BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,158 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster.
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,632 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Did you Ck 914 Rubber. I think I was something from them for conversions
Bet Bob B |
BillJ |
Their kit has a fin you can weld on to the throttle pivot. I want one that is already done
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,147 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
BillJ |
Boy Ben, was just hoping you would say "sure will whip that right up and send to you man!" Lol
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,481 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I have done 2 of these and modified both. I was lucky to have found a used original linkage with the "tab", so I was able to use it as a pattern. But IIRC there was a couple changes I had to make to get things right. Add to this, subtract from that, but cannot recall exactly
I also cut a section of the top portion of the tunnel away for easy access |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,642 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster. @billJ I can make one for you. I do it a little different in that i drill a hole in the accelerator crank and mount the fin with a 4mm screw. I use an original to get the orientation of the fin. Pretty busy but i can get one made in a couple weeks max. |
bdstone914 |
Double post
BillJ |
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster. @billJ I can make one for you. I do it a little different in that i drill a hole in the accelerator crank and mount the fin with a 4mm screw. I use an original to get the orientation of the fin. Pretty busy but i can get one made in a couple weeks max. Awesome. Will PM you for details on where to send and to pay you. Seems only right as it is going into your cluster. |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,624 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Does anyone have or make an already assembled pivot for the pedal cluster side of the hand throttle? I know that the kit includes a little fin, but would prefer it already done and can install in my nice stone rebuilt cluster. @billJ I can make one for you. I do it a little different in that i drill a hole in the accelerator crank and mount the fin with a 4mm screw. I use an original to get the orientation of the fin. Pretty busy but i can get one made in a couple weeks max. Any chance you could post a couple pics of the original? I have to make mine, thanks |
Lo-Fi Version | Time is now: 7th September 2024 - 05:24 PM |
