DennisV |
Member ![]() ![]() Group: Members Posts: 499 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
Can anyone tell me the length of part number 901-108-648-00? It is #19 in the parts book diagram for 914-6 Weber IDTP carbs pull rod. Thanks.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Dennis I believe the one at the top with the fixed nut on the shaft is OE '6' It has infinite adjustment 'in place' with reverse thread in one end.
The others would work too. Attached thumbnail(s) ![]() |
DennisV |
Dennis I believe the one at the top with the fixed nut on the shaft is OE '6' It has infinite adjustment 'in place' with reverse thread in one end. The others would work too. Super helpful! I appreciate you taking time to post this. Thanks for pointing out the fixed nut. I am guessing that is the #26 push rod if you trust the parts catalog drawing. The other two the pull rod #19. |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:34 PM |
