Late model Blue wire with Yellow stripe Dash location?, Where does this wire go? |
TINKERGINEERING |
May 24 2024, 10:30 PM
Member Group: Members Posts: 208 Joined: 15-March 20 From: Sierra Madre, CA Member No.: 24,031 Region Association: Southern California |
First 3 pics:
This has a small mental female blade connector and goes back to the white cylinder connector behind the firewall. under the dash near the Gagues, where does this connect to? Not on the diagram Last 3 pics of Bezel: also the two lights on the instrument gauge bezel I am missing 1 of them but what do they mean and what's the one I am missing? Basically, what are these and what do I label them? Thanks! Frances Attached thumbnail(s) |
L-Jet914 |
May 24 2024, 10:35 PM
Member Group: Members Posts: 277 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Catalytic converter temperature warning light and EGR reminder light. The 4 pin connector goes to the EGR/Cat timer box.
saladin |
May 25 2024, 12:21 AM
Member Group: Members Posts: 50 Joined: 18-September 07 From: Mountain View, CA Member No.: 8,125 Region Association: Northern California |
@TINKERGINEERING hopefully the below service manual current flow drawings clarify the connections.
Ken |
JeffBowlsby |
May 25 2024, 07:48 AM
914 Wiring Harnesses Group: Members Posts: 8,703 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
To answer the questions, what L-Jet914 and Saladin posted gets you there.
The blue/yellow wire attaches to a CAT light on the dash which you are missing. The EGR and CAT lights merely indicated when these items needed servicing. These are all components of the 1975-76 CA-only model, both 1.8L and 2.0L, that requires an EGR valve and catalytic converter for emissions. The CAT circuitry starts with a sensor to the CAT, and logic box 'relay' at the drivers side tailight area of the chassis harness, not shown in the photos above. More info here: https://bowlsby.net/914/Classic/Emissions.htm |
saladin |
May 25 2024, 10:40 AM
To answer the questions, what L-Jet914 and Saladin posted gets you there. The blue/yellow wire attaches to a CAT light on the dash which you are missing. The EGR and CAT lights merely indicated when these items needed servicing. These are all components of the 1975-76 CA-only model, both 1.8L and 2.0L, that requires an EGR valve and catalytic converter for emissions. The CAT circuitry starts with a sensor to the CAT, and logic box 'relay' at the drivers side tailight area of the chassis harness, not shown in the photos above. More info here: https://bowlsby.net/914/Classic/Emissions.htm @JeffBowlsby Is the J⁴² labeled as a relay for catalyst temperature control shown in the diagram the logic box 'relay' you mentioned; given the T⁴ connector is labeled as a quadruple cable connector in the rear luggage compartment and the G²⁰ is labeled as the catalyst temperature sensor which I assume is in the catalytic converter? Ken |
JeffBowlsby |
May 25 2024, 10:46 AM
QUOTE @JeffBowlsby Is the J⁴² labeled as a relay for catalyst temperature control shown in the diagram the logic box 'relay' you mentioned; given the T⁴ connector is labeled as a quadruple cable connector in the rear luggage compartment and the G²⁰ is labeled as the catalyst temperature sensor which I assume is in the catalytic converter? Ken Yes, exactly. |
May 25 2024, 01:36 PM
Resident German Group: Admin Posts: 41,845 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
TINKERGINEERING |
May 25 2024, 02:03 PM
yep there's that too haaa |
TINKERGINEERING |
May 25 2024, 02:06 PM
not on my diagram
Thanks for these print outs I am printing and saving. I want to get the CAT bezel light button just to have it there. may need to add some other meaning to it eventually. Hey thanks for all the responses and so fast. 914World is amazing |
Chris914n6 |
May 25 2024, 09:29 PM
Jackstands are my life. Group: Members Posts: 3,405 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
EGR - Energy Gone, Recharge (low watts)
CAT - Charging Amongst Teslas (charge in process) (IMG:style_emoticons/default/biggrin.gif) In case you didn't know, Tesla Superchargers is the only network that's populous, reliable and constantly maintained enough to make EV practical. The others are essentially a bad gamble. |
TINKERGINEERING |
Jun 6 2024, 04:00 PM
EGR - Energy Gone, Recharge (low watts) CAT - Charging Amongst Teslas (charge in process) (IMG:style_emoticons/default/biggrin.gif) In case you didn't know, Tesla Superchargers is the only network that's populous, reliable and constantly maintained enough to make EV practical. The others are essentially a bad gamble. Ohh perfect. Next time someone asks these are the responses now. Haa |
TINKERGINEERING |
Jun 6 2024, 04:02 PM
Catalytic converter temperature warning light and EGR reminder light. The 4 pin connector goes to the EGR/Cat timer box. The previous DC build guy removed all combustion bits.. Apearently including this sensor module. now the plug makes sense thanks for the great pic. Frances Dad gave a thumbs up too (IMG:style_emoticons/default/bye1.gif) |
rick 918-S |
Jun 7 2024, 05:16 AM
Hey nice rack! -Celette Group: Members Posts: 20,723 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I was on youtube wanting to see where you are at on your project but only came across a 1 year old video of a news reel. Any newer videos? Your getting closer to getting your license?
Geezer914 |
Jun 7 2024, 05:50 AM
Geezer914 Group: Members Posts: 1,736 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I wired the cat light to my oil cooler fan. The light comes on when the fan is running.
Lo-Fi Version | Time is now: 25th October 2024 - 06:01 PM |
