how to remove the windshield molding for 914, how to remove the windshield molding for 914 |
LUX-PIERRE |
Jun 14 2024, 03:56 AM
Newbie Group: Members Posts: 14 Joined: 8-August 11 From: BELGIUM Member No.: 13,416 Region Association: Europe |
Hi guys
(IMG:style_emoticons/default/unsure.gif) how to remove the windshield molding for 914 Thanks. Peter. |
rick 918-S |
Jun 14 2024, 05:31 AM
Hey nice rack! -Celette Group: Members Posts: 20,723 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
There are 19 plastic clips that hold the fragile trim. Slide a razor blade between the windshield frame/cowl top panel and the trim and cut the clips off. The clips are available but the trim is not. Don't try a windshield trim tool. You may get some of the clips loose but bending up the trim is almost certain.
friethmiller |
Jun 14 2024, 07:38 AM
Senior Member Group: Members Posts: 649 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
There are 19 plastic clips that hold the fragile trim. Slide a razor blade between the windshield frame/cowl top panel and the trim and cut the clips off. The clips are available but the trim is not. Don't try a windshield trim tool. You may get some of the clips loose but bending up the trim is almost certain. (IMG:style_emoticons/default/agree.gif) 100% |
76-914 |
Jun 14 2024, 10:11 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,616 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
An aftermarket trim is available. I just installed it last month. I forget the vendor presently but I'm sure I kept the receipt. (IMG:style_emoticons/default/beerchug.gif)
technicalninja |
Jun 14 2024, 11:14 AM
Senior Member Group: Members Posts: 1,945 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Thanks for posting!
This was a question I was going to ask when I removed mine. Now I don't have to. |
rick 918-S |
Jun 15 2024, 09:19 AM
Come to think of it Mark at 914rubber had some sets made I think.
dr914@autoatlanta.com |
Jun 15 2024, 10:09 AM
914 Guru Group: Members Posts: 8,092 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the razor blade works great, we have at least ten new windshield anodized trim kits in stock along with the windshield installation kit, we even have new aftermarket windshields now!!!! If you need tech advice we install the windshields and trim at least once a week in our 914 service shop
burton73 |
Jun 15 2024, 12:12 PM
burton73 Group: Members Posts: 3,658 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have a new windshield anodized trim kits in my 6 ( number 41) from Auto Atlanta that I bought several years ago, and it is perfect. The hard part is the shipping of these parts. They need a huge box because of the shape. They bend if you look at them funny.
Good hunting Best Bob B |
porschetub |
Jun 15 2024, 08:43 PM
Advanced Member Group: Members Posts: 4,728 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have a new windshield anodized trim kits in my 6 ( number 41) from Auto Atlanta that I bought several years ago, and it is perfect. The hard part is the shipping of these parts. They need a huge box because of the shape. They bend if you look at them funny. Good hunting Best Bob B They bend easy if they are used ,if you cut the clips do several test fits to make sure they fit ok before as removing with the new clips you are back to square one. Bought my roller with a new screen and clips ,was a nervous time when I was happy with used trim and finally clipped them on , but have some rust popping out after 4yrs on drivers side...as mentioned back to square one . As Bob mentioned shipping is an issue for a new set, to get to my side of the world is mental,we have a very strong classic car following in my country so as mine are a bit rough may prep them and get them refinished ...most likely cheaper. Cheers. |
mb911 |
Jun 16 2024, 06:45 AM
914 Guru Group: Members Posts: 7,200 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Just make sure to use Porsche clips when reinstalling the aftermarket ones break easier than a balsa wood airplane
LUX-PIERRE |
Jun 17 2024, 05:04 AM
Ok
Ok thank you, I understand! I thought the clips were made of steel? but how to put the clips back without removing the windshield? |
mb911 |
Jun 17 2024, 05:06 AM
rick 918-S |
Jun 17 2024, 05:47 AM
Lo-Fi Version | Time is now: 25th October 2024 - 06:00 PM |
