CCE |
CCE ![]() ![]() Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille ![]() ![]() |
Glad you got her fixed. I just came upon this thread and when I read "cuts out on acceleration" I was thinking voltage regulator. I have seen my factory voltage gauge indicating over 14v often. Probably not an issue for factory stuff. Yes I also had a couple of coil packs blown in the past, and had the idea it was a defective batch from CB performance, but now I see it was my autozone voltage regulator allowing peaks of power trough. The amp evidenced it more clearly. ![]() |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,342 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
CCE |
To all who replied to my questions, I want to thank you all for the support and also I wanted to comment on the Amp.
After I sorted the issues caused by my installation, me, and my car regulator, I finally had a chance to use it, and I highly recommend it. Power will not bleed your ears, just will sound fine, with enough power for my “low-end” Focal speaker sets, bass works deep and natural. Not as specified 100w X 4 by blaupunkt, but for $110usd I think is good. I also installed a kill switch to turn off the amp If I don’t want to use it, connected to the remote turn on on the amp to my fuse box. I liked the black-out faceplate from 914rubber, and the simple original look to it. The amp is small enough to fit where my old stereo was, wiring was done with an amp install kit also from blaupunkt I also got as the amp from Amazon, and cable caps, very simple install. I really have very limited talent, and just liked my end result. Finally, Just FYI all speaker grills and doors where already broken when I got the car, I just replaced the old rotted speakers with new ones because I wanted to hear my phone tunes. (IMG:style_emoticons/default/driving.gif) ![]() |
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,875 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
"I really have very limited talent, and just liked my end result."
"Don't sell yourself short kiddo" as Humphrey Bogart used to say. "Keep learning & have fun" is what I say. Electronics are far more complicated than most people understand. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:52 PM |
