Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,713 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Not sure if this may be related (since my engine is completely different) but i have to rev up the engine to above 4k ish rpm once to get the alternator to kick in and produce enough current to charge the battery.
If i just turn on the car and let it idle, it never gets that initial kick and just sits at 12V. (IMG:style_emoticons/default/idea.gif) |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,980 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Not sure if this may be related (since my engine is completely different) but i have to rev up the engine to above 4k ish rpm once to get the alternator to kick in and produce enough current to charge the battery. If i just turn on the car and let it idle, it never gets that initial kick and just sits at 12V. (IMG:style_emoticons/default/idea.gif) Andy very possibly. So I just corrected a gauge issue but while doing that I tested the D+ lead vs the battery and there is a 1 volt drop between the 2. Hmm bad connection maybe? I will have to look around for that but so odd. Could that be the bulb itself with that much resistance? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,597 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Not sure if this may be related (since my engine is completely different) but i have to rev up the engine to above 4k ish rpm once to get the alternator to kick in and produce enough current to charge the battery. If i just turn on the car and let it idle, it never gets that initial kick and just sits at 12V. (IMG:style_emoticons/default/idea.gif) That is a common problem with a 964/993 that has been converted to a single belt. The factory had the alternator spinning at a faster speed than the fan. A conversion to a single belt causes it to spin too slow at idle to get the alternator to start working. I had to tap the accelerator to get the alternator to kick in every time. |
mb911 |
Minor update. Ohmed out the blue D+ wire back to the gauge. No measurable loss. The red/white switch 12v adjacent to that wire reads 1v less than the battery. I need to check that out next
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,037 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
mb911 |
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump
Superhawk996 |
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump Good find I can’t remember how much current fuel pump draws but should only be a couple amps - let’s say 5 amps? To get 1v of voltage drop across wiring would mean you have wiring with 0.2 ohms of resistance in it. Agree ignition switch is a good 1st place to look but if it’s not there, you’ll need to track it back to wherever it resides. Worst case is that it’s a few smaller drops across wiring, terminal connections etc. Is your fuel pump re-wired or are you running it off the relay board and OEM round relay back in engine compartment. Can’t remember what you did for the /6 conversion. |
mb911 |
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump Good find I can’t remember how much current fuel pump draws but should only be a couple amps - let’s say 5 amps? To get 1v of voltage drop across wiring would mean you have wiring with 0.2 ohms of resistance in it. Agree ignition switch is a good 1st place to look but if it’s not there, you’ll need to track it back to wherever it resides. Worst case is that it’s a few smaller drops across wiring, terminal connections etc. Is your fuel pump re-wired or are you running it off the relay board and OEM round relay back in engine compartment. Can’t remember what you did for the /6 conversion. I am not using a relay at all so just switched 12v but with switching to the 044 pump it maybe necessary now |
Superhawk996 |
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump Good find I can’t remember how much current fuel pump draws but should only be a couple amps - let’s say 5 amps? To get 1v of voltage drop across wiring would mean you have wiring with 0.2 ohms of resistance in it. Agree ignition switch is a good 1st place to look but if it’s not there, you’ll need to track it back to wherever it resides. Worst case is that it’s a few smaller drops across wiring, terminal connections etc. Is your fuel pump re-wired or are you running it off the relay board and OEM round relay back in engine compartment. Can’t remember what you did for the /6 conversion. I am not using a relay at all so just switched 12v but with switching to the 044 pump it maybe necessary now Got it. Yeah would definitely want that “battery” side of the D+ feed circuit to be reflecting full battery voltage over at the Gen light bulb (yellow highlighted wiring) ![]() |
mb911 |
@superhawk996 so interesting enough with no fuel pump running there is no voltage loss. Gonna change out the ignition switch to be sure might need a relay on the pump Good find I can’t remember how much current fuel pump draws but should only be a couple amps - let’s say 5 amps? To get 1v of voltage drop across wiring would mean you have wiring with 0.2 ohms of resistance in it. Agree ignition switch is a good 1st place to look but if it’s not there, you’ll need to track it back to wherever it resides. Worst case is that it’s a few smaller drops across wiring, terminal connections etc. Is your fuel pump re-wired or are you running it off the relay board and OEM round relay back in engine compartment. Can’t remember what you did for the /6 conversion. I am not using a relay at all so just switched 12v but with switching to the 044 pump it maybe necessary now Got it. Yeah would definitely want that “battery” side of the D+ feed circuit to be reflecting full battery voltage over at the Gen light bulb. Yup so that is my plan. Just wish this 90% humidity and 90 plus degrees would go away for a few days to get this solved |
Superhawk996 |
One quick thing to do: rotate fuse 9 and see if the voltage drop goes away.
I absolutely don’t miss Midwest heat & especially the humidity. I know how miserable it is. |
mb911 |
One quick thing to do: rotate fuse 9 and see if the voltage drop goes away. I absolutely don’t miss Midwest heat & especially the humidity. I know how miserable it is. Sounds good will try that as well. Midway through the 911 ignition switch replacement. Heading to lake now for some boating and cooling down |
mb911 |
Ok switch is changed out, checked and replaced any questionable grounds, ran a fuel pump relay(fused) along with the inertia switch, cleaned up the connections on the fuse panel and now all is well. What’s amazing is that I cleaned it a year or 2 ago. Thanks for all the help everyone
Lo-Fi Version | Time is now: 2nd July 2024 - 01:22 AM |
