Artfrombama |
Member ![]() ![]() Group: Members Posts: 266 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Refinished my engine tins, would love to replace this decal. Is it reproduced?
1974 1.8 ![]() Thanks! |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,720 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Refinished my engine tins, would love to replace this decal. Is it reproduced? 1974 1.8 ![]() Thanks! thats the tune up sticker from an EC-B engine Art. shows two black hoses either side of the distributor. @StarBear made a small number repros of the one from the EC-A (california) engine which shows only one black hose on left aide of distributor. i think he was going to make some further repros which were for the EC-B engine like yours (and mine) but he may not have gotten around to it yet. if he has any EC-A ones left they are close but not exactly correct. (IMG:style_emoticons/default/beerchug.gif) as far as i know not made commercially or available anywhere apart from @StarBear 's stash. |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,107 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
@artfrombama
Yep; I have both. Just PM me with your address. I’ll send you two. They don’t last real long with the heat as they’re just inkjet on Avery labels with a spray coating. Fine each for 2-3 seasons. |
Artfrombama |
@artfrombama Yep; I have both. Just PM me with your address. I’ll send you two. They don’t last real long with the heat as they’re just inkjet on Avery labels with a spray coating. Fine each for 2-3 seasons. (IMG:style_emoticons/default/pray.gif) > @StarBear |
wonkipop |
@artfrombama Yep; I have both. Just PM me with your address. I’ll send you two. They don’t last real long with the heat as they’re just inkjet on Avery labels with a spray coating. Fine each for 2-3 seasons. (IMG:style_emoticons/default/pray.gif) > @StarBear @Artfrombama while you are snooping about down there at the tune up sticker. is there still a paint stencil number just off the left on the side of the tin. if it is there, does it say 604? yeah @Starbear is the man for minutia supplies. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/pray.gif) |
Artfrombama |
@artfrombama Yep; I have both. Just PM me with your address. I’ll send you two. They don’t last real long with the heat as they’re just inkjet on Avery labels with a spray coating. Fine each for 2-3 seasons. (IMG:style_emoticons/default/pray.gif) > @StarBear @Artfrombama while you are snooping about down there at the tune up sticker. is there still a paint stencil number just off the left on the side of the tin. if it is there, does it say 604? yeah @Starbear is the man for minutia supplies. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/pray.gif) ![]() |
wonkipop |
@artfrombama Yep; I have both. Just PM me with your address. I’ll send you two. They don’t last real long with the heat as they’re just inkjet on Avery labels with a spray coating. Fine each for 2-3 seasons. (IMG:style_emoticons/default/pray.gif) > @StarBear @Artfrombama while you are snooping about down there at the tune up sticker. is there still a paint stencil number just off the left on the side of the tin. if it is there, does it say 604? yeah @Starbear is the man for minutia supplies. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/pray.gif) ![]() ace mate. your car is a little beauty. ringy ding rigy. thanks for doing that. (IMG:style_emoticons/default/first.gif) |
L-Jet914 |
Member ![]() ![]() Group: Members Posts: 328 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California ![]() |
@artfrombama Yep; I have both. Just PM me with your address. I’ll send you two. They don’t last real long with the heat as they’re just inkjet on Avery labels with a spray coating. Fine each for 2-3 seasons. I wonder if there is a medium we can print on that is less susceptible to heat. I know there are some stickers that have a silver backing for heat resistance and using a color laser printer. I think the Toyota timing belt stickers are printed on something similar as they reside on the timing belt cover inside the engine compartment. Grant it the temperatures probably aren't as high in the engine compartment as an air cooled engine. |
wonkipop |
@artfrombama Yep; I have both. Just PM me with your address. I’ll send you two. They don’t last real long with the heat as they’re just inkjet on Avery labels with a spray coating. Fine each for 2-3 seasons. I wonder if there is a medium we can print on that is less susceptible to heat. I know there are some stickers that have a silver backing for heat resistance and using a color laser printer. I think the Toyota timing belt stickers are printed on something similar as they reside on the timing belt cover inside the engine compartment. Grant it the temperatures probably aren't as high in the engine compartment as an air cooled engine. https://tslgraphics.com/products/decals/hea...sistant-decals/ https://fastdecals.com/shop/custom-decals-a...ure-decals.html |
Lo-Fi Version | Time is now: 31st March 2025 - 04:49 PM |
