914 structure, How are they made? |
Ace Le Count |
Jul 5 2024, 02:53 PM
Looking for 4712908713 Group: Members Posts: 173 Joined: 20-February 18 Member No.: 21,910 Region Association: None |
Hi all, from what I understand, the longs are double thickness? Is it the same all the way through the car, as in the top, bottom, and sides of them? Just trying to understand how these cars are built. Photos would really help. Thanks!
Montreal914 |
Jul 5 2024, 03:46 PM
Senior Member Group: Members Posts: 1,707 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
That is quite a wide question but let me try to explain some. The longs are doubled up in the elbow in the rear on both the inner and outer halves of the beam.
The yellow line on the left is the termination of the inside inner layer. On my car, you can see I actually cut the bottom half of it because it was compromized. As you can see, the inside inner forward lower part also includes the seatbelt point (round hole ~1"). This inside inner layer become corrugated after the elbow and goes pretty much to the upper end of the long. The inside outer layer goes toward the front about the same at the inside inner. It does support the jack point area. Actually, if the jack point piramid is removed, you should see an indented shallow pyramid with a square which is in the ouside outer layer and a large hole (~2 1/2") would be the inside outer layer. The inside outer layer also goes up the long but ends about 2/3 in a V shape represented by the right yellow line in my picture. You can also star here in my build thread that I am getting back into, after too many months... (IMG:style_emoticons/default/rolleyes.gif) http://www.914world.com/bbs2/index.php?sho...9463&st=110 You will see some picture showing how it's made. But best is probably to read through the reference build thread such as Jeff Hail, BBrock (RIP), others... Attached thumbnail(s) |
JeffBowlsby |
Jul 5 2024, 04:10 PM
914 Wiring Harnesses Group: Members Posts: 8,759 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
930cabman |
Jul 5 2024, 04:16 PM
Advanced Member Group: Members Posts: 3,722 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Hi all, from what I understand, the longs are double thickness? Is it the same all the way through the car, as in the top, bottom, and sides of them? Just trying to understand how these cars are built. Photos would really help. Thanks! The framework is made up of thin gauge formed sheet steel sections often welded together to form rigid sections. Track cars generally add another layer to further stiffen the framework |
Ace Le Count |
Jul 5 2024, 04:49 PM
That is quite a wide question but let me try to explain some. The longs are doubled up in the elbow in the rear on both the inner and outer halves of the beam. The yellow line on the left is the termination of the inside inner layer. On my car, you can see I actually cut the bottom half of it because it was compromized. As you can see, the inside inner forward lower part also includes the seatbelt point (round hole ~1"). This inside inner layer become corrugated after the elbow and goes pretty much to the upper end of the long. The inside outer layer goes toward the front about the same at the inside inner. It does support the jack point area. Actually, if the jack point piramid is removed, you should see an indented shallow pyramid with a square which is in the ouside outer layer and a large hole (~2 1/2") would be the inside outer layer. The inside outer layer also goes up the long but ends about 2/3 in a V shape represented by the right yellow line in my picture. You can also star here in my build thread that I am getting back into, after too many months... (IMG:style_emoticons/default/rolleyes.gif) http://www.914world.com/bbs2/index.php?sho...9463&st=110 You will see some picture showing how it's made. But best is probably to read through the reference build thread such as Jeff Hail, BBrock (RIP), others... Thank you for your answer. I found this on your build thread. It is what I was looking for, but was wondering how far it goes. If the whole long is like this or not. your photo with the yellow lines helped to clarify things for me. |
windforfun |
Jul 5 2024, 05:00 PM
Senior Member Group: Members Posts: 1,993 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Wasn't this the first uni-body car to be sold in the US?
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
930cabman |
Jul 5 2024, 05:51 PM
Wasn't this the first uni-body car to be sold in the US? (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) 356 |
technicalninja |
Jul 5 2024, 06:05 PM
Advanced Member Group: Members Posts: 2,026 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
https://gizmodo.com/a-brief-history-of-unib...600%20in%201941.
Nash looks like they take the cake! VW was close behind with the Bettle (which sold thousands of times better). I consider the beetle as Uni-body. Some might not. |
930cabman |
Jul 5 2024, 06:30 PM
https://gizmodo.com/a-brief-history-of-unib...600%20in%201941. Nash looks like they take the cake! VW was close behind with the Bettle (which sold thousands of times better). I consider the beetle as Uni-body. Some might not. I would say no to the beetle, it had a spine for structure IIRC |
technicalninja |
Jul 5 2024, 06:36 PM
Beetle had a "pan" that got substantially stronger when the body was bolted to it.
If you want to use the "pan" as an off-road vehicle you have to weld/bolt a roll cage assembly to it to give it strength. The pan alone is not really enough IMO. Now, a vehicle with a "frame" can function without any of the body on it. The body is not part of the stressed assembly. |
technicalninja |
Jul 5 2024, 07:20 PM
This is a good thread to look through regarding structure.
Fred's rebuilding MOST of the important parts of the unibody. Some areas are far more than 2 layers... It is also a good reference as to what happens internally and what you have to do to repair it. Had that NOT been a Bumble Bee, I'd have thrown it away. http://www.914world.com/bbs2/index.php?showtopic=368359 |
KELTY360 |
Jul 5 2024, 09:49 PM
914 Neferati Group: Members Posts: 5,091 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Wasn't this the first uni-body car to be sold in the US? (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) 356 First unibody car in the US was the ‘36 Lincoln Zephyr. |
nathanxnathan |
Jul 6 2024, 07:11 PM
Member Group: Members Posts: 294 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
Here are a few pics I have that show how it's layered. To use the terminology in the diagram, Auto Atlanta has a piece that includes the inside outer and outside outer already assembled/welded together. The outside outer is actually the inner wheel well.
https://www.ebay.com/itm/232571921636?chn=p...BoaAnr1EALw_wcB On the outside the long is a separate piece just forward of the firewall. You can see here how there is a flap that overlaps both layers of the rear. I think I fudged them together at the top here which I don't think is actually correct. It all gets sandwiched together as the rear of the door jam comes together with it. Here's a pic of the inside, the 1 piece that goes from the rear of the front fender past the firewall, and it's cut just forward of the front of the trunk Tricky to remove rear of that as there's a double layer section that overlaps it just in front of the trunk. And a shot of both layers of the inside which includes the lower seatbelt mounting point. I wouldn't recommend doing it how I did here, to remove the inside with the outside still attached. I feel like it would go way smoother to build up the car from the inside out as most builds I've seen do it. |
worn |
Jul 6 2024, 07:21 PM
can't remember Group: Members Posts: 3,356 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hi all, from what I understand, the longs are double thickness? Is it the same all the way through the car, as in the top, bottom, and sides of them? Just trying to understand how these cars are built. Photos would really help. Thanks! Another thing worth mentioning is that for repairs you make the largest hole on the outer layers, outer meaning farthest from the center of the structure member being fixed, then you make a smaller removal for the next layer and so on. Then you make repairs one layer at a time. You need to do this for access. |
930cabman |
Jul 7 2024, 08:24 AM
Hi all, from what I understand, the longs are double thickness? Is it the same all the way through the car, as in the top, bottom, and sides of them? Just trying to understand how these cars are built. Photos would really help. Thanks! Another thing worth mentioning is that for repairs you make the largest hole on the outer layers, outer meaning farthest from the center of the structure member being fixed, then you make a smaller removal for the next layer and so on. Then you make repairs one layer at a time. You need to do this for access. (IMG:style_emoticons/default/agree.gif) Try to have 8" or so of overlap with your splices |
Ace Le Count |
Jul 7 2024, 06:56 PM
Here are a few pics I have that show how it's layered. To use the terminology in the diagram, Auto Atlanta has a piece that includes the inside outer and outside outer already assembled/welded together. The outside outer is actually the inner wheel well. https://www.ebay.com/itm/232571921636?chn=p...BoaAnr1EALw_wcB On the outside the long is a separate piece just forward of the firewall. You can see here how there is a flap that overlaps both layers of the rear. I think I fudged them together at the top here which I don't think is actually correct. It all gets sandwiched together as the rear of the door jam comes together with it. Here's a pic of the inside, the 1 piece that goes from the rear of the front fender past the firewall, and it's cut just forward of the front of the trunk Tricky to remove rear of that as there's a double layer section that overlaps it just in front of the trunk. And a shot of both layers of the inside which includes the lower seatbelt mounting point. I wouldn't recommend doing it how I did here, to remove the inside with the outside still attached. I feel like it would go way smoother to build up the car from the inside out as most builds I've seen do it. Thank you! This is the exact answer I was looking for! Thanks to everyone for their help! |
friethmiller |
Jul 8 2024, 07:56 AM
Senior Member Group: Members Posts: 665 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
This is a good thread to look through regarding structure. Fred's rebuilding MOST of the important parts of the unibody. Some areas are far more than 2 layers... It is also a good reference as to what happens internally and what you have to do to repair it. Had that NOT been a Bumble Bee, I'd have thrown it away. http://www.914world.com/bbs2/index.php?showtopic=368359 Ha! Yes, I would have never purchased the car, if I had any doubt of its rarity. |
didenpx |
Nov 25 2024, 08:50 AM
Newbie Group: Members Posts: 19 Joined: 1-September 23 From: Usa Member No.: 27,556 Region Association: North East States |
That is quite a wide question but let me try to explain some. The longs are doubled up in the elbow in the rear on both the inner and outer halves of the beam. The yellow line on the left is the termination of the inside inner layer. On my car, you can see I actually cut the bottom half of it because it was compromized. As you can see, the inside inner forward lower part also includes the seatbelt point (round hole ~1"). This inside inner layer become corrugated after the elbow and goes pretty much to the upper end of the long. The inside outer layer goes toward the front about the same at the inside inner. It does support the jack point area. Actually, if the jack point piramid is removed, you should see an indented shallow pyramid with a square which is in the ouside outer layer and a large hole (~2 1/2") would be the inside outer layer. The inside outer layer also goes up the long but ends about 2/3 in a V shape represented by the right yellow line in my picture. You can also star here in my build thread that I am getting back into, after too many months... (IMG:style_emoticons/default/rolleyes.gif) http://www.914world.com/bbs2/index.php?sho...9463&st=110 You will see some picture showing how it's made. But best is probably to read through the reference build thread such as Jeff Hail, BBrock (RIP), others... Thank you for your answer. I found this on your build thread. It is what I was looking for, but was wondering how far it goes. If the whole long is like this or not. your photo with the yellow lines helped to clarify things for me. Posting this here specifically to address whether the whole long looks like this. I don't think so. below is a photo looking into the front of the sill structure from the front wheel well of my 1975. You can make out three separate layers of metal: the bottom of the door pillar post, the inner rocker, another layer of metal (called what?), and finally the heating ducts). I'll be peeling this open in the coming week or so and will post more detailed photos once I'm properly in there. |
Ace Le Count |
Nov 28 2024, 12:32 PM
That is quite a wide question but let me try to explain some. The longs are doubled up in the elbow in the rear on both the inner and outer halves of the beam. The yellow line on the left is the termination of the inside inner layer. On my car, you can see I actually cut the bottom half of it because it was compromized. As you can see, the inside inner forward lower part also includes the seatbelt point (round hole ~1"). This inside inner layer become corrugated after the elbow and goes pretty much to the upper end of the long. The inside outer layer goes toward the front about the same at the inside inner. It does support the jack point area. Actually, if the jack point piramid is removed, you should see an indented shallow pyramid with a square which is in the ouside outer layer and a large hole (~2 1/2") would be the inside outer layer. The inside outer layer also goes up the long but ends about 2/3 in a V shape represented by the right yellow line in my picture. You can also star here in my build thread that I am getting back into, after too many months... (IMG:style_emoticons/default/rolleyes.gif) http://www.914world.com/bbs2/index.php?sho...9463&st=110 You will see some picture showing how it's made. But best is probably to read through the reference build thread such as Jeff Hail, BBrock (RIP), others... Thank you for your answer. I found this on your build thread. It is what I was looking for, but was wondering how far it goes. If the whole long is like this or not. your photo with the yellow lines helped to clarify things for me. Posting this here specifically to address whether the whole long looks like this. I don't think so. below is a photo looking into the front of the sill structure from the front wheel well of my 1975. You can make out three separate layers of metal: the bottom of the door pillar post, the inner rocker, another layer of metal (called what?), and finally the heating ducts). I'll be peeling this open in the coming week or so and will post more detailed photos once I'm properly in there. That would be awesome! Thank you! |
didenpx |
Dec 2 2024, 06:14 PM
This is the cross section of the front part of the longitudinal looking from the rear of the vehicle toward the front. You can clearly make out an additional structural element between the outer sill and the heating duct. It extends to about the lame distance as the rear portion of the A-pillar/bottom of door pillar. The front of mine is gone, but I surmise that it is shaped similar to the front of the outer sill. It appears to provide additional structural rigidity in the area of the sills beneath the door pillar. |
Lo-Fi Version | Time is now: 4th December 2024 - 02:22 AM |
