Has anyone sucessfully repaired a horn?, Fixed! Nothing to see here |
Artfrombama |
Jun 14 2024, 01:28 PM
Member Group: Members Posts: 189 Joined: 21-January 24 From: Alabama Member No.: 27,870 Region Association: South East States |
Can't get the horn to blow! Drilled out the eight rivets, disassembled, cleaned the points, coil checks out good. No bueno!
914werke |
Jun 14 2024, 01:49 PM
"I got blisters on me fingers" Group: Members Posts: 10,777 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Regularly. If the leads are still good typically the tension adjustment need to fiddled with.
DennisV |
Jun 14 2024, 01:54 PM
Senior Member Group: Members Posts: 543 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Can't get the horn to blow! Drilled out the eight rivets, disassembled, cleaned the points, coil checks out good. No bueno! I resurrected mine. I don't think the 356 or VW are much different than 914. Here are some great horn resources. Horn diagram information Horns HowTo Hella B31/6V Horn Restoration |
Artfrombama |
Jun 14 2024, 04:16 PM
Regularly. If the leads are still good typically the tension adjustment need to fiddled with. Can't get the horn to blow! Drilled out the eight rivets, disassembled, cleaned the points, coil checks out good. No bueno! I resurrected mine. I don't think the 356 or VW are much different than 914. Here are some great horn resources. Horn diagram information Horns HowTo Hella B31/6V Horn Restoration Success! Dirty spade connector |
Lo-Fi Version | Time is now: 25th October 2024 - 06:00 PM |
