Jim C |
Member ![]() ![]() Group: Members Posts: 206 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region ![]() ![]() |
Recently on a rare occasion I was caught in the rain, I noticed that I did not have two speed wiper function. One click up started the wipers, but the second click up was no change in speed. I do not have the intermittent wipers option, at least there is no bracket and relay installed. The wiper switch seemed well used and since I also needed to replace the turn signal switch I figured to kill two birds. Both switches are installed, but now the wipers operate in the lowest (off) position, turn off in the middle (on) position, and remain off in the uppermost position so I still only one wiper speed. The replacement switch was supposedly for a 1975-1976 914. I can live with it since I do have wipers and never intentionally drive in the rain, but... (IMG:style_emoticons/default/WTF.gif)
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,033 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
probably have the pin sequence off
Recently on a rare occasion I was caught in the rain, I noticed that I did not have two speed wiper function. One click up started the wipers, but the second click up was no change in speed. I do not have the intermittent wipers option, at least there is no bracket and relay installed. The wiper switch seemed well used and since I also needed to replace the turn signal switch I figured to kill two birds. Both switches are installed, but now the wipers operate in the lowest (off) position, turn off in the middle (on) position, and remain off in the uppermost position so I still only one wiper speed. The replacement switch was supposedly for a 1975-1976 914. I can live with it since I do have wipers and never intentionally drive in the rain, but... (IMG:style_emoticons/default/WTF.gif) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,980 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
As the good Dr said. Your off somewhere.
All the way down is intermittent 2nd is off 1up is slow 2up is fast |
Jim C |
You mean where the switch plugs into the harness at the base of the steering column cover?
914Sixer |
Yes
Jim C |
Checked and rechecked and all five pins seated.
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,669 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,604 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Jim, I have both the OEM used and OEM replacement switches that I can take pic's of if you need to check the wiring of your switch.
Jim C |
76-914 |
76-914 |
76-914 |
76-914 |
Jim C |
Lo-Fi Version | Time is now: 7th September 2024 - 05:17 PM |
