad, I just did this a few hours ago. Guess this is a benefit to aging (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
sixnotfour |
Jul 7 2024, 04:00 PM
is this an oc 54..not the early filter. If memory serves, yes OC 54. Kinda sad, I just did this a few hours ago. Guess this is a benefit to aging (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) All good ,,Some things are not worth remembering.. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 16th September 2024 - 12:56 PM |
