rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,610 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,147 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? Phenolic spacers , standard manifolds off a 71 T, no never wanted plastic it just scared me when I was running fuel to the carbs but now that it’s fuel injected maybe. Yes for sure the proper height as you can see by sheet metal etc. |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
mb911 |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,789 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? Phenolic spacers , standard manifolds off a 71 T, no never wanted plastic it just scared me when I was running fuel to the carbs but now that it’s fuel injected maybe. Yes for sure the proper height as you can see by sheet metal etc. Weird.. When I put the 73 T motor in my car, I didn't have to alter the factory air cleaner at all. But it was MFI. |
mb911 |
Why is there a dent in the back of the air cleaner????? Only way it would fit so had to massage it. Spent a ton of time on this. I have the engine at stock 914-6 height but the air cleaner just was a PIA but I refused to go with k&n setups. I purchased a few housings but all from 911s and required modifications before the engine lid bracing would clear Ben I had the same question. The engine tin looks to be at the right height. Tall manifolds ? Phenolic spacers ? Did you try a 911 plastic housing ? Phenolic spacers , standard manifolds off a 71 T, no never wanted plastic it just scared me when I was running fuel to the carbs but now that it’s fuel injected maybe. Yes for sure the proper height as you can see by sheet metal etc. Weird.. When I put the 73 T motor in my car, I didn't have to alter the factory air cleaner at all. But it was MFI. I wonder if the MFI air cleaners are shorter? The steel ones have no forgiving factors |
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 873 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
here's a Lubral sticker I pulled off an early 911 air cleaner...long time ago...may have been on a Euro delivery 911....Lubral with Dutch colors used in Europe
somewhere I have a few pics of the 911 metal and plastic air cleaners side by side... the MFI where plastic like the 914-6 and seems to me both were a little thinner...not as tall/thick ![]() |
flat4guy |
Member ![]() ![]() Group: Members Posts: 454 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,480 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
For the Dented section,,
Attached image(s) ![]() |
mb911 |
mb911 |
technicalninja |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,807 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Looks "Factory"
Cept for the dent... "Transparent" Ninja approved! (IMG:style_emoticons/default/ninja.gif) |
mb911 |
Looks "Factory" Cept for the dent... "Transparent" Ninja approved! (IMG:style_emoticons/default/ninja.gif) Yes the dent has to stay I looked at it again. No other way |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,419 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Out of curiosity what is the dent clearanced to? Torsion bar retention loop?
mb911 |
technicalninja |
You know what will drive Ben BATSHIT crazy!
Someone else needs to ask "Why the dent" every few days... (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) |
mb911 |
You know what will drive Ben BATSHIT crazy! Someone else needs to ask "Why the dent" every few days... (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/stirthepot.gif) Lol it’s all good |
ClayPerrine |
Ben,
Where did you put the injectors? Did you modify the manifolds??? Would you post a detailed picture of them? Thanks, Clay |
mb911 |
ClayPerrine |
Ben, Where did you put the injectors? Did you modify the manifolds??? Would you post a detailed picture of them? Thanks, Clay Just into the MFI ports in the heads. Jpnovak makes an adapter ![]() I thought so. I was just checking on it. JP builds good stuff. I saw one of his EFI conversions at the Hill Country Rally a couple of years ago. Clay |
Lo-Fi Version | Time is now: 7th September 2024 - 05:26 PM |
