> 3rd Brake light behind targa trim
Literati914
post Jul 8 2024, 11:32 AM
I've got a couple extra horizontal targa trim (brightwork) pieces on hand and I ran extra wiring for a 3rd brake light during my wiring harness refurb. I was hoping to find a slim LED strip and neatly cut away some of the metal trim piece to fit it behind - for a clean simple look.
I've read up on 3rd brake lights here on the forum - so I know what all the other options are, and basically I'm not interested in doing any of those.. however, I'd consider mounting one on the outside face of the trim IF there was no way of getting it behind the trim.. but that's not ideal.
Two things wrong with the ones I'm seeing w/ google searches.. they seem to be only adhesive mountable and that adhesive is on the backside obviously. I want a screw at each end if possible, so some kind of flange around the perimeter would be nice. Also, they tend to be way too long.
I found an old post from @euro911 showing the set up, but it was just a pic, no details to it. Anyone done this and have any recommendations?
friethmiller
post Jul 8 2024, 01:33 PM
Ok, if this isn't what you're looking for @Literati914 , I apologize. My light mounts behind the trim and is pretty low profile, IMO. I fashioned two brackets to hold my LED brake light that I purchased off Amazon. I drilled two holes and used two pop rivets to secure the brackets and then attached/wired-in the light. I then relieved the chrome piece to clear the brackets (minor adjustment). Finally, I "sistered" in the hot wire to the driver side tail light and, of course, grounded the other.
ClayPerrine
post Jul 8 2024, 02:29 PM
I already have the light and the concept on how to put this together. I just have not found a spare trim piece.
Clay
Literati914
post Jul 8 2024, 02:35 PM
QUOTE(ClayPerrine @ Jul 8 2024, 03:29 PM) *
Clay
I can hook you up with that!
Trade you for intellectual property ? (IMG:style_emoticons/default/biggrin.gif)
StarBear
post Jul 8 2024, 02:51 PM
As noted in a prior thread, I used an L piece of 1.5” aluminum roof edge flashing, painted to match car and secured vinyl magnets on the outside of the L and mounted a thin LED strip (AutoZone) to the other outside edge. Whole thing just mounts under the trim and comes off as/if (never yet) needed.
No drilling or extra trim.
ClayPerrine
post Jul 8 2024, 02:56 PM
QUOTE(Literati914 @ Jul 8 2024, 03:35 PM) *
Clay
Sure. Let me know when you want to get together.
Clay
Spoke
post Jul 8 2024, 07:42 PM
Jerry
Got this one from Jegs. They come in 6, 9, 12 inch. This is 9 inch. Mounted it on the chrome trim so it hangs below the trim. Can't see it in the mirror because of the roll hoop padding.
friethmiller
post Jul 8 2024, 08:10 PM
QUOTE(Spoke @ Jul 8 2024, 07:42 PM) *
@Spoke - That looks a lot like mine but I think I like your solution even better. Nice job! (IMG:style_emoticons/default/smilie_pokal.gif)
Spoke
post Jul 9 2024, 05:04 AM
Jerry
QUOTE(friethmiller @ Jul 8 2024, 10:10 PM) *
@friethmiller
Thanks. Here's the entire installation of the 3rd brake light. Just realized I had the 12 inch light and I got it through Summit. I grabbed brake power from the rear light assembly with a Y-spade so I didn't have to cut/splice any wires.
Spoke's 3rd Brake Install
emerygt350
post Jul 9 2024, 05:41 AM
20 dollars at Walmart. Self adhesive. Not exactly pebble beach but very effective and invisible from inside. No damage to the car.
I don't think this is the solution you are looking for though...
Literati914
post Jul 9 2024, 10:26 AM
Thanks for suggestions guys, but I'm trying to stay dedicated to putting one behind the horizontal targa trim.
I've seen mention of the rear window mounted light from a Ford GT working but can't find it done ..or any dimensions of this light. On the other-hand I'd be surprised if there's not a slim generic LED strip that would work too.
friethmiller
post Jul 9 2024, 12:07 PM
QUOTE(Literati914 @ Jul 9 2024, 10:26 AM) *
@Literati914 - I'm confused. Two out of the three solutions above go behind the horizontal trim. Can you clarify? Thanks.
technicalninja
post Jul 9 2024, 12:10 PM
I want to do "inside the trim" too!
I want to go all the way across and down the sides as well.
A WIDE upside down "U".
I WANT the monkeys behind me to go "WTF!" when I hit the brakes!
I'm figuring the trim itself will not be able to be used.
I'll have to make something to house the lights and replace the trim.
I'm planning on the "Murdered Out" look on my current trim anyways due to the damage they already have. Semi flat black or grey "Titanium" will be the color choice.
The black would be EASY to do on a 3D printer.
They just look black until they light up RED.
Literati914
post Jul 9 2024, 12:24 PM
QUOTE(friethmiller @ Jul 9 2024, 01:07 PM) *
Yes, inside of the trim, sandwiched between trim and pinch weld area.
Literati914
post Jul 9 2024, 12:28 PM
QUOTE(technicalninja @ Jul 9 2024, 01:10 PM) *
I'm planning on the "Murdered Out" look on my current trim anyways due to the damage they already have. Semi flat black..
Yea, that's what I've done with the trim on this current car.. it was not that nice to begin with, so I don't mind cutting into it for experimentation. I have better that I could transfer to later if I change my mind on the black, after getting the 3rd light set up figured out.
technicalninja
post Jul 9 2024, 12:41 PM
It's SO HARD to modify "perfect concours" and SO EASY to modify trash.
I actually prefer the trash...
Allows me license!
friethmiller
post Jul 9 2024, 01:02 PM
QUOTE(Literati914 @ Jul 9 2024, 12:28 PM) *
Ok, yeah I thought of that too when I did mine but the width of the light, if I remember correctly, was more than the width of the chrome piece. I'm sure this can be done just need to be mindful of the dimension, of course.
burton73
post Jul 9 2024, 02:09 PM
Senior member, and old dude
The one that PMB decided was what I wanted on my 6. I do not know what brand it is but you will notice the black plastic covers for the ends. A very clean set up.
Best Bob B
JmuRiz
post Jul 9 2024, 02:29 PM
Bob, looks similar to the old trailblazer/envoy unit I bought for mine YEARS ago. I was planning on mounting to the top or underside of the engine grill (I think it has a slight curve to it that might fit better there). If I wasn't so damn slow with my car I'd have photos of it installed long ago.
euro911
post Jul 9 2024, 02:56 PM
I never did get around to doing the upper rear targa trim modification that I planned for HOWARD. I did the '86 Corvette convertible brake light on the engine lid grille on the 'BB'.
I have a nice spare upper rear trim piece if anyone's interested in it (IMG:style_emoticons/default/confused24.gif)
http://www.914world.com/bbs2/index.php?sho...=367873&hl=
Also have some nice lower sail trim pieces available ...
http://www.914world.com/bbs2/index.php?sho...=367896&hl=
- Lo-Fi Version Time is now: 14th March 2025 - 07:14 AM
