thecleanoutking |
Newbie ![]() Group: Members Posts: 21 Joined: 8-May 24 From: Florida Member No.: 28,109 Region Association: South East States ![]() |
I was trying to get to the brake switch at the pedal to rule out any issues there..
Oh boy!! posted another thread yesterday (someone said it was a bit of a wiggle job) I'd say.. just to get to the two allens that hold the kick board i had to basically remove the carpet, half my console and after all that I still can't get the kick board out.. The carpet had holes for the clutch pedal, brake pedal, accelerator pedal and even a separate hole for the rod behind the gas pedal (which I ended up just putting a slice into that small hole or I might still be there).. Now still can't get the kick board out but I lifted it and after removing a small mouse nest i can barley see what I think is the switch...man.. Should have started with the switch at the master?? why two switches any advice on the kick board and pedal switch? ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 07:50 AM |
