New here couple questions?, new owner, questions brake lights, search help |
thecleanoutking |
May 19 2024, 07:25 PM
Newbie Group: Members Posts: 21 Joined: 8-May 24 From: Florida Member No.: 28,109 Region Association: South East States |
Greetings all, I recently purchased a 1974 914 with a stock 1.8 FI I found this forum in doing research on parts and tech advice. So I signed up and here I am..
I do belong to a few other sites that are helpful with other cars and I seem to be having issues when searching .. So it may be user error but I seem to be having trouble when search on here.. Currently trying to figure out why I have no brake lights, so I simply searched on here "No Brake Lights" or brake switches or brake lights.. I get thousands of threads and sometimes it will take me reading dozens of post's just to find anything related.. Maybe I'm searching wrong, I usually just go on the main page and hit search and type in a term.. Am I doing something wrong, any and all help is appreciated |
Shivers |
May 19 2024, 07:57 PM
Senior Member Group: Members Posts: 2,478 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
thecleanoutking |
May 19 2024, 08:03 PM
Thanks that did work better then just searching inside the forum, also realize I need a Haynes manual....ordering one now...Thx |
Shivers |
May 19 2024, 08:05 PM
Thanks that did work better then just searching inside the forum, also realize I need a Haynes manual....ordering one now...Thx Car looks nice. (IMG:style_emoticons/default/welcome.png) |
Resident German Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Currently trying to figure out why I have no brake lights, so I simply searched on here "No Brake Lights" or brake switches or brake lights.. (IMG:style_emoticons/default/welcome.png) Did you actually put quotes around your search terms? Because when i search for "No Brake Lights" with quotes, i only get 3 pages worth of results. From the search page: |
FlacaProductions |
May 19 2024, 08:12 PM
Senior Member Group: Members Posts: 1,642 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Welcome!
Bookmark this link and use the search field as usual: https://cse.google.com/cse?cx=0024083458981...772:ajvfxschcgc |
windforfun |
May 19 2024, 08:31 PM
Senior Member Group: Members Posts: 1,875 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
That link goes no where. Did you check the light bulbs? The switch at the master cylinder might be bad. How many miles are on the car?
thecleanoutking |
May 19 2024, 08:45 PM
Thanks "quotations" around the term help as well, I did not do that at first, thanks.. yes, checked bulbs, fuses, I suspect the switch at the pedal but not 100% sure how to test a switch, searching now..
May 19 2024, 09:03 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Power to rear tail lights is on the drivers side in the engine bay..
Then to the relay board Then to the pedal Then to the fuse Test at all locations for power. Quick test, based upon how nice the car looks would be your grounds at the taillights them selves. Btw, find all the main grounding points, clean them well…it’s 50 years old And Jeff’s site https://bowlsby.net/914/WiringHarnesses/ |
thecleanoutking |
May 19 2024, 09:56 PM
Power to rear tail lights is on the drivers side in the engine bay.. Then to the relay board Then to the pedal Then to the fuse Test at all locations for power. Quick test, based upon how nice the car looks would be your grounds at the taillights them selves. Btw, find all the main grounding points, clean them well…it’s 50 years old And Jeff’s site https://bowlsby.net/914/WiringHarnesses/ |
Van B |
May 19 2024, 10:01 PM
Senior Member Group: Members Posts: 1,614 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Awesome, another original 1.8!
You have a few of us on here keeping these things alive as designed |
wonkipop |
May 20 2024, 02:48 AM
Advanced Member Group: Members Posts: 4,432 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Awesome, another original 1.8! You have a few of us on here keeping these things alive as designed yeah but there is a price for helping. he has to give wonkipop vital historical data concerning his car and feed it down the historical rabbit hole. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) no worries @thecleanoutking we can help you. and there is even a topic in the originality section that will tell you everything about your 74 1.8 you never wanted or needed to know. (IMG:style_emoticons/default/beerchug.gif) nice looking car. (IMG:style_emoticons/default/beer3.gif) |
930cabman |
May 20 2024, 04:55 AM
Advanced Member Group: Members Posts: 3,198 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Great find and the boys/girls here will be very helpful. Starting with a Haynes manual is a good start |
Spoke |
May 20 2024, 05:14 AM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Besides wiring and a fuse, the brake lights are controlled by a switch under the pedal board in the cabin connected to the brake pedal. Maybe start there. |
thecleanoutking |
May 20 2024, 07:19 AM
Thanks, everyone for the words of encouragement..
I've always loved these cars and being a VW man I actually had a bus with a similar motor once which my friend an I rebuilt. Obviously I can tell right off the bat I see many differences.. This car was somewhat of an impulse buy, wasn't really even looking just searching marketplace one morning as I do most mornings and I saw it listed 30 min ago in the next town over.. I did a little boning up online about what to look for, shot over looked it over drove it made the guy an offer he said yes.. I wish I'd have done a bit more looking it over and the guy selling it was a little bit of a fast talking salesman who kinda lied about a few things but all in all its a pretty solid car with everywhere i look it doesn't seem to be missing a lot.. The paint job re-sell red looks nice but its a fast job with lots of sprayed bolts, and a few places they didn't tape so good but its mine now.. After day one when I broke the door handle off in my hand I wasn't so sure but now a few weeks in i'm starting to love and admire her more and more, so i think I'll stick with it for a while.. Glad this place and you all are here to help, thanks.. |
Shivers |
May 20 2024, 12:48 PM
Thanks, everyone for the words of encouragement.. I've always loved these cars and being a VW man I actually had a bus with a similar motor once which my friend an I rebuilt. Obviously I can tell right off the bat I see many differences.. This car was somewhat of an impulse buy, wasn't really even looking just searching marketplace one morning as I do most mornings and I saw it listed 30 min ago in the next town over.. I did a little boning up online about what to look for, shot over looked it over drove it made the guy an offer he said yes.. I wish I'd have done a bit more looking it over and the guy selling it was a little bit of a fast talking salesman who kinda lied about a few things but all in all its a pretty solid car with everywhere i look it doesn't seem to be missing a lot.. The paint job re-sell red looks nice but its a fast job with lots of sprayed bolts, and a few places they didn't tape so good but its mine now.. After day one when I broke the door handle off in my hand I wasn't so sure but now a few weeks in i'm starting to love and admire her more and more, so i think I'll stick with it for a while.. Glad this place and you all are here to help, thanks.. I think his name here is cabinetmaker, look him up he can help you with door handles and locks |
thecleanoutking |
May 20 2024, 01:40 PM
Oh..thanks...I already got one off ebay and installed it, the door panels very similar to some vw's I've had and everything went as expected....
Cost me about $100 with shipping for a nice used one.. Thanks, everyone for the words of encouragement.. I've always loved these cars and being a VW man I actually had a bus with a similar motor once which my friend an I rebuilt. Obviously I can tell right off the bat I see many differences.. This car was somewhat of an impulse buy, wasn't really even looking just searching marketplace one morning as I do most mornings and I saw it listed 30 min ago in the next town over.. I did a little boning up online about what to look for, shot over looked it over drove it made the guy an offer he said yes.. I wish I'd have done a bit more looking it over and the guy selling it was a little bit of a fast talking salesman who kinda lied about a few things but all in all its a pretty solid car with everywhere i look it doesn't seem to be missing a lot.. The paint job re-sell red looks nice but its a fast job with lots of sprayed bolts, and a few places they didn't tape so good but its mine now.. After day one when I broke the door handle off in my hand I wasn't so sure but now a few weeks in i'm starting to love and admire her more and more, so i think I'll stick with it for a while.. Glad this place and you all are here to help, thanks.. I think his name here is cabinetmaker, look him up he can help you with door handles and locks |
Van B |
May 20 2024, 05:28 PM
Can you show us the motor? I noticed a few things that are off for a 74 1.8
Steve |
May 20 2024, 05:54 PM
914 Guru Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) Besides wiring and a fuse, the brake lights are controlled by a switch under the pedal board in the cabin connected to the brake pedal. Maybe start there. (IMG:style_emoticons/default/agree.gif) Sometimes the little lever on the brake switch gets bent and the brake pedal doesn't actuate the switch. |
thecleanoutking |
May 20 2024, 08:53 PM
sure cause i'm not 100% sure its not a franken-porsche but little to no real rot
Here is the link to all the pics I have CLICK HERE! Can you show us the motor? I noticed a few things that are off for a 74 1.8 |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:51 PM |
